ce joli petit dac offre un son chaud et musical, sans aucune agressivité.
Fosi Audio's ZD3 is a balanced DAC with excellent connectivity thanks to its multiple inputs and Bluetooth 5.0 chip. The digital/analogue conversion is based on an ES9039Q2M chip, which supports PCM up to 32bit 768kHz and DSD up to DSD512. Three DIP8-mounted OPAs can also be replaced if you wish to have a different tone.
In order to deliver the cleanest possible sound, Fosi Audio opted for a symmetrical architecture during the design of the ZD3, drastically reducing the distortion that one channel could create on the other.
Thanks to its ES9039Q2M DAC chip using Hyperstream IV technology and taking advantage of the advanced Sabre HiFi architecture, the ZD3 is capable of handling a PCM signal up to 32bit 768kHz and DSD up to DSD512.
The ZD3 has 5 different inputs, allowing it to adapt to any configuration. Moreover, you can use the HDMI ARC, Optical and Coaxial inputs, each of which accepts a signal up to PCM 24bit 192kHz. You can also use the USB-B input, which accepts PCM 32bit 768kHz and DSD512 thanks to the XMOS XU316 interface used.
The ZD3's Bluetooth QCC3031 chip enables it to support high-resolution codecs for stable, reliable wireless transmission: SBC, AAC, aptX and aptX HD. The ZD3 therefore supports up to PCM 24bit 48kHz, i.e. CD quality in wireless transmission.
The ZD3's amplification stage is based on LME49720 OPAs with an output level of 5Vrms on XLR and 2.5Vrms on RCA. However, as these are DIP8 mounted, you can easily replace them with other OPAs with a different sound profile to adapt the pre-amplification to your tastes.
To ensure the cleanest possible power supply, the ZD3 features a number of very low-noise voltage regulators, ensuring that the power needed to operate the device does not pollute your audio signal.
For automatic power-up of your Hi-Fi system.
For a pure, unaltered signal.
The ZD3 DAC has been specially designed to match one or two of the brand's ZA3 amplifiers. Whether in terms of form factor or electronic components, to get the best out of it aesthetically speaking or for the performance of your Hi-Fi system.
1 | Balanced XLR output |
2 | RCA output |
3 | Trigger in/out |
4 | Toslink optical input |
5 | Antenne Bluetooth |
6 | Coaxial input |
7 | HDMI ARC input (CEC compatible) |
8 | USB-B input |
9 | DC 12V power port |
The ZD3 nails the look and importantly, feature set of what one wants in a low cost DAC. It provides full transparency with excellent noise and distortion. […] It is my pleasure to recommend the Fosi ZD3 balanced stereo DAC.
Product type | DAC |
DAC chip | ES9039Q2M |
OPA | LME49720 |
Inputs | 1x USB-B 1x HDMI ARC (CEC compatible) 1x Coaxial 1x Optical Toslink Bluetooth |
Outputs | 1x Stereo XLR 1x Stereo RCA |
Supported sampling rates | USB : PCM 32bit 768kHz / DSD512 Optical/Coaxial/HDMI : PCM 24bit 192kHz Bluetooth : PCM 24bit 48kHz |
Output level | XLR : 5Vrms RCA : 2.5Vrms |
Signal-to-noise ratio (SNR) | 126dB |
SINAD | ≥ 120dB |
Total harmonic distortion more noise (THD+N) | < 0.00008% |
Dynamic range | ≥ 123dB |
Noise level | ≤ 2μV |
Bluetooth version | 5.0 |
Bluetooth operating range | ≥ 13m |
Supported codecs | aptX HD, aptX, AAC, SBC |
USB compatibility | Windows 7, 8, 8.1, 10, 11 (driver required) Mac OS X Linux |
Power supply | DC 12V 1.5A |
Color | Black |
Package | 1x Fosi Audio ZD3 1x Remote control 1x 12V 1.5A power supply 1x USB-A to USB-B cable 1x Jack 3.5mm trigger cable |
Input | Bluetooth |
Input | USB |
Input | Optical |
Input | HDMI ARC |
Input | SPDIF |
Output | RCA |
Output | XLR |
Color | Black |
Class | N/A |
Remote Control | Yes |
Average votes 5.0 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
patrick a.
Thomas V.
Patrick D.
