FOSI AUDIO DAC-Q5 DAC ES9018K2M Headphone Amplifier TPA6120 24bit 192kHz
Compact, versatile and affordable, the Fosi Audio DAC-Q5 brilliantly takes on the role of DAC and headphone amplifier. Ideal for a desktop installation, it will fit just as well into a more traditional audio system. Its digital/analogue conversion stage is based on an ESS ES9018K2M DAC chip, ensuring high-quality decoding for rich, accurate sound reproduction.
Reference : 17960
79,90 €tax incl.
66,58 € tax excl.
Fosi Audio DAC-Q5
Fosi Audio DAC-Q5 DAC ES9018K2M Amplificateur Casque TPA6120 24bit 192kHz
Compact, versatile and affordable, the Fosi Audio DAC-Q5 brilliantly takes on the role of DAC and headphone amplifier. Ideal for a desktop installation, it will fit just as well into a more traditional audio system. Its digital/analogue conversion stage is based on an ESS ES9018K2M DAC chip, ensuring high-quality decoding for rich, accurate sound reproduction. It is accompanied by an MS8416 SPDIF receiver and a SA9123L USB interface accepting PCM signals up to 24bit 192kHz. The headphone amplification stage of the Fosi Audio DAC-Q5 is entrusted to a TPA6120 chip and NE5532 OPAs, enabling it to develop a power of 400mW at 32Ω. In terms of connectivity, the inputs are USB-B, optical and coaxial. Outputs are either RCA or amplified headphone outputs with Jack 3.5mm and Jack 6.35mm connectors.
1Input indicator
2Jack 3.5mm headphone output
3Volume knob
4Power ON-OFF / Input selection
5Jack 6.35mm headphone output
6Coaxial input
712VDC Power input
8USB-B input
9Optical Toslink input
10Stereo RCA output
Product typeDAC
Inputs1* USB-B
1* Optical Toslink
1* Coaxial
Outputs1* Stereo RCA
1* Jack 3.5mm headphone output
1* Jack 6.35mm headphone output
DAC ChipESS ES9018K2M
USB interfaceSA9123L
OPALME49720
Headphone amplifier chipTPA6120A2
Supported sampling ratesPCM up to 24bit 192kHz
Frequency response10Hz-20kHz (±0.5dB)
Headphone output power400mW @ 32Ω
SNR> 110dB
THD+N (1kHz)< 0.002%
Recommended headphone impedance16-250Ω
Supplu voltage12VDC 1A
Dimensions98*165*35mm
Housing materialAluminum alloy
Package1* Fosi Audio DAC-Q5
1* Power supply
1* USB cable
OutputJack 6.35mm
OutputJack 3.5mm
DAC / ADC ChipES9018K2M
Max sampling rate192kHz
ClassN/A
Compact, versatile and affordable, the Fosi Audio DAC-Q5 brilliantly takes on the role of DAC and headphone amplifier. Ideal for a desktop...
