HOLO AUDIO Cyan balanced DAC XLR 384KHz PCM balanded headphone amplifier
An R2R symmetric decoder with and without oversampling dedicated to PCM formats. Independent balanced headphone output. Digital OLED display, USB3 I2S Coaxial, Optical, XLR / RCA & XLR outputs.
By buying this product you get 134 loyalty points
Reference : 12703
1 349,00 €tax incl.
1 124,17 € tax excl.
Discover the new AUDIO R2R DAC CYAN 2 here.
Holo Audio - Cyan DAC R2R
 Symmetric DAC & Headphone Amplifier PCM 24 bit 384KHz
DAC & Headphone Amplifier Audio Holo
Finesse in audio decoding
Inputs and outputs Audio DAC CYAN Holo
The Cyan at Holo Audio offers the capabilities of decoding a DAC owner discrete component based on the so-called DAC R2R ladder technology. A calibrated digital stage for supplying symmetrical high-quality analog output.
 The DAC is itself natively capable of operating a DSD conversion> PCM DSD256 up and will thus not limited by audio format issues. Similarly, possibilities of digital decoding make a Swiss Army knife since the decoding is possible to switch between decoding without oversampling, or oversample up to 384kHz. As many convenient options to refine compliance Foncton signal characteristics of other elements of the chain. Cyan so effectively prevent much of the unwanted colorations.
High Fidelity Headphone Amplifier
Headphone output CYAN
In the version PCM, Cyan is built around two distinct symmetrical circuits that provide a net signal and high accuracy as well as to the headset to the amplifier. Far from being a secondary feature, the headphone output meets the same quality of exigeances that the link connecting the analog digital converter to the amplifier. It is an excellent option for those who sail regularly between listening to the speakers and headphones. Cyan is quite suitable for headphones and in-ear systems demanding and can easily feed helmets at the highest level and high impedance. .
From the device menu, you can choose between low and hi fashion that will take into account the specific characteristics of different helmets that will be submitted to nvoyer a suitable signal.
High-quality components
The DAC Cyan incorporates advanced components for an enhanced audio experience.
Its XMOS unit U8 USB 3.0 benefits of galvanic isolation and clocks with a very low drift with phase-locked loop adjusted to a reduced jitter, even with very demanding digital resolution.
Cyan Audio DAC inside Holo
Holo Audio Remote Control
cyan remote holo audio dac R2R
Cyan's remote is able to control the device in its most common functions. You can enable and disable remote oversampling, mutate and Unmute the audio, change the screen display, increase / decrease the volume, input selection, select actrive output.
This remote, very robust, mainly benefits a formidable design that uses the warm gilding and copper Cyan.
TypeDAC / Headphone Amp
InputUSB 3 / Coaxial / Optical / AES / EBU / I2S (HDMI)
OutputXLR and RCA (symmetrical) / Headset (symmetrical 4 pin XLR)
CYAN modelPCM
volume controlYes (digital) - all output
Selection OS / NOSYes (OUR 48k)
oversampling PCM352.8 or 384K (32 bit)
Selection high impedance / low headphonesYes
THD + N @ 1k0.0001%
SNR-125dB
THD + N @ 1K Headset0.0015%
SNR-120dB
Low impedance load (asymmetric)400mW @ 32ohm
Low impedance load (balanced)1600mW @ 32ohm
high impedance load (asymmetric)300mW
Low impedance load (balanced)3000mW
Dimensions260x281x55 mm
Weight4.75g
Parts supplied
Power cablex1
Infrared Remote Controlx1
USB-A male to USB-B male cablex1
InputXLR
InputI2S via HDMI
InputHDMI
DAC / ADC ChipR2R LADDER DAC
Max sampling rate384kHz
ColorGold
An R2R symmetric decoder with and without oversampling dedicated to PCM formats. Independent balanced headphone output. Digital OLED display, USB3...
