AUDIOPHONICS Digipi+AES TOSLINK TCXO Digital Interface AES/EBU for Raspberry Pi
This interface extends the capabilities of your Raspberry Pi by adding a range of digital audio output. It includes an optical output (SPDIF) with a connector already mounted, a coaxial output (SPDIF, this one has to be mounted with an RCA connector - not included) and an AES / EBU XLR already mounted with a Neutrik connector. Thanks to DigiPï + interface and a software solution (Moode for example) your Raspberry Pi can become a true high-fidelity network drive.
4.9 / 5
Reference : 13316
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 22-08-2025.
Audiophonics DigiPi +
Digital interface for Raspberry Pi AES / EBU & Optical
Interface digipi plus
Warning: this interface needs a Raspberry Pi 5Raspberry Pi 4 or Raspberry Pi 3B / 3B + to run. This piece is not provided.
The interconnection between your Raspberry Pi and digital interface is directly I2S-based for increased performance and respect of the audio signal. This type of protocol limits indeed the need for successive signal conversions and manages high sampling rate (up to 192kHz).
The DigiPi + is compatible with multiple softwares (PiCore, Volumio, Moode...etc)  thanks to HiFiBerry Digi Driver. Those are free xtremely comprehensive software solutions based Raspberry Pi with many features to enrich playback and potentiate the rest of your audio system. This software environment has been developped especially for this type of hardware and each part will be able to function to the best of its potential.
To operate correctly, the DigiPi+ needs to use the HiFiBerry Digi and Digi+ driver.
DigiPi+ Driver
AES / EBU and SPDIF on Raspberry Pi
This digital interface is one of the few on the SBC market to offer an AES / EBU XLR output. This greatly opens the possibilities of integration regarding solutions based on RPI. It is a good way to associate your player / mediacenter with very advanced devices favoring AES / EBU standard.
Naturally, the DigiPi + has traditional digital connectors rigor, such as a SPDIF Optical connector.
Il est également possible d'ajouter une connectique coaxiale en soudant un connecteur RCA aux pastilles indiquées dans le schéma ci-dessous.
XLR AES EBU Raspberry PI SBC
0.5ppm TCXO electronic clock
WM8804G & Clock TCXO Interface
The interface works with a digital chip WM8804G. It is connected to a Raspberry Pi via I2S GPIO and accuracy of the digital stream is provided by a 27MHz TCXO clock Audiophonics 0.5ppm.
With this configuration, the interface is capable of handling sample rates up to 24bit / 192kHz with a distortion rate and minimal jitter (50ps).
A power supply that suits your needs
To give you the whole attitude to make the best decision in terms of power supply, DigiPi + interface can comply with different power configuration.
We can therefore supply the interface and the Raspberry Pi via Jack 5.5x2.5mm DC input. The opposite is equally feasible and can interface will be powered by the Raspberry Pi via GPIO.
A third configuration is to use two alimenations simultaneously. Each element (DigiPi + and Raspberry Pi) is powered independently, which considerably limits the food-related interference.
digiPi interface Power
DigiPi interface + power jumper
AUDIOPHONICS Digipi+AES Interface Digitale pour Raspberry Pi AES/EBU TOSLINK TCXO
Control plugin for new features
New features can be added to the DIGIPI+ with the mood player :
  • Play / Pause
  • Vol+ / Vol-
  • Previous / Next
Connect the buttons to the Raspberry Pi as shown below to install these new features:
  • GND is connected to the black point of the 40Pin interface of the Raspberry Pi
  • Volume Down: Connect to pin 2 of the Raspberry Pi 40Pin interface
  • Previous song : Connect to pin 3 of Raspberry Pi 40Pin interface
  • Play/Pause: Connect to pin 4 of the Raspberry Pi 40Pin interface
  • Volume plus: Connect to pin 5 of the Raspberry Pi 40Pin interface
  • Next song: Connect to pin 6 of the Raspberry Pi 40Pin interface
Enable Play/PauseOn
GPIO Pin4
Enable Vol+On
GPIO Pin5
Enable Vol -On
GPIO Pin2
Enable PreviousOn
GPIO Pin2
Enable NextOn
GPIO Pin6
Enable Shutdown Off
Technical Characteristics
specifications
TypeDigital interface
ChipWM8804G
InputI2S via GPIO
OutputCoaxial (to be connected)
XLR AES / EBU
Optical
Power Supply5VDC via DC Jack 5.5 / 2.5mm or via GPIO
Max audio rate192kHz 24bit
Supported softwareVolumio
moode
Dimensions65 x 56 x 36 mm
Weight44g
Parts supplied
DigiPi Map +x1
spacers M2.5x4
Phillips screw M2.5x8
InputI2S
OutputCoaxial SPDIF
OutputOptical Toslink
DAC / ADC ChipWM8804
Max sampling rate192kHz
9 reviews
Works well, but room for improvement
I have a couple of these running 24x7 in a modified HighPi Pro case which works fine.
These devices don't work well during a "brown-out" condition and sometimes don't come up properly unless you wait a good few minutes between boots.
This behaviour seems to be due to the way this board resets - it just has a 100k pull-up resistor which is not sufficient. I intend on trying a MCP100 Supervisory Controller to mitigate this but could also use a pin to a spare GPIO port to reset for when this condition happens. I would love to see a future revision of this board that has a proper reset circuit.
Extra points if a dedicated steel case with heatsinks was available.
This review has been posted for AUDIOPHONICS Digipi+AES TOSLINK TCXO Digital Interface AES/EBU for Raspberry Pi
Hey, it works!
Perfect for a headless Plexamp pi feeding a Genelec SAM system! :-)
The missing star is for lack of documentation and a little for lack of a suitable case. Stole the idea to use a low profile passive heatsink case from Geekworm and cannibalize their acrylic plate "case" for a hood and bits, Works, but the hat still remains pretty exposed.
What's actually needed to get it working: 'dtoverlay=hifiberry-digi'.
Can't figure out (with enough certainty, not going to guess) where/how to wire a coax S/PDIF output; Really should be documented here.
AES / EBU HAT RPI
I paired this with a Pi4b streamer running Moode in a Argon M2 case with a Funk AES cable connected to a Gustard X18. Listening between USB2 and USB3 BT LDAC with very good cables the AES was a quantum leap. Sound stage a meter wider, bass clean and forceful, mids just sweet, highs crystal clear, high hats some I hadn't heard on tracks I'd listen to 100 times before.No hint of digital sound or tinny sounding, an absolute upgrade and at an excellent price. For the M2 case and HAT I needed 2 PSUs but it was all set up on Moode in a few minutes.Top product, thanks Audiophonics for the great service as well.
Really good product
I work with professional Broadcast equipment with AES/EBU input and with this product I now have a small battery operated media player with AES/EBU output. Very practical to have for testing and repairing equipment or just listening to music when You are working :-)
works perfect
On a RPi4 with RopieeeXL Connecting through AES/EBU connector to a topping D90 playing with Audirvana from MacBook Pro M1, sounds wonderful.
This interface extends the capabilities of your Raspberry Pi by adding a range of digital audio output. It includes an optical output (SPDIF) with...
