By buying this product you get 199 loyalty points
DAC Class A Headphone Amplifier Preamplifier 2x ES9038Q2M Bluetooth 32bit 768kHz DSD512
Burson Audio offers with its Conductor 3 Reference a DAC, Class A headphone amplifier and preamplifier combo of great quality. Its digital/analog conversion stage is indeed equipped with a pair of ESS ES9038Q2M DAC chips, associated with a USB XMOS receiver chip using a custom Thesycon driver. This combination allows to deliver a rich and precise sound, while supporting high sampling rates, up to PCM 32bit 768kHz and DSD512.
Conveniently, the Conductor 3 Reference also features a Qualcomm CSR8675 Bluetooth 5.0 receiver, supporting the aptX HD audio codec, allowing you to remotely stream your music, from a smartphone for example, with improved quality, comparable to CD.
The unit also incorporates Burson Audio's patented MCPS (Max Current Power Supply), increasing the voltage frequency from 50Hz to 170kHz, pushing noise beyond the threshold of human hearing. Moreover, it takes advantage of a low impedance to offer an important energy reserve to the output transistors. It is worth noting that the Conductor 3 Reference has no less than 5 sets of MCPS. Each element, namely the display, the controls, the DAC and the left and right analog channels are all independently powered.
In terms of design, the device's components are hidden in a robust high-density aluminum case. This chassis also acts as a heat sink to keep the components at an acceptable temperature. On its front panel, the Conductor 3 Reference is equipped with an OLED display for intuitive and fluid use.
Product type | DAC Headphone amplifier Preamplifier |
DAC Chips | 2x ES9038Q2M |
Amplifier type | Class A |
Bluetooth Chip | Qualcomm CSR8675 |
Inputs | Bluetooth 5.0 2x Line level stereo RCA 1x USB 1x Optical Toslink |
Outputs | 1x Pre-Out stereo RCA 1x DAC Out stereo RCA 2x Jack 6.35mm headphone outputs |
Input impedance | 40kΩ |
Frequency response | 0Hz - 58kHz ±1dB |
THD | < 0.0015% |
Output impedance | Headphone amplifier : 0.5Ω Pre Out : 1Ω DAC Out : 25Ω |
Headphone amplifier power output | 7.5W @ 16Ω 5W @ 32Ω 1.75W @ 100Ω 1.16W @ 150Ω 0.58W @ 300Ω |
Channel separation (DAC) | 142dB @ 1kHz 135dB @ 20kHz |
THD+N (DAC) | 0.0005% @ 1kHz, 0dBFS |
Supported sampling rates | USB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DoP512 SPDIF : PCM up to 24bit 192kHz |
Dimensions | 255 x 270 x 70mm |
Color | Silver |
Weight | 5kg |
Package | 1x Burson Audio Conductor 3 Reference 1x USB Cable 1x RCA Cable 1x Power supply |
Input | USB |
Input | SPDIF |
Input | Bluetooth |
Input | RCA |
Input | Optical |
Output | RCA |
Output | Jack 6.35mm |
DAC / ADC Chip | ES9038Q2M |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Silver |
Class | Class A / AB |
Networking | No |
Remote Control | Yes |
