FOSI AUDIO K7 DAC Headphones Amplifier
The Fosi Audio K7 is a compact, high-performance DAC/headphone amplifier featuring an original design and high-quality components. It features an XMOS XU208 USB interface, an AKM AK4493SEQ DAC chip for its digital-to-analog conversion stage, and a balanced amplifier circuit with two TPA6120 chips and OPA1612 OPAs. The Fosi Audio K7 is therefore capable of supporting high-resolution audio streams up to PCM 32bit 384kHz and DSD256, and delivers headphone output power of up to 2x 2100mW at 32Ω.
Reference : 20662
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 17-06-2025.
Fosi Audio K7 DAC Headphone Amplifier AK4493SEQ XMOS XU208 Bluetooth 5.0 aptX HD 32bit 384kHz DSD256
Photo of FOSI AUDIO K7
The Fosi Audio K7 is a compact, high-performance DAC/headphone amplifier featuring an original design and high-quality components. It features an XMOS XU208 USB interface, an AKM AK4493SEQ DAC chip for its digital-to-analog conversion stage, and a balanced amplifier circuit with two TPA6120 chips and OPA1612 OPAs. The Fosi Audio K7 is therefore capable of supporting high-resolution audio streams up to PCM 32bit 384kHz and DSD256, and delivers headphone output power of up to 2x 2100mW at 32Ω. The K7's Bluetooth 5.0 connectivity - thanks to a Qualcomm QCC3031 chip - supports standard SBC and AAC codecs as well as the high-resolution aptX, aptX LL and aptX HD codecs, and thus offers a quality wireless listening experience. In terms of connectivity, the K7 is equally complete and versatile, with three digital inputs (USB-C, coaxial and Toslink optical), two headphone outputs (single-ended 3.5mm jack and balanced 4.4mm jack), as well as a 3.5mm jack microphone input and an RCA line output. Finally, a 1.5” LCD screen displays operating information for intuitive operation.
Key features of the Fosi Audio K7
Fosi Audio K7: An audiophile DAC for a high-resolution listening experience
Thanks to its USB XMOS XU208 interface and AKM AK4493SEQ DAC chip, the Fosi Audio K7 supports high-resolution audio streams up to PCM 32bit 384kHz and DSD256 via its USB-C input. The Toslink optical and SPDIF coaxial inputs support PCM up to 24bit 192kHz. The K7 offers an audiophile listening experience with faithful reproduction of detail.
Fosi Audio K7 DAC chip
Fosi Audio K7: Balanced amplification circuit for exceptional power and sound clarity
The K7's headphone amplifier circuit, based on a balanced architecture, integrates two TI TPA6120 chips and two AOP OPA1612s. This configuration delivers high headphone output power (2x 2100mW into 32Ω on the balanced 4.4mm jack output and 2x 600mW into 32Ω on the unbalanced 3.5mm jack output), enabling a wide range of headphones and earphones to be driven with exceptional sonic clarity.
Fosi Audio K7 amplification circuit
Fosi Audio K7: Bluetooth 5.0 for high-quality wireless connectivity
The Fosi Audio K7 is equipped with a Qualcomm QCC3031 receiver chip, offering stable Bluetooth 5.0 connectivity and support for standard SBC and AAC codecs, as well as high-definition aptX, aptX LL and aptX HD codecs for quality wireless transmission.
Bluetooth 5.0 feature of the Fosi Audio K7
Fosi Audio K7: A clean power supply for optimum sound reproduction
The Fosi Audio K7's power supply is optimized through the use of LDO regulators, ensuring precise voltage distribution for each component. This design reduces noise and improves overall sound quality.
Fosi Audio K7 power supply
Fosi Audio K7 overview
1Volume / Gain control
2LCD screen
3Tonalité / Microphone volume control
4Control buttons
5Microphone jack 3.5mm input
6Single-ended jack 3.5mm headphone output
7Balanced jack 4.4mm headphone output
8RCA line output
9Bluetooth antenna
10Coaxial input
11Optical Toslink input
12USB-C input
13Jack DC 12V power input
Fosi Audio K7 test by Headfonia
"Geeky, mighty, and genuinely versatile, this little DAC/Amp handled everything I threw at it, both sonically and technically, bridging the gap between my gaming setup, my audiophile cravings, and even my daily work rig. The wealth of inputs, the flat tuning, the solid amplification stage, everything just clicked."
Headfonia
Product typeDAC
Headphone amplifier
USB interfaceXMOS XU208
DAC chipAKM AK4493SEQ
Amplification chips2x TPA6120
Bluetooth chipQCC3031
Inputs1x USB-C
1x Optical Toslink
1x Coaxial
1x Microphone jack 3.5mm input
Bluetooth 5.0
Outputs1x Stereo RCA line output
1x Balanced jack 4.4mm headphone output
1x Single-ended jack 3.5mm headphone output
Supported sampling ratesUSB: PCM up to 32bit 384kHz, DSD up to DSD256
Optical Toslink / Coaxial: PCM up to 24bit 192kHz
Bluetooth 5.0: PCM up to 24bit 48kHz (depending on codec used)
Supported Bluetooth codecsSBC, AAC, aptX, aptX LL, aptX HD
Bluetooth range≤ 13m
Recommended headphone impedance16-300Ω
OS compatibilityWindows 7, 8, 8.1, 10, 11 (with driver)
Mac OS X, Linux (without driver)
Output powerL+R ≥ 2x 2100mW (32Ω/THD+N<1%)
SNR121dB
THD+N< 0.0002%
Dynamic range121dB
Noise level≤ 6.5μV
Output powerL+ R ≥ 2x 600mW (32Ω/THD+N<1%)
SNR122dB
THD+N< 0.0005%
Dynamic range121dB
Noise level≤ 2.5μV
Frequency response20Hz-20kHz (±0.1dB)
RCA line output
Output level≥ 2Vrms
SNR20Hz-20kHz (±0.1dB)
THD+N0.0005%
Dynamic range121dB
Noise level≤ 3μV
Power supply12V DC 2A
Dimensions9 x 15.5 x 4.3cm
Package1x Fosi Audio K7
1x USB-A/C to USB-C cable
1x Jack 3.5mm splitter
1x Bluetooth antenna
1x Power adapter
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipAK4493SEQ
Max sampling rateDSD256
Max sampling rate384kHz
ClassClass A / AB
FOSI AUDIO K7 DAC Headphone Amplifier AK4493SEQ XMOS XU208 Bluetooth 5.0 aptX HD 32bit 384kHz DSD256
The Fosi Audio K7 is a compact, high-performance DAC/headphone amplifier featuring an original design and high-quality components. It features an...
