GUSTARD X26III DAC Streamer Black
Gustard's X26III is a balanced DAC and streamer based on two top-of-the-range ES9039SPRO DAC chips, offering accurate conversion of PCM up to 32bit 768kHz and DSD up to DSD512, as close as possible to the original. Its extensive connectivity means it can be used in a wide range of configurations. Furthermore, as the X26 takes CelWare 3.x as its software base, it is compatible with Room Bridge, Airplay, HQPlayer NAA, UpnP, mC Mconnect, Bubble UpnP, Spotify and QQMusic protocols.
By buying this product you get 151 loyalty points
Reference : 20217
1 519,00 €tax incl.
1 265,83 € tax excl.
Shipping date: 09-10-2025.
Gustard X26III DAC 2x ES9039SPRO NOS 32bit 768kHz DSD512 Streamers LAN Roon Airplay Upnp Black
Gustard X26III : Front view
Gustard X26III: Dual DAC ES9039SPRO
The X26III uses two ESS ES9039SPRO flagship chips for digital-to-analog conversion, one for each of the left and right channels, each independently powered. These high-end chips enable conversion up to PCM 32bit 768kHz and DSD512. A NOS mode is also available.
Gustard X26III : DAC chip
Gustard X26III : DSP
Gustard X26III: SHARC DSP
The X26III is also equipped with a high-performance digital filtering solution developed on the Analog Device SHARC DSP platform specifically for digital audio, whose main objective is to reduce aliasing noise in the frequency range of digital audio. This filter improves sound quality by increasing the scale and shaping the noise of the raw digital audio signal. The anti-aliasing algorithm and high-precision 64-bit floating-point operation used in this program ensure sound reproduction of pristine quality.
Gustard X26III: Gustard FPGA
Here, Gustard deploys its own FPGA for signal reconstruction, clock signal management, shaping of the second phase-locked loop, DOP demodulation and denoising of PCM and DSD signal switching noise.
Gustard X26III : PFGA Gustard
Gustard X26III : GCLK Clock
Gustard X26III: GCLK internal clock
The X26III uses a GCLK clock module and a high-performance clock frequency synthesizer that uses advanced PLL (Phase Locked Loop) technology to ensure clock signal stability and accuracy. The design of this module allows it to use either a local clock source or an external 10Mhz clock signal, giving you a qualitative and flexible clock solution.
Gustard X26III: Discrete low-pass filter
The low-pass filter at the output of the ES9039SPRO DAC chips has been designed using Class A discrete circuits. This approach enabled Gustard to fine-tune the filter as much as possible during the design phase, resulting in a warm, natural-sounding sound reproduction with non-existent noise and distortion.
Gustard X26III : Low-pass filter
Gustard X26III : compatible network protocols
Gustard X26III: CelWare 3.x
The X26III is based on CelWare 3.x. This OS uses a linux kernel optimized for audio signal input and output, and is compatible with Room Bridge, Airplay, HQPlayer NAA, UpnP, mC Mconnect, Bubble UpnP, Spotify and QQMusic protocols. You can easily activate or deactivate the various protocols by using your PC browser and typing '//x26.local'.
Gustard X26III: XMOS USB interface
The X26III also features a USB XMOS XU216 interface, enabling it to support signals up to PCM 768kHz and DSD512.
Gustard X26III : XMOS chip
Gustard X26III : transformers
Gustard X26III: Power supply
The X26III uses two transformers to supply the digital and analog parts of the device independently, ensuring total absence of interference. Furthermore, each channel benefits from filter capacitors to ensure a stable voltage and an absolute absence of parasitic noise.
Gustard X26III: I2S pinout
Gustard X26III : I2S pinout
Product typeDAC
Streamers
Inputs1x USB-B
1x RJ45
1x HDMI I2S
1x Coaxial
1x AES/EBU
1x Optical Toslink
1x BNC clock input (50Ω)
1x USB-C
1x Balanced stereo XLR
DAC chips2x ES9039SPRO
USB interfaceXMOS XU216
Supported sampling ratesCOAX/AES/OPT: PCM 24bit 192kHz / DSD DOP64 / MQA
USB: PCM 32bit 768kHz / DSD DOP256 /Native DSD512 / MQA
RJ45: PCM 32bit 768kHz / DSD DOP256 /Native DSD512 / MQA
I2S: PCM 32bit 768kHz / DSD DOP256 /Native DSD512 / MQA
Network protocolsRoom Bridge
Airplay
HQPlayer NAA
UpnP
mC Mconnect
Bubble UpnP
Spotify
QQMusic
Frequency response20Hz - 20kHz (±0.3dB)
Dynamic range128dB
Signal-to-noise ratio (SNR)127dB
Crosstalk-132dB @10kHz
Total harmonic distortion more noise (THD+N)≤ 0.0001% @ 1kHz
Intermodulation (IMD)≈ 0.001% @ -1dBFS
Output levelRCA  2.5Vrms (fixed volume)
XLR: 5.1Vrms (fixed volume)
Output impedance100Ω
Power supply voltage115V/230V AC 50Hz/60Hz (Selectable)
Consumption< 25W
Dimensions330 x 260 x 65mm
Weight7kg
Package1x Gustard X26III
1x Remote control
1x USB-A to USB cable-B
1x Power cord
InputAES/EBU
InputI2S via HDMI
InputClock (BNC)
InputRJ45
DAC / ADC ChipES9039MPro / ES9039MSPro
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
NetworkingYes
Remote ControlYes
Streaming services & Network protocolsmC Mconnect
Streaming services & Network protocolsQQMusic
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Streaming services & Network protocolsUpnP
Streaming services & Network protocolsBubble UpnP
Streaming services & Network protocolsHQPlayer NAA
Best DAC I have heard
This is an outstanding DAC. I had previously used a CHORD Mojo 2 in my hi-fi system. That was really good, but the Gustard is a very clear upgrade. It is value for money, too, as it has a built-in streamer that can save you 1.000 EUR for a separate streaming-bridge to match the Gustard DACs sound quality level.
This review has been posted for GUSTARD X26III DAC 2x ES9039SPRO NOS Streamers LAN Roon Airplay UPnP 32bit 768kHz DSD512 Black
Gustard's X26III is a balanced DAC and streamer based on two top-of-the-range ES9039SPRO DAC chips, offering accurate conversion of PCM up to...
