AUDIOPHONICS I-SABRE LTE ES9023 I2S DAC for Raspberry Pi 2 / 3 / 4
Reference : 11215
25,90 €tax incl.
21,58 € tax excl.
Shipping date: 11-12-2025.
Equipped with the now famous ESS SABRE ES9023 24bit 192khz (used in our U-SABRE USB DAC), Ultra Low Noise regulator and “Low ESR” filter capacitors, this DAC offers unrivalled value for money, delivering musical sound rich in micro-detail.
This LTE version features classic-quality RCA cinch connectors for an even more competitive price.
The integrated GPIO connector combines the I2S digital input with a 5V voltage input for plug-and-play use, simply plugged into a Raspberry Pi A+, B+, 2.0, 3.0, 4.0 and you're ready to go. This DAC requires no electronics skills or soldering iron to operate.
This 24bit DAC is also suitable for 100% Raspberry Pi-free design, thanks to its 6-pin (4+2 pin) I2S / 5V DC input on XHP connector.
For experienced DIY users, there's also the option of driving this DAC via an external MCLK clock (masterclock), or choosing word-clock left justified or the classic I2S protocol.
This is a formidable solution for accessing High Definition High Fidelity, with unrivalled value for money and extensive upgrade possibilities, such as the addition of a TCXO solder clock.
For use in Bit Perfect mode, maximum or fixed volume is required, depending on the Linux audio distribution used. The “I2S HifiBerry” driver position should be chosen to run on Rune Audio, Volumio or Pi.
General features :
  • Slot for soldering a full-size 50Mhz TCXO clock.
  • I2S input on Raspberry Pi GPIO connector.
  • 5V DC input on Raspberry Pi GPIO connector.
  • 6 pin (4+2 pin) I2S / 5V DC input on XHP connector.
  • Input: Raspberry PI B+ A+ 2.0/3.0 GPIO and I2S.
  • GPIO carry-over (you can stack other modules).
  • Output: Gold-plated RCA.
  • Supported sampling rates: 24bit 192 kHz.
  • This converter has its own clock. An external clock can be injected by connecting the R1 bridge.
  • No soldering required for use on Raspberry Pi.
  • Works with the I2S “HIFIBERRY DAC” driver.
Dimensions and weight :
  • PCB dimensions: 65x56x30mm.
  • Centre distance: 50 x 50 mm.
  • Weight: 35gr.
  • Supplied with 4 nuts, 4 screws and 4 spacers for mounting on PI B+, A+ or 2.0, 3.0 , 4.0 (HAT format).
We recommend the following USB I2S accessories and interfaces:
https://www.audiophonics.fr/images2/picoreplayer.jpg
InputI2S
DAC / ADC ChipES9023
Max sampling rate192kHz
Mounting typeTo connect
Channel2 (Stereo)
5 reviews
ES9023 Sabre DAC
Nice sounding device, full recomendation for well listening at low cost.
This review has been posted for AUDIOPHONICS I-SABRE LTE ES9023 I2S DAC for Raspberry Pi 2 / 3 / 4
ess 9023 Raspberry pi 4
awesome sound far better from a directly connected pc , fast sipping
Good cheap dac hat for raspberry pi 3b
Quick delivery to UK. Easy to install, comes with spacers, screws. Straight onto io pins. For volumio use hifiberry Dac driver option as in description . Easy as that. Very pleased with sound quality of flac and wav files through my hifi
Parfait !
Avec Volumio j'ai utilisé le pilote ES9026. Cependant le réglage de volume ne fonctionne pas, un problème de driver et de description du circuit Sabre qui ne peut pas gérer le volume semble-t-il.
Le pilote Volumio Sabre ES9026 pour Spotify connect ne fonctionne pas bien.
Il faut utiliser le pilote DAC standard. Mais je trouve que la qualité sonore n'est pas indentique. Une idée je ne sais pas.
Cette carte mérite un vrai pilote Volumio ;-)
super rapport qualité prix
J'avais besoin d'un juke box contenant toute ma musique dans ma maison de campagne qui n'a aucun accès réseau mobile et internet (le bonheur !). La solution ? Un petit raspberry PI 3, ce DAC complètement plug and play installé en 3minutes, une solution volumio qui crée également un AP wifi sur votre PI ... avec un vieux DD qui contient toute la musique et le tour est joué ! Une solution parfaitement autonome toute à fait qualitative au niveau du son . Merci Audiophonics ... super sympa par ailleurs.
