This DAC module is equipped with an ESS ES9038Q2M digital-to-analog conversion chip. This enables it to support high-resolution audio streams up to PCM 32bit 384kHz and DSD256. Input is via I2S on a 2.54mm XH connector (5 pins), and output is via stereo RCA or a 2.54mm XH connector (3 pins). The module offers excellent audio performance for transparent, accurate sound reproduction.
1 | I2S input |
2 | Audio output (3 pins) |
3 | RCA audio output |
4 | Power input 5-32V DC (2 pins) |
Product type | DAC module |
DAC chip | ES9038Q2M |
Input | I2S |
Outputs | 1x Stereo RCA or XH 2.54mm connector (3 pins) |
Supported sampling rates | PCM up to 32bit 384kHz DSD up to DSD256 |
SNR | 129dB |
THD+N | 120dB |
Output level | 3V |
OPA | NE5532P |
Supply voltage | 5-32V DC on XH 2.54mm connector (2 pins) |
PCB dimensions | 80 x 48mm |
Total dimensions | 90 x 48mm |
Mounting holes spacing | 67 x 42mm |
Input | I2S |
Output | RCA |
Output | PCB Connector |
DAC / ADC Chip | ES9038Q2M |
Max sampling rate | 384kHz |
Max sampling rate | DSD256 |
