TI LM4562NA/NOPB Dual Operational Amplifier OPA DIP8 (Unit)
The Texas Instruments LM4562NA/NOPB is a high-performance 2-channel operational amplifier (OPA) integrated in a PDIP8 enclosure. This ultra low distortion, low noise and high speed AOP is optimized for high fidelity audio applications.
4.7 / 5
Reference : 14420
8,90 €tax incl.
7,42 € tax excl.
Shipping date: 06-10-2026.
TI LM4562NA/NOPB
TI LM4562NA/NOPB Amplificateur Opérationnel AOP Double DIP8 (Unité)
The Texas Instruments LM4562NA/NOPB is a high-performance 2-channel operational amplifier (OPA) integrated in a PDIP8 enclosure. This ultra low distortion, low noise and high speed AOP is optimized for high fidelity audio applications. By combining state-of-the-art technology and modern design, the LM4562 offers superior audio signal amplification for outstanding audio performance. It combines extremely low voltage noise density (2.7nV/√Hz) with low THD+N (0.00003%) for use in demanding audio applications. To cope with the heaviest loads without compromise, the LM4562 has a slew rate of ±20V/µs and an output current capability of ±26mA. This AOP also features a 120dB CMRR and 120dB PSRR, giving it excellent DC performance.
The LM4562 also benefits from a wide supply voltage range, from ±2.5V to ±17V. This stable unit gain AOP achieves outstanding AC performance while generating complex loads with values up to 100pF.
Product typeOperational Amplifier (AOP)
Number of channel2
Supply voltage range±2.5V ±17V
Case/Connection typePDIP8
Output current26mA
Input noise density2.7nV/√Hz @ 1kHz
THD+N0.00003%
Slew rate±20V/µs
Load impedance30kΩ
CMRR - Common mode rejection rate110dB à 120dB
Gain bandwidth55MHz
Open loop gain140dB
Min/Max operating temperature-40°C / 85°C
OPA TypeDual
6 reviews
RAS
Livraison rapide et emballage correcte, pas encore essaye.
Petite précision ce sont de National semiconductor
This review has been posted for TI LM4562NA/NOPB Dual Operational Amplifier OPA DIP8 (Unit)
Moyen
Moyen aussi sur mon Fosi V3.
Chez moi, l'OPA2134 et de bons NE5532P sonnent plus "réalistiquement" et en effet plus ouvert aussi.
Bref, un peu étriqué si vous écoutez du Jazz et aimé entendre les sonorités chaleureuses des intruments à vent.
Amha, bien évidemment.
très bon rapport qualité prix
utilisé dans un fois v3, cet app est assez surprenant. Le son est très bon pour son prix. Les graves sont bien tenus, les aigus corrects sans trop piquer. Il y a surtout un dynamique de fou, à la fois très agréable et peut être parfois un peu fatiguant.
Bref, pour le prix, ça vaut vraiment le coup de les essayer. Je recommande.
Remplacement AOP CONSTRUCTEUR
J'ai procédé à l'échange des condensateurs audio ELNA BLEU (remplacé par des PANASONIC FC 50V 4,7 uf ) sur le circuit du Aiyiama A07 MAX , j'ai changé l'AOP d'origine par celui-ci,la sonorité me convient mieux , il fonctionne encore mieux avec le LME 49860, pour ma part ,c'est musical ,aéré et pas fatiguant ,un excellent TPA 3255 accessible qui mérite du cablage et des composants de qualité , que du bonheur.
EXCELLENT UPGRADE
Pour un prix très modique ce LM4562 fonctionne à merveille sur l'amplificateur Aiyima A07. Belle dynamique, définition excellente et image stereo superbe en largeur comme en profondeur. Je le
préfère même à mon autre Aiyima A07 équipé de deux AOP Sparkos
 (3)
The Texas Instruments LM4562NA/NOPB is a high-performance 2-channel operational amplifier (OPA) integrated in a PDIP8 enclosure. This ultra low...
