SMSL PL100 CD Player CS43131 Black
The SMSL PL100 CD player is the perfect way to enjoy your CD collection. It's essentially based on a CS43131 DAC chip and a PLL (Phase-locked Loop) circuit for sound reproduction as close as possible to the original source.
4.5 / 5
Reference : 20391
119,90 €tax incl.
99,92 € tax excl.
Last items in stock !
Shipping date: 07-04-2026.
SMSL PL100 picture
The SMSL PL100 CD player is the perfect way to enjoy your CD collection. It's essentially based on a CS43131 DAC chip and a PLL (Phase-Locked Loop) circuit for sound reproduction as close as possible to the original source. Various CD formats are supported: CD / CD-R / CD-RW / MP3 CD. Several outputs are also available, including a coaxial output, a Toslink optical output and an analog RCA output. There's an additional 3.5mm jack headphone output capable of delivering up to 2x60mW under 32 Ohm. The user experience is enhanced by the small display on the PL100's front panel, as well as the various control buttons and remote control.
SMSL PL100: CS43131 DAC chip
The CS43131 DAC chip, coupled with the PLL circuit, offers high-quality CD decoding for high-quality final sound reproduction. The PLL circuit greatly reduces jitter during playback.
DAC chip CS43131
Raw digital outputs
SMSL PL100: Raw digital outputs
The PL100's SPDIF Coaxial and Toslink optical outputs are capable of outputting the raw signal for direct connection to a DAC, so you can enjoy the best possible sound.
SMSL PL100: Headphone output
Thanks to its CS43131 DAC chip, the SMSL PL100 CD player is also able to deliver up to 60mw under 32 ohms of power on its 3.5mm jack output to drive a wide range of headphones and IEMs.
3.5mm headphone output
A practical form factor
SMSL PL100: Two installation options
The form factor of the SMSL PL100 CD player allows it to be positioned either horizontally or vertically.
SMSL PL100 overview
SMSL PL100 overview
1Coaxial output
2Toslink optical output
33.5mm headphone output
4RCA output
55V 2A USB power input
This device does not work with USB-PD (Power Delivery) power supplies.
In addition, please note that a 5V 3A power supply is required.
Product typeCD player
DAC chipCS43131
InputCD
Outputs1x Coaxial
1x Toslink optical
1x RCA output
1x Jack 3.5mm headphone output
Supported CD formatsCD / CD-R / CR-RW / CD MP3
Headphone output power60mW @ 32 ohm
THD+N0.001%
SNR110dB
Power supply5V 3A via USB
Power consumption4W
Standby: < 0.1W
Dimensions160 x 162 x 42mm
Weight1.2kg
Package1x SMSL PL100 CD player
1x Power supply USB cable
1x Remote control
2 reviews
Parfait
Rapport qualité prix imbattables comme toujours chez SMSL.
Testé en analogique et coaxial pas de différence pour mon oreille. Moi au contraire de beaucoup de commentaires, l'esthétique me plaît, ça change des standards idiophiles a 400€, voir plus, pour une boîte 3 fois plus grande et quasi vide. A voir dans le temps pour le chargement, mais les autoradio était costaud alors pourquoi pas. Qualité sonore, encombrement minimum et simplicité d'utilisation son au rendez vous. Je recommande.
This review has been posted for SMSL PL100 CD Player CS43131 Black
Bon transport
Je cherchais un transport de petite taille avec un son correct pour le placer à coté d'un ampli FDA Sabaj, le résultat est correct, peut-etre moins de corps que mon vieux lecteur Pioneer mais c'est tres défini, je n'ai pas testé le DAC interne, sinon branché sur un DAC SMSL SU-1 et des enceintes de monitoring ça marche bien, c'est cohérent, on est pas sur un vieux lecteur Philips ou Marantz, c'est neutre.
The SMSL PL100 CD player is the perfect way to enjoy your CD collection. It's essentially based on a CS43131 DAC chip and a PLL (Phase-locked...
