AUDIOPHONICS CANARE Digital Coaxial Cable Ultra Coax 75 Ohm BNC-BNC 1m
This Coaxial Ultra Coax 75 Ohm cable with male BNC connectors is assembled in France by Audiophonics, with top of the range components from Canare. This includes an ultra low-loss, ultra-high quality, shielded Canare L-5.5CUHD 12G-SDI cable, combined with Canare BCP-D55UHD connectors, specially designed for the cable mentioned. These components, combined with Audiophonics' know-how, enable us to offer you a resolutely high-end cable.
Reference : 13061
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 05-05-2026.
CANARE Ultra Coax
Canare Câble Numérique Coaxial Ultra Coax 75 Ohm BNC-BNC 1m
Câble coaxial Canare L-5.5CUHD
Canare L-5.5CUHD Ultra Coax cable
This 75 Ohm Coaxial L-5.5CUHD cable, designed and manufactured in Japan by Canare is the assurance of a very high quality product, formerly reserved for the professional market. It has excellent electrical and mechanical characteristics allowing it to ensure an ultra low loss rate.
It is a 12G-SDI cable, specially developed for the transmission and acquisition of 4K and UHD video streams in 60fps. It thus ensures a signal transmission speed of 12Gbps while being less heavy and cumbersome than 4 cables 3G-SDI.
The BNC 75 Ohm BPC-D55UHD connector is also designed in Japan and has been designed to fit the Canare L-5.5CUH cable. The connector consists of a gold-plated, ground machined central pin and an external Beryllium Copper contact.
Connecteurs Canare BCP-D55UHD
Cable typeCoaxial
Connectors2x Male BNC
Length1m
External diameterCable : 9mm
Connectors : 14.5mm
Canare Ultra Coax L-5.5CUHD Cable
Cable standard12G-SDI
Impedance75 Ohm
Internal conductor section16AWG (1.31mm²)
Internal conductor diameter1.35mm
External cable diameter (without external sheath)7.7mm
Insulation diameter5.55mm
External conductor materialRolled copper foil
Internal conductor resistance12.5 Ohm/km
External conductor resistance10.3 Ohm/km
Static capacity52 pF/m
Attenuation39.1dB/100m @ 6GHz
ColorBlack, white, cream
Canare BCP-D55UHD Connectors
Central pin platingGold
External contact materialCuivre Beryllium
Return loss0-3GHz >= 26.4dB
0-6GHz >= 20dB
0-12GHz >= 15dB
Tensile force>= 200N
Length (m)1.0
ShieldingYes
Section (mm²)1.31
ConnectorBNC
4 reviews
Perfect
Top quality , audio band ends very controlled , perhaps the sheath is too stiff
This review has been posted for AUDIOPHONICS CANARE Digital Coaxial Cable Ultra Coax 75 Ohm BNC-BNC 1m
Good
I am connecting a Oppo BDP 105 to a Lector Digicode s-192. Compaired with my previous 20 euro rca cable, the music is more transparent and the bass are more punchy.
I am very happy.
Good product
Just like in one of the previous comment I use this cable in the same situation - between Allo DigiOne and a Chord Qutest - it works well, it is also very well crafted - although it is a bit stiff.
Prefect to connect DigiOne Signature player and Chord Qutest DAC
I use it between DigiOne Signature player and Chord Qutest DAC.
It is a prefect match to the task, I tried up to 24bit/192KHz without any issue (maybe good for higher speeds but I does not have music to try). Not cheap but performs well, connectors are strong, looks/feels like a quality product.
This Coaxial Ultra Coax 75 Ohm cable with male BNC connectors is assembled in France by Audiophonics, with top of the range components from Canare....
