With the K5 Pro, Fosi Audio offers a compact, versatile and affordable DAC / headphone amplifier. With its microphone input on the front panel, the K5 Pro is designed to fit into a desktop installation, although it can easily be integrated into a more conventional audio setup. Indeed, in addition to its headphone output, the K5 Pro has an RCA output, which can be connected to an amplifier or directly to active speakers. Furthermore, the USB-C input is a 2-in-1 socket that can receive data and power the K5 Pro at the same time.
The K5 Pro's amplification stage incorporates a NE5532 OPA and is capable of developing a power of 1000mW at 16Ω and 80mW at 300Ω, while maintaining a harmonic distortion rate below 0.003%. Note that signal amplification also applies to the 3.5mm jack microphone input.
As far as digital/analog conversion is concerned, the K5 Pro accepts input sampling rates of up to 24bit 192kHz for optical and coaxial input, and 16bit 96kHz for USB-C input.
1 | Indicator light |
2 | 3.5mm Jack headphone output |
3 | 3.5mm Jack microphone input |
4 | Bass control |
5 | Treble control |
6 | Mode selection / Volume control / Power button |
7 | USB-C input / Power supply |
8 | Optical input |
9 | Coaxial input |
10 | Right RCA output |
11 | Left RCA output |
Product type | DAC Headphone amplifier |
Inputs | 1x USB-C 1x Coaxial 1x Optical toslink 1x 3.5mm Jack for microphone |
Outputs | 1x Stereo RCA 1x 3.5mm Jack for headphones |
OPA | NE5532 |
Supported sampling rates | USB-C : up to 24bit/96KHz Coaxial / Optical : up to 24bit/192KHz |
Headphone output power | 1000mW @16Ω 500mW @32Ω 300mW @64Ω 150mW @128Ω 80mW @300Ω |
Signal-to-noise ratio (SNR) | ≥110dB |
Total harmonic distortion (THD) | <0.003% |
Recommended headphone impedance | 16Ω - 300Ω |
Power supply | USB-C 5V |
Dimensions | 112 x 95 x 30mm |
Color | Grey |
Weight | 251g |
Package | 1x Fosi Audio K5 Pro 1x USB-C cable 1x Optical cable 1x Two-in-one headset adapter |
Input | Jack 3.5mm |
Input | Optical |
Input | USB |
Input | SPDIF |
Output | Jack 3.5mm |
Output | RCA |
DAC / ADC Chip | NC |
Max sampling rate | 192kHz |
Color | Gray |
Class | N/A |
Networking | No |
Remote Control | No |
