SOMMERCABLE EPILOGUE XLR Interconnect Cable 0.75m (Pair)
The Epilogue cables from Sommercable consist of two Neutrik XLR connectors, male on one side and female on the other. These benefit from high build quality and are based on four copper conductors with a cross-section of 0.14mm². Each of these conductors is covered with a thin carbon layer before being enclosed in insulation. This carbon layer not only dissipates static electricity that may accumulate during cable handling, but also smooths the boundary between conductor and insulation, helping to avoid micro-voids and irregularities that could induce slight capacitive instability.
Reference : 22231
137,61 €tax incl.
114,67 € tax excl.
Sommercable Epilogue Stereo Interconnect Cable XLR Male to XLR Female Gold-Plated 0.75m (Pair)
The Epilogue cables from Sommercable consist of two Neutrik XLR connectors, male on one side and female on the other. These benefit from high build quality and are based on four copper conductors with a cross-section of 0.14mm². Each of these conductors is covered with a thin carbon layer before being enclosed in insulation. This carbon layer not only dissipates static electricity that may accumulate during cable handling, but also smooths the boundary between conductor and insulation, helping to avoid micro-voids and irregularities that could induce slight capacitive instability. The result is cables with a very low capacitance of only 35pF, ensuring the absence of crosstalk. Finally, to protect signal transmission from electromagnetic interference, these cables feature a braided copper shielding, ensuring the absence of EMI/RFI noise.
Product typeXLR cables
Conductor cross-section4x 0.14mm²
Length0.75m
Conductor materialCopper
Connectors1x XLR male
1x XLR female
Connector contact platingGold
Shielding
ColorYellow
PackagingSold in pairs (1 cable with red rings, 1 cable with white rings)
Length (m)0.75
ShieldingYes
Section (mm²)0.14
ConnectorXLR
Conductors Plating (Cable)Carbone
SOMMERCABLE EPILOGUE Interconnect Cable Male XLR to Female XLR Gold Plated 0.75m (Pair)
The Epilogue cables from Sommercable consist of two Neutrik XLR connectors, male on one side and female on the other. These benefit from high build...
