AUDALYTIC AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Silver
The Audalytic AH90 is a DAC offering excellent decoding performance and precise sound reproduction, thanks to a careful and intelligent design. And it's reasonably priced for what it delivers. As well as using top-of-the-range components, such as an AKM AK4499EX DAC chip or an XMOS XU316 USB interface, the AH90 boasts comprehensive connectivity, even providing balanced and single-ended amplified headphone outputs. It's also a connected device that can be used as a streamer, thanks to its RJ45 Ethernet port.
By buying this product you get 59 loyalty points
Reference : 18317
599,00 €tax incl.
499,17 € tax excl.
Shipping date: 13-06-2025.
Audalytic AH90
Audalytic AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Silver
AK4499EX DAC
The Audalytic AH90 is based on an AK4499EX digital-to-analog conversion chip and an AK4191 digital modulation chip. This design drastically reduces interference between digital and analog circuits. As a result, the AH90 is able to deliver high-quality decoding, favoring high-precision, crystal-clear playback.
FPGA
With its integrated, specially programmed FPGA, the AH90 ensures high-quality clock signal processing. It is thus able to greatly reduce jitter levels for perfect signal synchronization and enhanced sound accuracy.
Streamer
The Audalytic AH90 features a streamer function via Ethernet, enabling you to stream your music remotely. In particular, it supports DLNA, AirPlay and Roon protocols, enabling you to access your music from devices connected to the local network, whether a computer, NAS or smartphone.
The AH90's USB-C input is combined with a 3rd-generation XMOS XU316 USB interface. This ensures efficient signal decoding via this input, and supports high-resolution audio streams up to PCM 32bit 768kHz, DSD512 and MQA.
CK-01 Clock
The on-board CK-01 clock oscillator enables the AH90 to supply its FPGA with a high-precision clock signal. This greatly reduces the device's jitter.
Headphone outputs
The Audalytic AH90 features a headphone amplifier with two outputs: a balanced Jack 4.4mm and a single-ended Jack 6.35mm. In addition, two gain levels are available to enable the device to adapt to the vast majority of headphones on the market.
MQA
The AH90 is capable of efficiently decoding MQA (Master Quality Authenticated) streams. These ensure sound reproduction as close as possible to the original studio recording, thanks to files validated directly by the artist, record company or copyright holders.
1Power button
2Screen
3Jack 6.35mm single-ended headphone output
4Jack 4.4mm balanced headphone output
5Multifunction knob
6Coaxial input
7100-240VAC power input
8Balanced XLR output
9Single-ended RCA output
10Coaxial input
11Optical input
12USB-C Audio input
13Ethernet RJ45 port
14Micro SD slot for firmware update
1512VDC power input
16Fuse
Product typeDAC
DAC chipAKM AK4499EX
Inputs1* Ethernet RJ45
1* USB-B
1* Optical Toslink
2* Coaxial
Outputs1* Balanced stereo XLR
1* Single-ended stereo RCA
Supported sample ratesUSB / LAN: PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256, MQA
Optical / Coaxial: PCM up to 24bit 192kHz, DSD DoP up to DSD64, MQA
Frequency response20Hz - 20kHz ±0.5dB
Output levelRCA : 2Vrms
XLR : 4Vrms
Supply voltage100-240VAC OR 9-15VDC 2.5A (Jack DC 5.5 / 2.1mm)
Dimensions220*170*50mm
ColorSilver
Package1* Gustard AH90
1* Power cable
1* USB cable
1* Remote control
Audalytic AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Silver Audalytic AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Silver Audalytic AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Silver Audalytic AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Silver Audalytic AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Silver Audalytic AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Silver Audalytic AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Silver Audalytic AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Silver
InputRJ45
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipAK4499EX
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
ColorSilver
NetworkingYes
Remote ControlYes
2 reviews
Updated review - Gustard Audalytic AH90
The AH90 is unique: It is the only device that can act as a DAC, Headphone Amo, and Steamer at this price point and this level of quality. The competition does not offer all 3 in one. Furthermore, after and update the unit is able to output to speakers DSD signals natively rather than converting them. That only works to speakers and for the odd recording that is DSD coded, which are rare in the market.
As a professional musician my sensitivities are not limited to volumes but to being able to hear what people do. This unit has been a joy. Regardless of what type of music and musicians are involved I can hear things. Status Quo was famous for changing guitars to create different sounds durng concerts. This unit will let you hear the difference. As an opera singer, the acoustic of a stage like Munich can make you aware of things you do as a singer that you do. Some houses make a musician reach into their bag of tricks. Think of Queen at Wembley and listen to it on a unit like this and listen to it with this unit: made me smile. No tricks of voicing. My previous SMSL bumped up the bass but never sounded as natural.
If you connect it to your LAN for Upnup or Streaming, you may not need a WiiM unit at all. I still own a WiiM Pro but am sure over my internal system the Gustarender software will sound better.
This is a special machine at this price point. It receives my highest recommendation. It has flexibility the Matrix Mini 4 does not have and is way cheaper than buying several machines to do what this unit does a 3 in !.
 (4)
This review has been posted for AUDALYTIC AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Silver
80% of the Gustard A26 at 1/3 the price
This unit is simply wonderful. Instrumental timbres are correct. Instrumental separation is accomplished. The unit is in no way slow in the low bass frequencies. If your speakers tend to beam the treble frequencies, the filters supplied in the DAC are a huge help and don't destroy the musicality. I am joyous over this purchase. I feel confident in saying that this is the best Streaming, DAC, and headphone amp you can buy for 599. FIf you are not Roon centric, you can use a WiiM Pro, because this unit will beat the pants off of the WiiM Pro+. I am still setting everything up and amazed it even bettered my Moon CD-1 with Burr-Brown Chips and I 8 times upsampling. They will be releasing a new firmware to address some concerns expressed by DSD disk owners. I listened to several of mine without the firmware and it is still the best DAC I have heard. It drives ma headphones too. It does not do Chromecast natively but the company says they intend to extend availabilities. Head-Fi has a dedicated page for Gustard owners if you are interested.
I am in love.
 (3)
The Audalytic AH90 is a DAC offering excellent decoding performance and precise sound reproduction, thanks to a careful and intelligent design. And...
