VIABLUE NF-75 Câble Digital Coaxial RCA Silver 0.50m
Reference : 106
140,00 €tax incl.
116,67 € tax excl.
Shipping date: 02-07-2026.
Câbles RCA NF-75 Silver Digital
The NF-75 ViaBlue RCA cables are high-end digital coaxial cables with ideal electrical characteristics that allow correct and error-free digital signal transmission.
In addition to a base impedance of 75 ohms, this cable also includes polyethylene dielectric insulation as well as a silver-plated shield.
These technical characteristics ensure extremely low resistance values ​​as well as maximum transmission quality of digital signals.
ViaBlue Silver Shield provides RCA NF-75 cables with 100% shielding, covering the entire cable.
This armor is composed of an aluminum foil and a silver-plated braided armor.
RCA NF-75 cables are assembled with RCA XLS ViaBlue gold plated and Teflon insulated plugs.
Ferrite cores placed at the ends significantly limit the induced currents that could occur between the conductor and and the shielding.
Caractéristiques:
  • External diameter: 9 mm
  • Connectors: T8 RCA plugs
  • Impedance: 52pF/M / 75 OHM
  • length: 0.5m
https://www.audiophonics.fr/images2/106/106_viablue_2.jpg
https://www.audiophonics.fr/images2/106/106_viablue_1.jpg
Length (m)0.5
ShieldingYes
Section (mm²)N/A
ConnectorCoaxial
Conductors Plating (Cable)NC
7 reviews
Excellent.
Très bon câble, excellente qualité de fabrication , très bonne sonorité.
Branchement aisé.
This review has been posted for VIABLUE NF-75 Câble Digital Coaxial RCA Silver 0.50m
Excellent !
Je suis parti sur cet cable pour relier mon Bluesound Node 2i et Dac Soncoz SGD1. Le son est très équilibré neutre et bien raffiné avec un charme analogue. Un équilibre général et un plaisir d’ecoute.
Superbe Cable
Marque qui gagne à être connue, finition de qualité et son au top.
Pour un budget bien moindre que certains câbles bcp plus chers et pas forcement avec un rendu sonore si bon.
câble transparent de bonne facture
Transparence et neutralité
Utilisé entre récepteur bluethoot 5.0 et ampli a1008 musical fidelity avec convertisseur intégré. Au départ le son est un peu bouché mais après 15 jours de rodage le son s'épanouit et la transparence et le naturel s'imposent. j' ai du modifié la position de mes correcteurs acoustiques de salle (osh et diffuseur acoustique ) ainsi que le réglage de l'équalizeur de mon smartphone qui se rapproche de la bande linéaire. Rivalise sans problème avec des cables beaucoup plus chers et parfois moins bon. Recommandable.
