Excellent Lecteur CD ou transport.
C'est mon deuxième appareil, celui-ci en couleur alu est magnifique.
Merci Audiophonics pour l'envoi exprès avec un super emballage.
CD Player Sanyo HD850 ES9219C Bluetooth 5.0 LDAC 32bit 384kHz DSD256 Silver
The Shanling EC3 is a CD player that stands out at first glance thanks to its compact size with measurements of only 188mm wide by 255mm deep and 68mm high. A certain compactness and yet incredible performances thanks to an intelligent and particularly careful design. Thanks to its know-how, Shanling offers a player that will allow you to enjoy your CDs in the best conditions.
The EC3 is based on the excellent Sanyo HD850 drive mechanism, supported by an Ingenic X2000 microprocessor. High quality components, widely acclaimed by audiophiles and music lovers, ensuring a very good CD playback quality while offering an important longevity.
The front panel of the Shanling EC3 features a beautiful circular color display. It displays in real time the playback information, the selected source or the volume level. Moreover, if the file being played comes from a USB stick and the album cover is available, it will be displayed. The screen also allows access to all the player's settings.
The Shanling E3 can also be controlled remotely from a smartphone via the free Shanling Controller mobile app. In addition, the player has a USB-A port on the front panel, allowing you to connect a storage device such as a USB flash drive or an external hard drive.
In addition to playing CDs and files from a USB device, the EC3 provides Bluetooth 5.0 reception capability. This means you can stream your music remotely, for example directly from your smartphone or tablet. The support of the LDAC transmission codec also allows you to enjoy excellent sound quality wirelessly.
The Shanling EC3 CD player is equipped with a particularly complete output connector system. We find stereo RCA for the analog part and optical Toslink and coaxial for the digital section. This connectic is completed by an amplified headphone output on a Jack 3.5mm connector on the front.
Product type | CD Player |
Inputs | CD / CD-R / CD-RW Bluetooth 5.0 1* USB-A |
Outputs | 1* Stereo RCA 1* Optical Toslink 1* Coaxial |
DAC chip | ESS ES9219C |
Frequency response | 20Hz - 40kHz |
SNR | 117dB |
Supported Bluetooth codecs | AAC, SBC, LDAC |
Headphone output power | 70mW @ 8Ω |
Power supply | 220 - 240V 50Hz (Power cable included) |
Dimensions (W*D*H) | 180*255*68mm |
Weight | 2.4kg |
Housing material | Aluminum |
Color | Silver |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Noel C.
