DAC Board 2x TDA1305T CS8412 USB SPDIF 16bit 48kHz
This simple DAC module is based on the use of two TDA1305T digital to analog conversion chips, one per channel, supporting PCM audio streams up to 16bit 48kHz. These are associated with a CS8412 SPDIF interface and a 12MHz MCO clock to reduce jitter considerably.
Reference : 16529
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 05-05-2026.
DAC Board
Module DAC 2x TDA1305T CS8412 USB SPDIF 16bit 48kHz
For the connectivity, the module offers coaxial, optical Toslink and USB-B as inputs. The output is either stereo RCA or 3.5mm jack.
Connecting the USB automatically disables the SPDIF inputs.
The simultaneous connection of the optical and coaxial inputs can generate noise.
Product typeDAC Board
DAC Chips2x TDA1305T
Inputs1x USB-B
1x Optical Toslink
1x Coaxial
Outputs1x Stereo RCA
1x Jack 3.5mm
Supported sampling ratesPCM up to 16bit 48kHz
SPDIF InterfaceCS8412
Power supply5V DC via 5.5/2.1mm DC Jack
Dimensions139 x 109mm
OutputJack 3.5mm
DAC / ADC ChipTDA1305T
Max sampling rate48kHz
This simple DAC module is based on the use of two TDA1305T digital to analog conversion chips, one per channel, supporting PCM audio streams up to...
