By buying this product you get 101 loyalty points
Shanling's MCD 1.3 is a top-of-the-range CD player with an XMOS XU316 USB interface, AK4499EX+ AK4191EQ DAC chip combo, TPA6120 headphone amplification and MUSES8920 line-out pre-amplification. This device is extremely versatile, thanks in particular to its multiple connections coupled with Bluetooth 5.0 and WiFi functionality supporting DLNA and Airplay protocols and being able to be connected to a NAS.
The Shanling MCD 1.3 houses a high-performance dual-core Ingenic X2000 processor. This chip is the first based on XBurst2 technology, which not only improves computing power, but also enables the device to start up quickly. This processor is combined with a Philips SAA7824 decoder and a Sanyo DA11 playback head, offering excellent playback performance and high-quality sound reproduction.
The Shanling MCD 1.3 is equipped with the AKM AK4499EX (DAC) and AK4191EQ (digital filter) chip combo. This enables it to support high-resolution streams up to PCM 32bit 768kHz, native DSD up to DSD512 and MQA/MQA-CD, with a distortion rate of less than 0.0005% (-122dB).
The USB interface of Shanling MCD 1.3 is entrusted to an XMOS XU316 chip, providing transparent sound reproduction and support for high-resolution audio streams up to PCM 32bit 768kHz and DSD512.
The Shanling MCD1.3 incorporates three digital outputs, allowing it to be paired with a higher-performance DAC if required. The I2S output via HDMI is optimised using an FPGA and is directly compatible with 10 different HDMI I2S pinouts. Optical and coaxial outputs are also available for easy connection to a DAC.
The Shanling MCD1.3 also incorporates different pre-amplification stages depending on the output, allowing the most appropriate amplification of the signal in all circumstances. The line output is powered by two soft-sounding OPA MUSES8920s, while the headphone output is powered by a more powerful, harder-sounding OPA TPA6120, capable of driving the vast majority of headphones.
Product type | CD player DAC |
Inputs | CD 1x USB-B 1x Coaxial 1x Optical Toslink 1x USB-A (USB Host) Bluetooth Wi-Fi |
Outputs | 1x Single-ended RCA stereo 1x Balanced XLR stereo 1x I2S via HDMI 1x Coaxial 1x Optical Toslink 1x Jack 6.35mm headphone output |
DAC chip | AKM AK4499EX + AK4191EQ |
USB interface | XMOS XU316 |
OPA | 2xMUSES8920 1xTPA6120 |
Supported Bluetooth codecs | SBC, ACC, aptX, aptX HD, LDAC |
Supported sampling rates | USB : PCM up to 32bit 768kHz / DSD up to DSD512 Coaxial and Optical : PCM up to 24bit 192kHz |
RCA OUTPUT MEASUREMENT | |
Output level | 2.5Vrms |
Frequency response | 20Hz-40kHz (-0.1dB) |
Total harmonic distortion more noise (THD+N) | 0.0005% |
Dynamic range | 119dB |
Signal-to-noise ratio (SNR) | 119dB |
XLR OUTPUT MEASUREMENTs | |
Output level | 5Vrms |
Dynamic range | 122dB |
Signal-to-noise ratio (SNR) | 122dB |
6.35MM JACK HEADPHONE OUTPUT MEASUREMENTS | |
Output level | Low gain : 21.5mW @ 32Ω Medium gain : 203mW @ 32Ω High gain : 1120mW @ 32Ω 153mW @ 300Ω |
Total harmonic distortion more noise (THD+N) | 0.001% |
Channel separation | 75dB@32Ω |
Dynamic range | 118dB |
Signal-to-noise ratio (SNR) | 118dB |
Output impedance | 4.7Ω |
Dimensions | 280 x 280 x 96mm |
Weight | 5.7kg |
Color | Black |
Package | 1x Shanling MCD 1.3 CD/SACD Player DAC 1x Power cable 1x Remote Control 1x USB-A to USB-B cable 1.5m |
Input | SPDIF |
Input | Bluetooth |
Input | CD |
Input | USB |
Input | Optical |
Input | WiFi |
Output | I2S LVDS via HDMI |
Output | Coaxial SPDIF |
Output | RCA |
Output | XLR |
Output | Jack 6.35mm |
Output | Optical Toslink |
DAC / ADC Chip | AK4499EX |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Max sampling rate | MQA |
Color | Black |
Networking | Yes |
Remote Control | No |
