SHANLING SCD1.3 CD SACD Player DAC AKM4499EX + AKM4191EQ Black
With its SCD1.3, Shanling unveils a high-end SACD CD player featuring the AKM AK4499EX + AK4191EQ DAC chip combo, XMOS XU316 USB interface and TPA6120 headphone amplification. Multifunctional, the Shanling SCD1.3 offers many other possibilities in terms of Hi-Fi configuration.
By buying this product you get 119 loyalty points
Reference : 18758
1 199,00 €tax incl.
999,17 € tax excl.
Shipping date: 02-04-2026.
Photo of shanling SCD1.3
With its SCD1.3, Shanling unveils a high-end SACD CD player featuring the AKM AK4499EX + AK4191EQ DAC chip combo, XMOS XU316 USB interface and TPA6120 headphone amplification. Multifunctional, the Shanling SCD1.3 offers many other possibilities in terms of Hi-Fi configuration. In fact, it features Bluetooth functionality, a USB-A U-Disk port and supports DLNA and AirPlay for network connection. These additional features make it easy to integrate into any sound system. Moreover, it features numerous inputs and outputs. Inputs include USB-B, coaxial SPDIF and Toslink optical, while digital outputs include I2S via HDMI, coaxial SPDIF and Toslink optical. Two analog outputs are also available: an analog RCA output and a balanced XLR output.
Shanling SCD1.3: MediaTek ME1389EE playback system and Sanyo HD870 laser
The SCD1.3's CD playback system enables it to fully exploit the capabilities of both high-resolution SACD and standard CD discs. It is equipped with a MediaTek ME1389EE drive and a Sanyo HD870 laser head offering excellent performance.
Photo du système de lecture CD SACD du Shanlink SCD1.3
Shanling SCD1.3: AKM AK4499EX and AK4191EQ chip combo
The SCD1.3's AKM chip combo enables it to render highly detailed sound over a wide soundstage, while retaining Shanling's soft, warm sound signature. In addition, a high-precision MUSES8902 volume controller enables the SCD1.3 to be directly associated with a power amplifier or active loudspeakers.
Shanling SCD1.3: XMOS XU316 USB interface
If you want higher-resolution streams than SACD format, you can always use the USB-B input and the XMOS XU316 USB interface, which supports up to PCM 32 bit 768 kHz and DSD512.
Shanling SCD1.3: 3 digital outputs
The Shanling SCD1.3 incorporates three digital outputs, allowing it to be paired with a more powerful DAC if desired. The I2S output via HDMI is FGPA-optimized and directly compatible with 10 different HDMI I2S pinouts. The SPDIF and optical coaxial outputs also enable simplified connection to a DAC. SACD disc playback will be converted to 88.2kHz on its digital outputs.
Shanling SCD1.3 compatible HDMI I2S brochures
SHANLING SCD1.3: MTouch touchscreen and Bluetooth functionality
The SCD1.3's 5" touchscreen uses Shanling's Mtouch technology and an Ingenic X2000 processor for smooth, precise touch navigation. It's also thanks to Shanling's Mtouch technology that the SCD1.3 benefits from Bluetooth 5.0 functionality, Wi-Fi connectivity and support for DLNA, AirPlay and NAS protocols. Bluetooth 5.0 enables the SC1.3 to support high-resolution Bluetooth codecs such as SBC, AAC, aptX HD and LDAC.
Front view of Shanling SCD1.3
Shanling SCD1.3 overview
Shanling SCD1.3 connection diagram
1CD / SACD player
25" touch screen
3Switch CD / SACD
4Standby / volume control
5Stop / Eject
6Play / pause
7Previous
8Next
9Remote control signal reception
106.35mm headphone output
11USB-A port (U-Disk)
12Digital outputs: I2S HDMI / SPDIF Coaxial / Optical Toslink
13Analog outputs: stereo RCA / balanced stereo XLR
14Digital inputs: USB-B / SPDIF coaxial / Optical Toslink
15Antenne Bluetooth / WiFi
16IEC power supply
Product typeCD SACD player / DAC
InputsCD/SACD
1x USB-B
1x SPDIF coaxial
1x Optical Toslink
1x USB-A (U-disk)
Bluetooth
Wi-Fi
Outputs1x RCA stereo output
1x XLR balanced stereo output
1x I2S output via HDMI
1x SPDIF coaxial output
1x Toslink optical output
1x 6.35mm headphone output
DAC chipAKM AK4499EX + AK4191EQ
USB interfaceXMOS XU316
Headphone amplifier chipTPA6120
Supported Bluetooth codecsSBC, ACC, aptX, aptX HD, LDAC
Supported sampling ratesSACD : 88.2kHz
USB : 32bit 768kHz DSD512
RCA OUTPUT MEASUREMENT
Output level2.5Vrms
Frequency response20Hz-40kHz (-0.1dB)
THD+N0.0005%
Dynamic range119dB
SNR119dB
XLR OUTPUT MEASUREMENT
Niveau de sortie5Vrms
Output level20Hz-40kHz (-0.1dB)
THD+N0.0005%
Dynamic range122dB
SNR122dB
6.35MM jack HEADPHONE OUTPUT MEASUREMENTS
Output power1.1 W @ 32Ω
153mW @ 300Ω
THD+N0.001%
Channel separation75dB@32Ω
Dynamic range122dB
SNR122dB
Output impedance4.7Ω
Dimensions280 x 280 x 96mm
Weight6.6kg
Package1x Shanling SCD1.3 CD/SACD Player DAC
1x Remote control
1x Power cable
Not everething is 5 stars, but the sound deffenetly is!
This review has been posted for SHANLING SCD1.3 CD SACD Player DAC AKM4499EX + AKM4191EQ Black
With its SCD1.3, Shanling unveils a high-end SACD CD player featuring the AKM AK4499EX + AK4191EQ DAC chip combo, XMOS XU316 USB interface and...
