By buying this product you get 22 loyalty points
With the ZEN V3, Ifi Audio presents a new version of its successful ZEN series. The brand's ambition is still to offer a digital/analog converter offering exceptional performance at the lowest possible price. This V3 version builds on the success of its predecessor, while integrating a Burr-Brown DAC chip capable of supporting a 768kHz sampling rate.
The heart of the Zen V3 is a Burr-Brown DAC chip supporting a sampling rate up to 768 kHz, DSD512 and capable of decoding MQA files. Moreover, thanks to the Burr-Brown chip, the manufacturer's True Native architecture enables "bit-perfect" transmission, ensuring sound reproduction as close as possible to the original recording. Furthermore, Zen V3 is equipped with an ultra-quiet, ultra-clean audiophile-grade power supply, featuring Active Noise Cancellation II technology that cancels out all incoming EMI and RFI noise.
In addition to being an excellent DAC, the Zen V3 also has the good grace to offer a headphone amplifier stage. With an output power of 390mW and two headphone outputs (4.4mm and 6.3mm jacks), it can drive the vast majority of headphones on the market. Furthermore, the brand's proprietary Xbass+ and PowerMatch technologies offer analog bass boost, perfect for certain open headphones, and an increased gain level for the most demanding headphones.
Ifi Audio's Zen V3 is designed to be as flexible as possible. Thus, in addition to the two headphone outputs (balanced and unbalanced) on the front panel, there's a switch on the back offering volume control bypass. This allows the Zen V3 to be used directly with active speakers, or connected as an input to an amplifier. Finally, the Zen V3 can be powered via the USB-C input for easy cable management, but if you decide to power it via a DC jack, then the USB-C input becomes capable of receiving data.
Product type | DAC Headphone amplifier |
DAC Chip | DAC by Burr-Brown |
USB Interface | XMOS 16 coeurs |
Input | 1x USB-C |
Outputs | 1x RCA Line output 1x Balanced Jack 4.4mm line output 1x Single-Ended Jack 6.35mm headphone output 1x Balanced Jack 4.4mm headphone output |
Supported sampling rates | PCM up to 768kHz DSD up to DSD512 DXD up to 768kHz MQA |
LINE OUTPUTS CIRCUIT | |
Output level | Single-ended RCA : Fixed = 2.1V, Variable = 1V / 3.3V max Balanced Jack 4.4mm : Fixed = 4.2V, Variable = 2V / 6.2V max |
Output impedance | Single-ended : ⩽100Ω Balanced : ⩽200Ω |
Signal-to-noise ratio (SNR) | ≥ 113dBA @ 0dBFS |
Dynamic range (DNR) | ≥ 113dBA @ 0dBFS |
Total harmonic distortion (THD) | Single-ended : ⩽0.003% @ 0dBFS Balanced : ⩽0.0015% @ 0dBFS |
HEADPHONE OUTPUTS CIRCUIT | |
Output power | Single-ended : 210mW @ 32Ω Balanced : 390mW @ 64Ω |
Output impedance | ⩽ 1Ω |
Signal-to-noise ratio (SNR) | ≥ 109dBA @ 0dBFS |
Dynamic range (DNR) | ≥ 109dBA @ 0dBFS |
Total harmonic distortion (THD) | Single-ended : ⩽0.013% @ 32Ω 1.27V Balanced : ⩽0.005% @ 600 Ω 2V |
Consumption | ⩽2.5W |
Power Supply | USB-C 5V DC |
Dimensions | 158 x 115 x 35mm |
Weight | 456g |
Package | 1x Ifi Audio Zen V3 1x RCA cable 1x USB-A to USB-C cable |
Input | USB |
Output | RCA |
Output | Jack 4.4mm |
Output | Jack 6.35mm |
DAC / ADC Chip | NC |
Max sampling rate | DSD512 |
Max sampling rate | MQA |
Max sampling rate | 768kHz |
Color | Black |
Class | Class D / T |
Networking | No |
Remote Control | No |
