Ultra Low Phase Noise Clock 49.152MHz 3.3V 25ppm
The Crystek CCHD-957 series of oscillators has been developed specifically for high definition audio applications. The extremely low phase noise of -100dBc/Hz (10Hz offset) and the noise threshold of -169dBc/Hz allow for accurate and clear audio reproduction.
This model has a frequency of 49.152MHz and a stability of 25ppm.
The above picture shows a crystek CCHD mounted on a FIFOPI from IAN CANADA thanks to IAN CANADA CCHD957 supports.
Product type | Clock oscillator |
Frequency | 49.152MHz |
Stability | 25ppm |
Load capacitance | 15pF |
Operating supply voltage | 3.3V |
Output format | HCMOS |
Mounting type | SMD / SMT |
Operating temperature | 0°C / +70°C |
Dimensions | 14.2 x 9.14 x 5.3mm |
RoHS |
