The NEMOI series from manufacturer Neotech is the result of extensive research in the field of audio cable.
The modulation cable Neotech NEMOI 5220mixing insulation PTFEand pure rectangular section OFC copper conductors has a particular architecture allowing a strong reduction in the inductance and capacitance effect.
If you are looking for a high-resolution cable, Neotech NEMOI 5220may correspond to this expectation.
The result is surprising mixing with the listening qualities often contradictory like seated in the grave and readable, natural sound scene with a High Definition in the medium without auditory fatigue.
- NEMOI series cables use RCA plugs DGA-202 with PIN OFC connectors and PTFE insulation -
- Structure of the OFC cableNeotech NEMOI 5220 -
Features:/ Strong>
Length (m) | 3.0 |
Shielding | Yes |
Section (mm²) | N/A |
Connector | RCA |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
