SHANLING ET3 CD Player Philips SAA7824 Sanyo HD850 WiFi DLNA AirPlay Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 MQA Black
The Shanling ET3 is a complete, powerful CD player with a modern design and excellent sound performance. Versatile, it offers full connectors and wireless connectivity, enabling it to be integrated into many audio systems, providing a high-quality source. It can even be used as a file player and NAS, thanks to a USB input for storage devices, combined with Bluetooth and WiFi capabilities.
4.9 / 5
Reference : 17955
699,00 €tax incl.
582,50 € tax excl.
Shanling ET3
Shanling ET3 Lecteur CD Philips SAA7824 Sanyo HD850 WiFi DLNA AirPlay Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 MQA Noir
The ET3 is an alternative to the brand's EC3, with a more focused use, centered on its CD player and digital transport functions, offering superior signal processing quality. Thanks to its numerous digital outputs, but above all its USB and I2S outputs, it is capable of transmitting high-resolution streams to an external device (DAC, amplifier...).
A particularly powerful design
The Shanling ET3 houses a high-performance dual-core Ingenic X2000 processor. This is the first chip based on XBurst2 technology, which not only enhances computing power but also enables rapid device start-up. This processor is combined with a CT7302CL upscaling chip, a Philips SAA7824 decoder and a Sanyo HD850 optical drive, delivering excellent playback performance and high-quality sound reproduction.
MQA / MQA-CD Decoder
The Shanling ET3 incorporates an MQA (Master Quality Authenticated) decoder, enabling it to read this type of file, offering sound reproduction as close as possible to the original recording. A rarer feature, it is also capable of reading and decoding the MQA-CD format.
MQA indicator:
  • MQA: Green
  • MQA Studio: Blue
  • MQA Rendering: Magenta
Complete connectors and connectivity
The ET3 is equipped with a particularly complete range of digital output connectors. The rear panel features USB-A, I2S on HDMI port, AES/EBU, optical and coaxial outputs. This connectivity is complemented by wireless connectivity, with an antenna on the rear of the device ensuring stable transmission.
1MQA indicator
2Screen
3Multifunction button
4USB input (USB Host)
5USB output
6I2S output via HDMI
7AES/EBU output
8Optical output
9Coaxial output
10BT / WiFi antenna
11Power input
12Power ON/OFF switch
Wireless connectivity & Control app
The Shanling ET3 also benefits from wireless connectivity, incorporating a Bluetooth 5.0 chip supporting high-resolution aptX, aptX HD and LDAC codecs, as well as dual-band WiFi supporting DLNA and AirPlay protocols. This makes it possible to control and stream music remotely, from a smartphone for example, using the free Eddict Player mobile application.
Screen
The front of the Shanling ET3 features an attractive circular IPS display. Stylish and practical, it displays playback information, selected source and volume level in real time. What's more, if the file being played comes from a USB stick and the album cover is available, it will be displayed. The screen also provides access to all player parameters.
Product typeCD Player
InputsCD Player
1* USB-A (USB Host)
WiFi
Bluetooth
Outputs1* USB-A (USB Audio)
1* I2S via HDMI
1* AES/EBU
1* Optical Toslink
1* Coaxial
WiFi
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
WiFiDual-band 2.4/5G
Supported WiFi protocolsDLNA
AirPlay
Decoder / Servo systemPhilips SAA7824
Optical driveSanyo HD850
Upsampling chipCT7302CL
CompatibilityCD
CD-R
CD-RW
Supported sampling ratesUSB / I2S : PCM up to 32bit 768kHz, Native DSD up to DSD512
Coaxial / Optical / AES : PCM up to 24bit 192kHz, DoP64
CPUIngenic X2000
ScreenIPS, 320*290px
Audio formats supported via USB deviceISO, DXD, APE, FLAC, WAV, AIFF, ALF, DTS, MP3, WMA, AAC, OGG, ALAC, MP2, M4A, AC3, M3U, M3U8, OPUS, DSD (ISO, DSF, DFF)
MQA support
MQA-CD support
Supply voltage220-240VAC
Consumption15W
Dimensions188*255*68mm
Weight~2.5kg
Housing materialAluminum
Package1* Shanling ET3
1* Remote control
1* Power cable
9 reviews
presque parfait
Les plus:
Le chargement et le palet presseur
Le silence total de fonctionnement et plutôt rapide
Le look et la taille compacte
La connectique très complète
Le surechantillonage fonctionne très bien
Les moins:
Une télécommande vraiment pas bonne lente,ultra directive
L impossibilité d accéder directement a une plage du cd
Si vous aviez l idée de l utiliser comme un mini streamer vous pouvez oublier. L appli est très mauvaise.
