DAC Module ES9038Q2M
This DAC module is equipped with an ESS ES9038Q2M digital-to-analog conversion chip. This enables it to support high-resolution audio streams up to PCM 32bit 384kHz and DSD256. Input is via I2S and output via RCA.
Reference : 18643
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 12-09-2025.
DAC Module ES9038Q2M I2S RCA 32bit 384kHz DSD256
DAC module ES9038Q2M
This DAC module is equipped with an ESS ES9038Q2M digital-to-analog conversion chip. This enables it to support high-resolution audio streams up to PCM 32bit 384kHz and DSD256. Input is via I2S on a 2.54mm XH connector (5 pins), and output is via stereo RCA or a 2.54mm XH connector (3 pins). The module offers excellent audio performance for transparent, accurate sound reproduction.
ES9038Q2M DAC module connection diagram
1I2S input
2Audio output (3 pins)
3RCA audio output
4Power input 5-32V DC (2 pins)
Product typeDAC module
DAC chipES9038Q2M
InputI2S
Outputs1x Stereo RCA or XH 2.54mm connector (3 pins)
DSD up to DSD256
SNR129dB
THD+N120dB
Output level3V
OPANE5532P
Supply voltage5-32V DC on XH 2.54mm connector (2 pins)
PCB dimensions80 x 48mm
Total dimensions90 x 48mm
Mounting holes spacing67 x 42mm
InputI2S
OutputPCB Connector
DAC / ADC ChipES9038Q2M
Max sampling rateDSD256
Max sampling rate384kHz
This DAC module is equipped with an ESS ES9038Q2M digital-to-analog conversion chip. This enables it to support high-resolution audio streams up to...
