GUSTARD X30 DAC Black
With its X30, Gustard unveils a DAC of exceptional performance and versatility. In fact, this DAC features no less than four ES9039SPRO DAC chips coupled with an ES9311Q linear regulator and a second-generation XU216 USB XMOS interface.
By buying this product you get 299 loyalty points
Reference : 19427
2 999,00 €tax incl.
2 499,17 € tax excl.
Shipping date: 26-08-2025.
GUSTARD X30 DAC 4x ES9039SPRO + ES9311Q  XMOS XU216 Airplay 2 DLNA 32bit 768kHz DSD512 MQA Black
GUSTARD X30 picture
With its X30, Gustard unveils a DAC of exceptional performance and versatility. In fact, this DAC features no less than four ES9039SPRO DAC chips coupled with an ES9311Q linear regulator and a second-generation XU216 USB XMOS interface. This enables it to support high-resolution sampling rates up to PCM 32bit 768kHz, DSD512 and MQA. It also features a preamplifier stage with R2R volume control, as well as an Ethernet LAN port on an RJ45 connector, allowing it to double as a network player. There's also an FPGA with OXCO crystal oscillators and a connector for an external 10MHz clock. The numerous digital and optical inputs include USB, Toslink optical, SPDIF coaxial, I2S via HDMI and a micro SD slot. Two 3.5mm jack triggers complete the package, and output is via stereo RCA or balanced stereo XLR. In terms of design and ergonomics, it features an attractive front panel display and elegant curves, plus a remote control for convenient operation from a distance. This makes the X30 an excellent choice as a sound gateway and a central element in your Hi-Fi system.
GUSTARD X30: XMOS XU216 USB interface and 4x DAC ES9039SPRO + ES9311Q
The Gustard X30 benefits from 4 ES9039SPRO DAC chips coupled with an ES9311Q linear regulator and an XU216 USB XMOS interface. This chip set enables it to support high-resolution streams up to PCM 32bit 768kHz, DSD512 and MQA. The ES9311Q ultra-low-noise linear regulator optimizes the work of the four DAC chips, achieving a dynamic range of over 130dB and an SNR of over 129dB. An analog Class A low-pass filter circuit based on discrete components offers flexibility in adjusting each parameter of the DAC chips, maximizing their performance.
DAC ES9039SPRO chips picture
GUSTARD X30: digital filter
An autonomous DSP SHARC digital filter provides noise reduction thanks to a 64-bit floating-point algorithm and noise-shaping techniques. The X30 also features 4 DSD filters, 3 PCM filters and NOS mode support.
Photo of the GUSTARD X30 DSD chip
Picture of the GUSTARD X30 preamplifier circuit
GUSTARD X30 : passive analog preamplifier
The preamplifier stage features R2R volume control for adjustment without loss of signal quality, and direct connection to a power amplifier or active speakers. A fixed output level is also available if you wish to connect the X30 to an external preamplifier.
GUSTARD X30: network player function
An Ethernet LAN RJ45 port enables the X30 to connect to the network and support Roon, Airplay, DLNA, UPnP, or NAA (Network Audio Adapter). Streaming platforms are thus accessible, notably via an interface developed with Celaudio. This interface has been specially designed to optimize sound rendering with devices combining hardware and software.
Network player function and CELAUDIO interface
GUSTARD X30: a high-end clock system
The X30's clock system features thermostatic OCXO crystal oscillators and a K2 synthesizer. This technology allows the DAC to use only its internal OXCO clock or an external 10MHz clock. The whole unit is accompanied by a FGPA chip for excellent stability.
Photo of the GUSTARD X30 clock system
GUSTARD X30: balanced power supply stage
The X30 benefits from two toroidal transformers that supply the analog and digital parts of the device independently, to avoid any interference. In addition, the power supply for the two DAC channels is separate, with independent voltage stabilizers.