This review has been posted for SHANLING ET3 CD Player Philips SAA7824 Sanyo HD850 WiFi DLNA AirPlay Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 MQA Black
Highly recommended
I’m very happy with the Shanling ET3. The build quality is outstanding — solid, elegant, and clearly made with care. It offers plenty of connectivity options (USB, I²S, coaxial, optical, AES/EBU), making it easy to integrate into any setup.
I haven’t used the Bluetooth or streaming functions yet, so I can’t speak to those features. However, as a CD transport, it has already improved the sound in my system compared to my previous CD player — more detail, clarity, and presence.
I also really appreciate the top-loading design. It feels more reliable than traditional tray mechanisms and even reminds me a bit of the ritual of placing a vinyl record — a nice touch for music lovers.
If you’re looking for a reliable, great-sounding CD transport with modern features and excellent construction, I highly recommend the ET3.
ET3 and Oversampling advantage ?
Has anyone taken an audio CD (16 bit /44,1 KHz) and experimented with raising the oversampling Frequency at playback over I2S outlet ? Theoretically, oversampling works as a filter and it could impact on experienced sound audio quality even if bitrate are the same. Share your experience with us here, please !
Nice sound!
Very good device. I am connecting it through Coax, Toshlink and USB to my old AudioGD DAC19MK3 and it sounds beautiful. Unfortunately I cannot test the I2S yet, but I might modify my DAC to accept it. The service and experience from audiophonics is one of the best I had, very fast shipping and very good packaging! Thank you!!
Superbe!!!
Ce drive CD est tout simplement magnifique & dans tout les sens du terme! La qualité de fabrication est très sérieuse, cela ce ressent au poids de l'appareil par rapport à sa taille....
Il est couplé en câble toslink au Bleusound Node 130 utilisé sur un ampli REGA BRIO (2017) équipé d'enceintes colonne HIGHLAND AUDIO ORAN 4305. Et très sincèrement bluffé par le rendu sonore de ce lecteur, rien à envier à mon ex ATOLL MD100!!!
La prise en n'est pas évidente surtout que le mode d'emploi est dans une langue que je pige pas (l'anglais)! Mais j'ai quand même réussi, après quelques heures de bataille à exploiter quelques fonctions: le Bluethooth franchement excellent rendu, appairage facile; AIRPLAY via Mac génial la pochette de l'album s'affiche sur l'écran!! J'adore! Bon parfois quand ont change d'album le changement de pochette peu prendre un peu de retard..... Il y la possibilité de se connecter à Tidal, pas encore essayé .... je verrais ça si je valide l'abonnement. Concernant l'application pas mal... mais certaines fonctions me paraisse pas assez aboutie, dont une réservée à la chine. Pour ce qui est du MQA pas encore l'utilité, ont verra ce que ça vaut le jour où....
Bref ce lecteur est une petite merveille!!! Il est beau, prend peu de place et procure un son splendide !!!!
Merci à AUDIOPHONICS pour l'expédition super rapide et son emballage sérieux, car le carton avait pris des coups & heureusement que SHANLING aussi n'hésite pas à mettre un double carton!!
p.s: Attention au disc cover il est en verre (épais quand même), pas besoin de vous expliquer plus..... Donc petite question à AUDIOPHONICS: Est-il possible d'en avoir de rechange???
The Shanling ET3 is a complete, powerful CD player with a modern design and excellent sound performance. Versatile, it offers full connectors and...
