FOSI AUDIO ZH3 DAC Preamplifier Balanced Headphone Amplifier
The ZH3 from Fosi Audio is a preamp and headphone amplifier that also includes a DAC function. This versatile device is based on four OPA1612 chips to provide 2570 mW of amplification under 32 Ω per channel and uses an AKM AK4493SEQ DAC chip, allowing it to handle signals up to PCM 32-bit 768 kHz and DSD256. Its balanced circuitry, coupled with the control it offers over the final tone, ensures that the ZH3 has a place of honour in many Hi-Fi installations, thanks to both its versatility and the quality of its components.
Reference : 21157
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 07-04-2026.
Fosi Audio ZH3 DAC Preamplifier Balanced Headphone Amplifier AK4493SEQ 32bit 768kHz DSD512
Fosi Audio ZH3 : Front view
The ZH3 from Fosi Audio is a preamp and headphone amplifier that also includes a DAC function. This versatile device is based on four OPA1612 chips to provide 2570mW of amplification under 32Ω per channel and uses an AKM AK4493SEQ DAC chip, allowing it to handle signals up to PCM 32bit 768 kHz and DSD256. Its balanced circuitry, coupled with the control it offers over the final tone, ensures that the ZH3 has a place of honour in many Hi-Fi installations, thanks to both its versatility and the quality of its components.
Fosi Audio ZH3: AKM DAC and XMOS interface
The ZH3 incorporates a series of audiophile-grade components. It includes an XMOS XU316 USB interface coupled with an AKM AK4493SEQ DAC chip, enabling it to support signals up to PCM 32bit 768kHz and DSD512. The power supply circuit features 11 Low Dropout (LDO) regulators to limit fluctuations and ensure a clean power supply for the audio stages.
Fosi Audio ZH3 : Summary of internal components
Fosi Audio ZH3: Balanced amplification circuit
The ZH3's amplification circuit benefits from a fully balanced design, resulting in a noise floor of just 1.9µV and crosstalk of 117dB, contributing to clear reproduction for a detailed final result.
Fosi Audio ZH3 : Circuit diagram
Fosi Audio ZH3 : Power output of 2570mW
Fosi Audio ZH3: Power output of 2570 mW
For its amplification stage, the ZH3 uses four OPA1612 operational amplifiers to achieve a power output of 2570mW at 32Ω per channel. Furthermore, it offers three gain levels, ensuring compatibility with headphones ranging from 16Ω to 300Ω.
Fosi Audio ZH3: Complete control over rendering
To give you maximum control over the sound output, the ZH3 incorporates several basic digital filters as well as customisable bass and treble settings. In addition, it is possible to bypass the tone control circuit entirely if desired, allowing you to minimise the number of signal processing stages.
Fosi Audio ZH3 : screen with bypass function enabled
Fosi Audio ZH3 with other products from the Z range
Fosi Audio ZH3: In line with the Z range
The ZH3 directly echoes the aesthetics of Fosi's Z range, using a distinctive aluminium housing coupled with a beautiful 1.5-inch circular LCD screen that displays all operating information. The design is completed by an attractive orange clickable button that allows you to change the volume or output mode on the fly.
Aperçu du Fosi Audio ZH3
Fosi Audio ZH3 : Product diagram
1LCD screen
24.4mm headphone jack output
36.35mm headphone jack output
4Multifunction knob
5RCA output
6Optical Toslink input
7Trigger input/output
8XLR output
9RCA input
10Coaxial input
11USB-C input
12Power port
Fosi Audio ZH3 review by Audio Science Review
" The ZH3 is an incredible offering with ultra low distortion yet a ton of power. It is attractive in design and capability. Listening performance was a delight even with my less sensitive headphone, […] It is my pleasure to recommend the FOSI ZH3. Company sure has its eye on the ball as far as feature list and performance. "
logo ASR
Product typeDAC
Preamplifier
Headphone amplifier
Inputs1x Stereo RCA
1x Coaxial
1x Optical Toslink
1x USB-C
Outputs1x Stereo RCA
1x Stereo XLR
1x 4.4mm headphone jack output
1x 6.35mm headphone jack output
DAC chipAK4493SEQ
USB interfaceXMOS XU316
OPA4x OPA1612
Supported sampling ratesUSB: PCM up to 32bit 768kHz, Native DSD up to DSD512
Optical: PCM up to 24bit 192kHz
Coaxial : PCM up to 24bit 192kHz
Recommended headphone impedance16-300Ω
Maximum output power2x2570mW(32Ω/THD+N<1%)
Signal-to-noise ratio (SNR)≥ 119 dB
Dynamic range≥ 119 dB
Total harmonic distortion (THD)≤ 0.00018%
Noise floor≤ 4.9μV
Maximum output power2x640mW(32Ω/THD+N<1%)
Signal-to-noise ratio (SNR)≥ 121 dB
Dynamic range≥ 121 dB
Total harmonic distortion (THD)≤ 0.00024%
Noise floor≤ 1.9μV
Power supply12V DC
Dimensions155 x 162 x 50mm
Package1x Fosi Audio ZH3
1x Remote control
1x Mains adapter
1x USB-C to USB-A/C cable
1x 12V trigger cable
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipAK4493SEQ
Max sampling rate768kHz
Max sampling rateDSD512
ClassN/A
Remote ControlYes
4 reviews
Excellent produit
J’ai attendu de l’avoir utilisé quelques semaines avant de donner mon avis
L’usage comme amplificateur casque est le principal atout du ZH3 . Associé à mon Final sonorous il propose une scène musicale large et un style analytique précis mais sans excès.
Naturellement limité dans les graves mais à ce tarif….
Utilisé comme DAC pur il montre ses limites avec mon système amplificateur à tube streamer Volumio : l’image sonore n’est pas très stable même si les timbres restent justes. La puce AK fait un travail remarquable
Bref très bien pour le bureau ou un système secondaire mais avec un système plus ambitieux il faudra un appareil plus consistant
Ce FOSI ZH3 demeure une bonne affaire et semble s’´inscrire dans la philosophie de la marque qui propose des appareils d’entrée de gamme pour le tarif mais aux performances comparables à des produits européens bien plus chers
M.L
This review has been posted for FOSI AUDIO ZH3 DAC Preamplifier Balanced Headphone Amplifier AK4493SEQ 32bit 768kHz DSD512
Fosi ZH3 puikus
Excellent produit, son incroyable ! Je l'utilise avec un casque DT 770 PRO et j'en suis ravi. Sinon, je l'utilise sur PC ou avec un Arylik S10+ et un Icepower 1200 via XLR vers un Dynavoice DM6. C'est un son exceptionnel pour les performances scéniques et en live. Je le recommande vivement.
Fosi ZH3 puikus
Puikus produktas, skamba nuostabiai, naudoju su ausinemis DT 770 PRO, negaliu atsidžiaugti. Kitu variantu klausau PC ar Arylik S10+ su Icepower 1200 per XLR į Dynavoice DM6, nuostabi scena ir gyvi atlikėjai, rekomenduoju.
ottimo!
veloci e precisi
The ZH3 from Fosi Audio is a preamp and headphone amplifier that also includes a DAC function. This versatile device is based on four OPA1612 chips...
