SMSL PL200T CD Transport
The SMSL PL200T is a high-performance, versatile CD transport. It's based primarily on a P.A.S.S. (Precision Access Servo System) playback system developed by SMSL, plus an XMOS USB interface on a USB-C connector. The playback system natively supports MQA CD and USB interface up to PCM 32bit 768kHz, DSD512 and MQA.
By buying this product you get 54 loyalty points
Reference : 20546
549,00 €tax incl.
457,50 € tax excl.
Shipping date: 04-07-2025.
SMSL PL200T CD Transport USB XMOS 32bit 768kHz DSD512 MQA-CD
Photo of SMSL PL200T
The SMSL PL200T is a high-performance, versatile CD transport. It's based primarily on a P.A.S.S. (Precision Access Servo System) playback system developed by SMSL, plus an XMOS USB interface on a USB-C connector. The playback system natively supports MQA CD and USB interface up to PCM 32bit 768kHz, DSD512 and MQA. The design features a large IPS screen and piano keyboard buttons, for a perfect blend of modern and retro looks. Connectivity includes a 10MHz clock input and Toslink optical, SPDIF coaxial and AES/EBU outputs.
Please note that the PL200T has no DAC and no analog output. That's why it's a CD Transport. It has digital outputs only.
SMSL PL200T: P.A.S.S (Precision Access Servo System) playback system
SMSL has developed its own CD playback system providing audiophile levels of dynamic response and playback stability. In addition, an anti-vibration system and shock absorbers give this CD transport a high level of reliability.
The SMSL PL200T P.A.S.S reading system
SMSL PL200T clock input
SMSL PL200T: 10MHz external clock input
The PL200T CD transport features a 10MHz external clock input compatible with 50 or 75 ohm impedance. It supports both standard and atomic external clocks.
SMSL PL200T: USB XMOS interface
The SMSL PL200T's USB-C input supports high-resolution sampling rates up to PCM 32bit 768kHz, DSD512 and MQA via an XMOS interface.
SMSL PL200T USB XMOS interface
SMSL PL200T: between modernity and retro look
The PL200 features piano keyboard keys for a retro look, and a large tempered-glass IPS screen with a simplistic, modern interface. On the top of the PL200, an innovative cover covers the CD playback system.
The aesthetics of the SMSL PL200T
SMSL PL200T: 3 power supply options
The SMSL PL200T CD transport can be powered via USB-C, DC jack or a mains power cord for added flexibility.
Please note that if you use the USB or DC jack power supply, it must be 5V (+/-0.3V), otherwise the device may be damaged. Also, be careful not to use the DC jack power supply and the mains power supply at the same time.
SMSL PL200T power supply
SMSL PL200T overview
1CD player cover
2CD holder
3Disk slot
4Next
5Previous
6Stop
7Play/Pause
8Multifunction button
9IR receiver
10LED indicator
11Display
12I2S output via HDMI
13AES/EBU output
14Coaxial output
15Toslink optical output
16External clock input
17Power supply via DC 5V 1A jack
18USB-C input/Power supply 5V 1A
19Mains supply 100-240V AC
Product typeCD transport
InputsCD
1x USB-C
Outputs1x I2S via HDMI
1x Coaxial
1x Optical Toslink
1x AES/EBU
USB transmissionAsynchronous
USB compatibilityWindows 7 / 8 / 8.1 / 10 / 11 (with driver)
MAC OSX 10.6 et +
Linux
Android, IOS
Supported output sample ratesI2S: PCM up to 32bit 768kHz, Native DSD up to DSD512
Optical Toslink, Coaxial, AES/EBU: PCM up to 24bit 192kHz, MQA (8X, 384kHz converts to 192kHz)
External clockFrequency: 44.1kHz ou 10Mhz
Impedance: 50 ohm ou 75 ohm
Waveform: square (TTL level) or sine (level >1Vrms)
Power supplyMains 100-240V AC
DC jack 5V 1A
USB-C 5V 1A
Power consumption15W
Standby: 0.5W
Dimensions200 x 42 x 175mm
Weight1.62kg
ColorSilver
Package1x SMSL PL200T
1x Remote control
1x Power supply cable
The SMSL PL200T is a high-performance, versatile CD transport. It's based primarily on a P.A.S.S. (Precision Access Servo System) playback...
