AUDIOPHONICS DAC1796 DAC Module CS8416 + PCM1796 24Bit 192KHz
4.8 / 5
Reference : 4993
69,90 €tax incl.
58,25 € tax excl.
Shipping date: 18-09-2025.
Audiophonics is proud to present its DAC board ready to be integrated in your projects. We have based ourselves on a sure value, a CS8416-CZ chip from Cirrus logic for SPDIF reception, coupled with a reference in the field, the PCM1796 converter from Burr-Brown.
This DAC card allows to convert a digital signal with a sampling frequency from 32 to 192KHz and this in 16 or 24 bit. The version 1.1 of this card includes now 2 SPDIF inputs, one optical TOSLINK and one Coaxial. The analog output is always present on the small white connector.
Great care has been taken with the analog output, it features 3 high end OPAs OP275 mounted on socket. The capacitors around the signal are all MKP and the resistors are Vishay DALE. The power supply capacitors are of high quality, 9x Panasonic FC 1500µF and Panasonic OSCON. In all 5 regulators are used to provide a stable and pure power supply, including 2 low noise regulators close to the digital chips.
To operate it requires a transformer of less than 30VA with these voltages: 2x15V AC + 1x6V AC. The 15V AC is used for the analog part, the 6V AC for the digital part.
Features:
  • Optical and Coaxial inputs
  • Default filter: Sharp (not modifiable)
  • SPDIF reception by Cirrus Logic CS8416
  • Decoding up to 24Bit 192KHz by Burr-Brown PCM1796
  • OPA275 Output OPA mounted on support
  • Analog output with connector or on PCB
  • Power supply capacitors Panasonic FC 1500µF and Panasonic OSCON
  • MKP signal capacitor and Vishay resistors
  • Power supply by a simple transformer 30VA 2x15V AC + 1x6V AC
  • Board dimensions: 160*70*29mm
  • Mounting holes spacing: 150*60.5mm
Delivered module:
https://www.audiophonics.fr/images2/4993/DAC1796_BOARD.jpg
Example of a realization based on a GX-183 box
https://www.audiophonics.fr/photos/DAC_1796_2.jpg
https://www.audiophonics.fr/photos/DAC_1796.jpg
OutputXH 2.54mm
OutputPH 2.0mm
DAC / ADC ChipPCM1796
Max sampling rate192kHz
Channel2 (Stereo)
14 reviews
Bon rapport qualité prix
Je viens d'acquerir ce Dac pour mettre en sortie d'une platine cd Marantz.
Pas de soucis pour me montage dr ce kit. Le rendu sonore est vraiment bien. Je me demande si un changement des AOP comme évoqué dans les autres avis serai vraiment perceptible par mes oreilles.
J'utilise l'entrée optique.
J'espère que le sevice technique de audiphonics mettra à jour le schema technique et le plan de la platine a jour car elle est encore pour l'ancien modèle avec les aop NE 5533 et NE 5534. Merci par avance. Sans regret pour cet achat.
This review has been posted for AUDIOPHONICS DAC1796 DAC Module CS8416 + PCM1796 24Bit 192KHz
Ce DAC est vraiment bon ! surtout si on remplace les 3 AOPs d'origine par des AOPs doubles BURR BROWN OPA627.
J'ai fait l'erreur de me fier à l'avis précédent :
Une DEXA discrete est un AOP simple ; en sortie de ce DAC cela pose un problème de niveau de sortie...
Etonnant petit DAC
C'est le deuxième de ce DAC que je viens d'acheter. Excellent dès le départ, j'ai remplacé les AOP I/V par des OPA627 et sur l'étage de sortie un AOP discret DEXA. Tout y est....
OK
good quality and sound
Bonne qualité
Bonjour,
J'ai remplacé les amplis op par des BURR BROWN OPA627 AOP double, effectivement le son est très bon.
Mais deux bémols, l’interrupteur placé à l'arrière est difficile à dé-souder (j'en ai mis un en façade), et il y a un bruit à l'allumage, donc dans un futur proche je mettrai un système de temporisation sur la sortie analogique...
