AUNE X8 XVIII BT MAGIC DAC ES9038Q2M Bluetooth aptX HD LDAC 32bit 768kHz DSD512 Silver
The X8 XVIII BT Magic DAC from Aune is a special edition of the DAC, on the occasion of the 18th anniversary of the brand. This one takes back the idea of the interchangeable AOP as well as the seven available filters, while adding a preamplified TRS balanced output. In addition, this BT version also benefits from Bluetooth connectivity with support for the high-resolution transmission codecs aptX HD and LDAC.
By buying this product you get 30 loyalty points
Reference : 16809
309,00 €tax incl.
257,50 € tax excl.
Shipping date: 19-06-2025.
Aune X8 XVIII BT Magic DAC
DAC DAC ES9038Q2M Bluetooth aptX HD LDAC 32bit 768kHz DSD512
Aune X8 XVIII BT Magic DAC FPGA Bluetooth aptX HD LDAC 32bit 768kHz DSD512
Aune X8 XVIII BT Magic: DAC ES9038Q2M
The X8 XVIII allows the decoding of high resolution audio streams up to PCM 32bit 768kHz and DSD512. Using an ESS ES9038Q2M DAC chip, the X8 XVIII offers a precise, dynamic and detailed sound reproduction.
Aune X8 XVIII BT Magic:TRS balanced output
In addition to its USB, coaxial and optical inputs and its RCA pre-out and line outputs, the X8 XVIII is now equipped with a balanced preamplified output in 6.35mm TRS format.
Aune X8 XVIII BT Magic:Interchangeable AOP
The Aune X8 XVIII takes the concept of the interchangeable AOP. This one is indeed mounted on DIP8 support and accessible under the device. You just have to replace it by another model to adapt the sound reproduction of the DAC according to your audio system and your listening.
Aune X8 XVIII BT Magic:Seven available filters
The Aune X8 XVIII provides seven filters. Just like the interchangeable AOP, these allow you to adjust the sound signature of the device according to your desires.
1Selection button
2LED indicator
3Volume button
4Coaxial input
5Bluetooth antenna
6Power switch
7Preamp outputs
8Line out
9Optical input
10USB-B Input
11Powre connector
Product typeDAC
DAC chipESS ES9038Q2M
Inputs1x Coaxial
1x Optical
1x USB-B
Bluetooth
Outputs1x Stereo RCA (Pre-Out)
1x Dual Jack 6.35mm TRS (Pre-Out)
1x Stereo RCA (Line out)
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD up to DSD512
Coaxial : PCM up to 24bit 384kHz, DSD DoP up to DoP128
Optique : PCM up to 24bit 192kHz, DSD DoP up to DoP64
Output level2Vrms
Frequency response20Hz ~ 20kHz ±0.5dB
SNR121dB
THD+N (1kHz)0.00027%
ColorSilver
PackageAune X8 XVIII
1x Power adapter
1x USB Cable
1x Bluetooth antenna
OutputJack 6.35mm
DAC / ADC ChipES9038Q2M
Max sampling rateDSD512
Max sampling rate768kHz
ColorSilver
Remote ControlN/A
REMARQUABLE
petit mais costaud :)
AUNE MAGIC DAC porte bien son nom, un magicien du son
il vous transforme la sonorité de la musique dans tous ses détails
la scène musicale est plus ouverte , les détails sont précis ,
relier un un lecteur réseau BLUESONUD NODE X
WAOUH le couple parfait ,sa simplicité de branchement via un câble coaxial et sa facilité d'exécution est remarquable
je ne regrette pas mon choix pour cette marque AUDIOPHILE
This review has been posted for AUNE X8 XVIII BT MAGIC DAC ES9038Q2M Bluetooth aptX HD LDAC 32bit 768kHz DSD512 Silver
The X8 XVIII BT Magic DAC from Aune is a special edition of the DAC, on the occasion of the 18th anniversary of the brand. This one takes back the...
