DYNAVOX DAC UM1 DAC Coaxial Optical 24bit 192kHz
The Dynavox DAC UM1 is a small digital/analog converter that is particularly affordable but still efficient. It has a Coaxial and an Optical input. At the output you will find a stereo RCA connector and a 3.5mm headphone output.
Reference : 14843
25,90 €tax incl.
21,58 € tax excl.
Dynavox DAC UM1
Dynavox DAC UM1 DAC Optique Coaxial 24bit 192kHz
The Dynavox DAC UM1 is a small digital/analog converter that is particularly affordable but still efficient. It has a Coaxial and an Optical input. At the output you will find a stereo RCA connector and a 3.5mm headphone output, their volumes being controllable via the buttons on the front of the device or with the supplied remote control. The DAC supports PCM sample rates up to 24bit 192kHz.
The SPDIF digital circuit works with a Cirrus Logic CS8416 chip connected to a conversion circuit built around a stereo DAC CS4344 Logic chip. This chip combo from the same manufacturer works together by sharing the same prerequisites for optimal operation.
Product typeDAC
Inputs1x Optical
1x Coaxial
Outputs1x Stereo RCA
1x Jack 3.5mm headphone output
DAC chipCS4344
Digital InterfaceCS8416
Supported sampling ratePCM up to 24bit 192kHz
Power supply5V 1A via Micro USB
Dimensions110 x 20 x 70mm
Weight70g
Package1x Dynavox DAC UM1
1x Remote cotnrol
1x USB-A to Micro USB cable
OutputJack 3.5mm
DAC / ADC ChipCS4344
Max sampling rate192kHz
Remote ControlYes
SEVA
THE PRODUCT MEETS EXPECTATIONS, SUITABLE FOR CONNECTING THE TV OPTICAL OUT, THE REMOTE CONTROL IS EXCELLENT FOR VOLUME REGULATION.
This review has been posted for DYNAVOX DAC UM1 DAC Coaxial Optical 24bit 192kHz
The Dynavox DAC UM1 is a small digital/analog converter that is particularly affordable but still efficient. It has a Coaxial and an Optical input....
