ARYLIC A100 Connected Amplifier
The Arylic A100 is a connected amplifier designed to offer exceptional power and versatility. It delivers up to 2x100W under 4Ω in stereo or 200W under 2Ω in mono, integrating easily into various Hi-Fi systems thanks to its extensive connectivity.
By buying this product you get 27 loyalty points
Reference : 20250
279,00 €tax incl.
232,50 € tax excl.
Arylic A100 Connected Amplifier Stereo WiFi Bluetooth 2x100W 4Ω
Arylic A100: Front view
With its RJ45 Ethernet port, Wi-Fi connection and Bluetooth 5.0, the A100 ensures seamless integration into your installations. Its compatibility with a wide range of network protocols and streaming services makes it particularly flexible and capable of meeting the needs of demanding music lovers.
Arylic A100: Streaming service / Protocols / FM Radio
The A100's main asset is its connectivity. It supports Airplay, Spotify Connect, UPnP, DLNA and Qplay protocols. What's more, it's also compatible with a host of streaming services such as Spotify, Tidal, Amazon Music, Qobuz, Napster and many others.
Arylic A100: Control application image on compatible service logo background
Arylic A100 :2x 100W power output
Arylic A100: 1x200W / 2x100W amplification
The A100 offers 2x100W amplification at 4Ω. However, you can also transform this amplifier into a powerful 200W mono block thanks to a switch on the rear panel.
Arylic A100: Multiroom and control application
The A100 can be used with the Go Control app available on Android and iOS. This lets you remotely control your music playback, as well as setting up a multiroom system. The control app also features a 10-band equalizer, so you can customize your listening experience to suit your preferences.
Arylic A100 : Multiroom
Platine Vinyle
Arylic A100: Phono amp
Arylic has also equipped its A100 connected amplifier with a phono input so you can enjoy your vinyl collection. This phono input is compatible with turntables with MC and MM cells.
Product typeConnected amplifier
Inputs1x Stereo RCA
1x Phono MM/MC input
1x Coaxial
1x Optical Toslink
1x RJ45
2x USB-A
2x Mic input
WiFi
Bluetooth
FM Radio
Outputs2x Speaker terminals
Output powerStereo: 2x100W @ 4Ω / 2x60W @ 8Ω
Mono: 1x200W @ 2Ω
Speaker impedance4Ω-8Ω
THD+N0.03%
SNR91dB
Transmission protocolsSpotify Connect
AirPlay
UPnP
DLNA
Qplay
Compatible streaming servicesSpotify
Tidal
Qobuz
Pandora
Napster
AmazonMusic
iHeartRadio
BBCRadio
TuneIn
RadioParadise
vTuner
QQmusic
WiFiIEEE802.11 b/g/n 2.4G
Ethernet10/100M RJ45
Bluetooth version5.0
Supply voltage115-230V AC 50/60Hz
Dimensions248 x 215 x 64mm
Weight3.9kg
Package1x Arylic A100
1x RCA cable
1x Power cable
2x Antennas (BT/WiFi)
1x FM antenna
InputRJ45
InputWiFi
InputPhono
InputFM
InputJack 3.5mm
OutputSpeaker terminal
Channel2 (Stereo)
Channel1 (Mono)
ClassFDA
Amplifier chipN/A
Power (W)200.0
Power (W)100.0
Download
ARYLIC A100 Connected Amplifier Stereo WiFi Bluetooth 2x100W 4Ω
The Arylic A100 is a connected amplifier designed to offer exceptional power and versatility. It delivers up to 2x100W under 4Ω in stereo...