Photo of GUSTARD X30 power supply stage
Gustard X30 overview
GUSTARD X30 overview
110MHz external clock BNC connector
22x I2S via HDMI
3SPDIF Coaxial input
4AES/EBU input
5USB-B input
6RJ45 Ethernet port
72x 110/230V AC mains switch
8Stereo RCA output
9Balanced stereo XLR output
10Toslink optical input
11Trigger IN/OUT
12Slot SD
13IEC power supply
I2S Pins diagram
I2S Pins diagram
Product typeDAC
DAC chip4x ES9039SPRO
Voltage regulatorES9311Q
USB interfaceXMOS XU216
Inputs1x USB-B
1x SPDIF Coaxial
1x Optical Toslink
1x AES/EBU
2x I2S via HDMI
1x SD slot
Outputs1x RCA stereo
1x XLR stereo balanced
Supported sample ratesUSB: PCM 32bit 768kHz, DSD DoP256, DSD512, MQA
SPDIF Coaxial, Toslink optical, AES/EBU: 16-24bit 192kHz, DSD DoP64, MQA
TriggerIn / Out
External clock10MHz via BNC connector (input impedance 50 ohm, 0dBm-20dBm)
CMOS square wave: 0.2V-3.3V
Sine wave: 0.5V-3.3V
Ethernet portLAN RJ45
LAN speed100/1000Mpbs
Supported network protocolsRoon, Airplay, UPnP, NAA
ANALOG OUTPUTS
Frequency response20-20kHz (+/-0.2dB)
Dynamic range> 130dB
SNR> 129dB
Channels crosstalk-139dB @ 10kHz
THD+N< 0.0001% @ 1kHz
IMD0.001% @ -1dbfs
RCA output level2.5Vrms (fixed)
RCA output impedance100 Ohm
XLR output level5.1Vrms (fixed)
XLR output impedance100 ohm
Power supply115/230V AC 50/60Hz
Power consumption< 30W
Dimensions430 x 300x 80mm (92mm with feet)
Weight10kg
Package1x DAC X30
1x Remote control
GUSTARD X30 measurements
InputRJ45
InputAES/EBU
InputMicro SD
InputI2S via HDMI
DAC / ADC ChipES9039MPro / ES9039MSPro
Max sampling rateDSD512
Max sampling rateMQA
Max sampling rate768kHz
NetworkingYes
Remote ControlYes
3 reviews
Gustard X30
First of all I would like to thank Audiophonics for the prompt delivery and exemplary packaging! It was delivered to me in Bucharest between Christmas and the 31'st.
This DAC is nothing short of amazing. I haven't heard anything like it before.
I can't find a single drawback to it's sound, the stage is deep and wide, the timbre is spot on, dynamics are off the charts with big swings and a really potent bass. I've always thought that the bass can't be very tight in my room because I have no treatment installed, but this DAC proved that it was the source that was keeping my system back in this regard. I don't mean to say that room treatment wouldn't help further, but to some this is not an option.
All of the aspects I've stated are impressive, however, the separation of instruments and voices is on a different level and this makes music make sense.
With this DAC I found that songs I thought were poorly recorded were just not reproduced well by my previous DAC.
Regarding the burn in period that lot's of reviewers mention, it sounded great right out of the box and I was happy with my purchase, but it did improve in the first three days.
Build quality is impressive, but the remote is of poor quality. Luckily I don't use it since I have a separate preamp. Regarding the preamp, it sounds a lot better with a preamp, but this might be system dependent. Going into my preamp if I adjust the volume from the Gustard the sound quality is not affected at all so the volume control inside it is good, but If I take my preamp out of the chain the sound is downgraded from all points of view. My preamp (Benchmark HPA 4) has no gain in the range that I use it in, but it has input and output buffering and it makes any DAC I connect to it sound better. If you've never tried a preamp you will still enjoy the upgrade compared to other DAC's connected directly to a power amp, but if you want an impressive upgrade further down the line get a good preamp.
Simply amazing!
This review has been posted for GUSTARD X30 DAC 4x ES9039SPRO + ES9311Q XMOS XU216 Airplay 2 DLNA 32bit 768kHz DSD512 MQA Black
DAC très addictif !
Attention, personne ne vous le dira, ce DAC est hautement hallucinogène, mais heureusement pas toxique ;-) Ce qui frappe d'emblée c'est son caractère organique dénué des artéfacts qui nous accompagnent depuis le début de l'ère digitale. Il faut un certain temps d'adaptation, comme pour se débarrasser d'une mauvaise habitude, après on passe avec aisance de l'autre côté du miroir, on se retrouve dans un espace où chaque son surprend par son réalisme, vous ne vous posez plus de questions d'audiophile insatisfait... Si vous êtes à la recherche d'un DAC hors du commun, celui-ci vous comblera à coup sûr. Musicalement parfait, j'en dirais pas autant de sa télécommande peu en rapport avec le pédigré de l'appareil. Ce DAC est muni d'un potentiomètre à relais, à mon avis fort peu pratique, mais surtout, il enlève une grande part de la magie dont il est capable. A utiliser en position "fixed" pour passer outre et à utiliser avec un préampli haut de gamme. Il se marie très bien avec mes amplis Audiophonics à base de modules Purifi et Sparkos, ils se sont adaptés avec plénitude et extrême fidélité au nouveau chef d'orchestre !
 (5)
Super produit
Bonjour, je remercie tout d’abord les équipes d’Audiophonics pour leurs efforts, le produit est arrivé 48 heures après la commande, la demande a été faite un Lundi, le mercredi je l’ai récupéré au point relai, de mon choix, après avoir été averti par SMS par le transporteur. Le carton du produit était dans un 2ème carton d’Audiophonics, aucune trace ou impacte qui montre que le produit a été mal mené.
