GUSTARD A26 DAC 2x AK4499EX XMOS XU216 LAN UPnP Roon 32bit 768kHz DSD512 MQA Black
10%
Gustard unveils with the A26 a high-end DAC, as powerful as versatile. It is based on a high quality architecture, using in particular a dual AK4499EX DAC associated with a AK4191 modulator and a USB XMOS XU216 interface allowing a faithful and rich sound reproduction. It also supports high-resolution audio streams up to PCM 32bit 768kHz, DSD512 and MQA from its USB, I2S and LAN inputs.
4.8 / 5
Reduced price!
Reference : 17144
Limited time offer:
1 499,00 €tax incl.
-10%
1 349,10 €tax incl.
1 124,25 € tax excl.
Shipping date: 30-04-2025.
Gustard A26
Gustard A26 DAC 2x AK4499EX XMOS XU216 LAN UPnP Roon 32bit 768kHz DSD512 MQA
AK4499EX dual DAC
With its two AKM AK4499EX DAC chips and AK4191 digital modulator, the Gustard A26 provides high performance decoding for rich, detailed and accurate sound reproduction. In addition, each channel has its own power supply, which considerably reduces interference that could alter the audio signal.
Streamer / Renderer
The Gustard A26 integrates a network layer with its RJ45 Ethernet input and support for UPnP, Roon Bridge and HQPlayer NAA protocols. It can therefore be used as a streamer and allows you to access your files stored on your network, on a computer or a NAS for example.
K2 Clock
In order to provide an accurate clock signal, the A26 features the ultra-low noise K2 module. This ensures that the DAC is able to achieve a very low jitter level for the most transparent sound possible.
The A26 also provides a 10M BNC input allowing it to be used in conjunction with an external clock generator.
XMOS XU216
The USB input of the Gustard A26 is associated with an XMOS XU216 interface. This allows it to support high resolution audio streams, up to PCM 32bit 768kHz and DSD512. It also supports MQA files.
I/V conversion
The Gustard A26 features an I/V conversion stage using multiple OPAs and transistors. This provides a precise and powerful output.
LPF
An LPF using discrete components was specifically designed to accompany the AK4499EX DACs. This was then carefully optimized to provide the best possible sonic performance.
A customized power supply stage
The A26's power supply stage includes two toroidal transformers to provide independent power supply to the analog and digital circuits. It also uses voltage regulators and filter capacitors, ensuring a clean and stable signal.
MQA
The Gustard A26 can decode and play MQA (Master Quality Authenticated) files. These ensure a sound quality as close as possible to the original studio recording.
Product typeDAC
Inputs1* Optical Toslink
1* AES/EBU
1* Coaxial
1* I2S (HDMI)
1* USB-B
1* RJ45 Ethernet
1* BNC clock input (50Ω)
Outputs1* Single-ended stereo RCA
1* Balanced stereo XLR
DAC chips2* AKM AK4499EX
Digital modulatorAK4191
USB interfaceXMOS XU216
Supported sampling ratesUSB / I2S / LAN: PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256, MQA
AES / Optique / Coaxial: PCM up to 24bit 192kHz, DSD DoP up to DSD64
Network protocolsUPnP
Roon Bridge
HQPlayer NAA
Frequency response20Hz - 20kHz ±0.2dB
Dynamic range> 127dB
SNR> 126dB
Crosstalk-139dB @ 1kHz
THD+N≤ 0.0001% @ 1kHz
IMD≈ 0.001% @ -1dBFS
Output levelRCA : 2.5Vrms (fixed volume) 100Ω
XLR : 5Vrms (fixed volume) 100Ω
Supply voltage (switchable)115V/230V AC 50Hz/60Hz
Consumption< 30W
Dimensions (L*P*H)330*260*65mm
Housing materialAluminum
Pinout I2S
InputRJ45
InputAES/EBU
InputI2S via HDMI
InputClock (BNC)
DAC / ADC ChipAK4499EX
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
NetworkingYes
Remote ControlYes
6 reviews
Top !!
Nachdem ich bereits mehrere andere DACs ( Gustard x26 Gustard R26 und einen Questyle) ausgiebig in meiner Kette getestet hatte und die Firma Gustard fast ausgeklammert hätte, bin ich mit dem Gustard A26 hochzufrieden.
