Ik gebruik de laatse versie van Volumio, maar geen sabre driver en geen geluid bij 16/44 bit
This new CADAUDIOPHONICS I-SABRE ES9018K2Mallows you to access the High Resolution 32bit 384KHZ directly compatible on Rapsberry Pi.
TheDAC I-SABRE ES9018K2Mincludes a power input directly to 5V micro USB input. This input has an isolator (voltage isolation 3000VDC).
Special attention is given to the power supply with two controllers followed by capacitors ensuring the necessary stability for the DAC ESS SABER 32bit.
Like all DAC dedicated Raspberry PI on GPIO support, The AUDIOPHONICS I-SABRE ES9018K2Mincludes a large number of options. It thus allows to adapt to all the possibilities and project DIY HIFI.
This DAC includes a voltage stage with two AOP NJM 2114D corresponding to the technical drawings of ESS. A final AOP NJM2114 buffer finalizes the output stage.
This DAC includes an integrated controller programmed by our development team. Depending on the firmware used, you can control the 32 bit digital volume of the ESS SABER DAC.
Ce 32-bit volume with 64bit accumulator is the most powerful on the market. It also allows the volume management of the ES9018K2m in hardware via a kit button soon available.
This optional screen of the most readable indicates the bit-rate, volume and various information from the DAC. It will suffice to connect it on 4 wires on the card of the DAC. it is managed by the microcontroller on the card.
It shows the main sampling frequencies, the I2S input and the volume level at the Décibel pré. Several sizes of screens will be available depending on the project or the desired assembly.
This DAC has an input on the circuit making it possible to input a voltage of 5V DC regulated directly on the ESS SABER ES9018K2M without going through the internal regulation. It is thus possible to further increase the decoding accuracy by any quality linear power supply. This DAC ES9018 K2M also allows the supply of Pi 3 or Pi 2 via the GPIO connector avoiding multiple unnecessary connections simplifying the arrangement of a case.
This DAC IS COMPATIBLE with REclocker 44 / 48MHZ ALLO KALI
Raspberry Pi 2 1GB HDMI 1.4 USB 2.0 1080p
Raspberry Pi 3 1GB HDMI Ethernet 4xUSB 1.2Ghz
Spacer Brass M2.5x11mm screw thread (x10)
AUDIOPHONICS Regulated Linear Power Supply Low Noise USB 5V 3.5A 25VA Audiophonics
Type of operation | CONTROLLER | DAC | MANAGEMENT volume and functions | INPUT I2S | DISPLAY screen | Things to do on the ES9018K2M |
SLAVE MODE 1 | The controller is disabled, the monitor output is not active | The DAC can be operated with a Pi2 / 3 or a 24-32 bit I2S source | Rune Audio manages software volume | The I2S input accepts 24-32 bit | OLED output disabled | Jumper welding IC or grounded |
STAN MODEDALONE 2 | The controller is active in master | The DAC is self-contained, no need for Pi2 or Pi3 | The volume and the mute are managed by the DAC in hardware mode with buttons | The I2S input accepts 16 / 24-32 bit depending on the MUTE pin (GND or 5V) | Bitrate and Volume displayed on a dedicated Oled screen | The IR pin must be GND |
SERIAL HARDWARE MODE | The controller is synchronized with the PI in serial connection | The DAC needs the serial script to be driven | The volume is in hardware mode (serial synchronization) | The I2S input accepts 16 / 24-32 bit depending on the serial message | Bitrate and Volume displayed on a dedicated Oled screen | the IR pin must be at + 5V |
Purchase this connector (click on the link): jack 5.5/2.5
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Adam P.