Le produit lui même était bien protégé, nickel, livré avec un câble secteur, un câble USB, une carte de garanti, et un mini disque. Le seul hic est qu’il n’y a pas de manuel d’utilisation, surtout pour savoir le fonctionnement du slot mini-SD, qui reste un mystère pour moi. Enfin, j’ai téléchargé un manuel en Anglais, mais le slot SD n’y est pas mentionné.
Je ne suis pas un testeur de DAC, mais je vais essayer de partager ma modeste expérience avec mes mots à moi.
Le Gustard X 30 remplace mon ancien DAC Topping D 90, que j’utilise depuis presque 5 ans. Je vais donc naturellement le comparer à ce dernier, malgré que ce n’est pas la même gamme de prix car le D 90 est 4 fois moins chère que X 30.
Je l’utilise comme un pure DAC, relié par câble USB sur un Mac. Le logiciel est Audirvana, Le X 30 est branché sur un préampli LA-4 de marque Sugden et un bloc de puissance de la même marque SPA-4, fonctionnant en classe A, et une paire d’enceinte de marque B&W 702 S2 à évent arrière, qui est d’ailleurs semi obstrué, à 60 cm du mur postérieur. Mon salon fait 26 mètre carré.
Le filtre courant est de marque Powergrip YG-2, les câbles secteurs et XLR de marque Audioquest, câbles HP sont Silver HD12 HP de chez Viard audio.
J’écoute tous genre de musique, du classic, du jazz jusqu’au musique du monde et même de l’éléctro. Mes fichiers vont du MP3 au DSD 64 et 128, alors attachez vos ceintures car la musique décolle !
La première impression c’est Waouh, Waouh, Waouh, la scène sonore est énorme, et la chose qui attire l’attention c’est le grave, qui rempli la pièce, sans localiser d’où sa vient, j’aurais jamais imaginé que les 702 ont un tel grave, qui est maitrisé, classe A oblige.
Le X 30 a environ 100 heures de fonctionnement, on va dire qu’il est presque rodé en une dizaine de jour.
La scène sonore : Oui la scène sonore est large, elle rempli tout le mur postérieur, avec une certaine image 3D. Les instruments ne sont pas derrière le mur, mais avec une profondeur de 2 mètres environs, le son est projeté plutôt vers l’avant, les différents instruments sont très séparés. Quoi que avec certains enregistrements, on écoute du son derrière le mur, dans les hauts médiums.
La dynamique : Sans blabla, il est très dynamique
Le timbre : Très agréable, mieux que le D 90. Ce qui attire l’attention le timbre de la batterie.
La transparence et les aigus : Oui il y a de la transparence, le son est beaucoup plus détaillé que le D 90, les aigus sont espacés, non agressifs. On entend très bien les coups de fourches du batteur sur les cymbales et même sur les tambours. Les aigus sont là, on les recherche pas. Tout simplement.
Le médium : Dans ce spectre je n’ai pas ressenti beaucoup de différence avec le D 90, qui est connu pour être doux. Ici, nous avons plus d’espace, le timbre des instruments et la voix est beaucoup mieux.
Le grave : Oui il y a du grave, beaucoup plus que D 90. On entend et on sent les vibrations des cordes de la contre basse. Cela me donne l’impression que les graves semblent sortir d’enceintes plus volumineuse, et qu’ils remplissent la pièce, tout simplement.
Le DSD : Je le compare avec mon lecteur Denon BD 2012, sachant que le SACD n’est pas sa fonction principale car il est considéré comme lecteur Blu Ray. L’écoute est complètement différente ! Waouh ! Je le redis..
Le son est totalement différent lorsque j’écoute un même album en résolution 24 bit/192 Khz et en DSD. La différence est vraiment flagrante, croyez moi.
Par ailleurs le changement de résolution lors de l’écoute continue, n’est pas accompagné d’un bruit, contrairement avec D 90, branché en XLR.
Leș filtres PCM : On entend une discrète déformation du son, fruste, lors du passage d’un mode à l’autre, et parfois il est très discret, le mode « Gentil » adoucis relativement l’écoute.
Le Mode NOS : Il reste très subtile. Pour ma pars, j’ai remarqué peu de changement avec mon système actuel.
Voila, j’ai fait comme j’ai pu pour vous partager mon expérience avec ce Gustard X 30. Vous l’avez compris, je suis très content de mon achat, et de l’évolution de mon système.
 (10)
With its X30, Gustard unveils a DAC of exceptional performance and versatility. In fact, this DAC features no less than four ES9039SPRO DAC chips...