Dieses Gerät liefert eine sehr natürliche, authentische Wiedergabe mit ebensolchen Klangfarben, sehr guter Auflöung und einem ganzheitlich überzeugenden Gesamteindruck.
Klanglich habe ich nichts zu bemängeln. Ich kann damit Musik hören, ohne ständig da und dort mehr oder weniger Defizite verbessern zu wollen. Zuhören ohne Stress ohne in verrundeten Wohlklang abzugleiten.
Den Streamer habe ich nicht ausprobiert, da ich direkt über Macbook Pro und Audirvana höre.
Ich habe eine Hifi - Tuning Feinsicherung in der Gold Ausführung installiert, bzw. gegen die serienmäßige Feinsicherung ausgetauscht. Netzkabel ist das Furutech FP-3TS20. Auch dieses ist sehr empfehlenswert. Leider - wie so vieles - deutlich im Preis gestiegen.
Zurück zum DAC: Dieses Gerät ist in dieser Preisklasse absolut empfehlenswert und vielen anderen - auch R2R DACs überlegen.
Hätte ich den A26 nicht, würde ich wahrscheinlich den A26 schauen, oder dem Gustard X30.
Aber......die Nachfolge der aktuellerern Geräte ist noch lange kein Grund unzufrieden zu sein.
Hören Sie sich den A26 an, wenn sie die Gelegenheit dazu haben!
Die eingangs erwähnten Geräte lässt er locker hinter sich. auch den vielerorts hochgelobten RME DAC.. Ganz zu schweigen von allem was günstiger als Fertiggerät erhältlich ist.
This review has been posted for GUSTARD A26 DAC 2x AK4499EX XMOS XU216 LAN UPnP Roon 32bit 768kHz DSD512 MQA Black
insanely high quality built product, top notch
An absolut fantastic DAC. I love the reproduction of voices, very natural and holografic. One can easily trust the positive reviews on youtube without a doubt. Finally my Pioneer TAD S-3ex front speaker play the music at their best. I am very pleased to highly recommend this product based on my experience.
Grande Musicalité
Après avoir contacté le service clients Audiophonics afin de « déblayer le terrain » avant achat, j’ai décidé d’acquérir cette belle machine et je ne regrette rien. J’ai déjà un Gustard X26 PRO basé sur des puces Sabre. Je ne dirais pas qu’un est meilleur que l’autre, mais ne correspondent pas aux mêmes types de système. Sur mon ampli à tubes ou tout autres amplis a tendance douce, le X26 pro apporte un surcroît de définition, d’attaque. En revanche l’A26 a une coté plus neutre, plus de matière et d’espace. Il n’est surtout ni moue ni anémique, bien au contraire, mais le mariage avec mon gros transistor très vif est bien meilleur. Histoire de goût et de mariage. Il me rappelle beaucoup un dac très haut de gamme que j’ai possédé dans les années 90 ( Métronome Technologie). Vraiment très Musicale dans le sens premier du terme. Aucune partie du spectre n’est mis en avant. Tout est très bien dosé . En 2 mots : ça chante. Encore merci à audiophonics pour sa disponibilité, réactivité et ses bons conseils
Polyvalent
Bonne machine polyvalente.
Je n’ai pas aimé la signature sonore sûr mon système. Cela manquait de matière.
Associer à un système neutre à chaleureux je suis certain qu’il fera des miracles.
Wonderfull AKM DAC in perfect implementation; a diamond waiting to be discovered.
i have bought this DAC some time ago and play only CD and SACD. Use a CD driver from Jay's Audio with upsampler. CD with upsampler button and gustard on NOS filter.. Smooth as it can gets. Combination is really wonderfull. This new AKM dac is a winner. The AKM 4499EX combination in another brand, Cary Audio, Marantz or Esoteric, can bring some upgrade. But this Gustard a26 and Jay Audio shows all the things you need to hear it all. And all in the wright colour and balance. Really natural sounding and with no glare at all. No fatigue. It doesn't downgrade other devices and went along with BW 801 D4, Accuphase C 3900, Mcintosh MC 1.25KW. Alle connected with vd Hull Cumulus 3T. Same goes for the combination with ToneWinner Class A amplifier. Another diamond on the market to be discovered. This AKM in a Gustard is a diamond to be discovered and if it is shows it real worth. Thank you for great service.
Gustard unveils with the A26 a high-end DAC, as powerful as versatile. It is based on a high quality architecture, using in particular a dual...
