These high-performance capacitors use silk fibers instead of traditional paper as terminals insulation.
The flexibility of the silk fiber is an ideal material for use in the field of precision audio. It reduces the stiffness of the peaks in the medium and high frequencies while enhancing massive and clear low frequencies.
The legs are in OFC copper for extremely low distortion.
Attention this is an electrolytic capacitor, so polarized: the positive pole is indicated by the longer leg.
Type | Aluminum electrolytic capacitor |
Capacitance | 330μf |
VCC | 35 VDC |
Tolerance | 20% |
Temperature | -40 + 85 ° C |
Diameter (body): | 16mm |
Length (body) | 25mm |
Connectors spacing | 7.5mm |
Connector diameter | 0.6mm |
Connector materials | OFC |
Polarized | Yes |
Connector length | Positive: 20mm Negative: 15mm |
Tolerance (%) | 20 |
Capacitor capacitance (µF) | 330 |
Rated voltage (V) | 35.0 |
Capacitor type | Electrolytic capacitor |
Capacitor format | Radial |
