AUDIOPHONICS STEALTH Stereo Cinch XLR Interconnect Cable OFC Copper ELECAUDIO 1.5m (Pair)
This XLR modulation cable STEALTH was assembled by us in the Audiophonics workshops. The choice of materials has been carefully studied and every detail or finish is checked to offer you a top-of-the-range cable.
Reference : 14088
99,00 €tax incl.
82,50 € tax excl.
Audiophonics STEALTH
XLR stereo odulation Cable 1.5m
Audiophonics STEALTH Câble de modulation stéréo XLR
This XLR modulation cable was assembled by us in the Audiophonics workshops. The choice of materials has been carefully studied and every detail or finish is checked to offer you a top-of-the-range cable. The modulation cable used is an ELECAUDIO SC-201B 2x 1.31mm² cross section with double shielding and PE insulation. The XLR connectors used are ELECAUDIO CX-101 and CX-102 Gold Plated Copper connectors.
Technical specifications
Elecaudio SC-201B Cable
ConductorsOFC copper silver plated - 2 conductors of 1.31mm² each
Compositon of conductors41x 0.12mm silver plated OFC copper wire, 0.12mm diameter each
Insulation of conductorsPE
Double shieldingBraided copper braid + Aluminium foil
External sheathHigh thickness PVC
External diameterØ 7,8mm
Elecaudio CX-101 - XLR Male Connector
ConductorTellurium Copper
PlatingGold plated 24k
BodyMachined metal
Max. connector diameter19mm
Overall body length50mm
Elecaudio CX-102 - XLR Female connector
ConductorCopper alloy
BodyMachined metal
Locking systemBy holding pin
Max. connector diameter23mm
Overall body length63mm
Length (m)1.5
ShieldingYes
Section (mm²)1.31
ConnectorXLR
This XLR modulation cable STEALTH was assembled by us in the Audiophonics workshops. The choice of materials has been carefully studied and every...
