LUXSIN X9 DAC Headphone Amplifier
New
The Luxsin X9 DAC headphone amplifier was developed by Eversolo and benefits from the brand's expertise. It incorporates top-quality components, enabling it to achieve a very high level of performance.
By buying this product you get 109 loyalty points
Reference : 20747
1 099,00 €tax incl.
915,83 € tax excl.
Shipping date: 18-07-2025.
Luxsin X9 DAC Headphone Amplifier AK4191 + AK4499EX Bluetooth 5.0 32bit 768kHz DSD512
Luxsin X9 picture
The Luxsin X9 DAC / headphone amplifier was developed by Eversolo and benefits from the brand's expertise. It incorporates top-quality components, enabling it to achieve a very high level of performance. Its DAC is based on a combo of AKM AK4191 + AK4499EX chips, and its USB XU316 interface supports high-definition sampling rates up to PCM 32bit 768kHz and DSD512. In terms of amplification, it features OPA1612 AOPs combined with a TPA6120A2 amplifier chip within a DNF (Dynamic Negative Feedback) structure that reduces distortion and improves signal linearity and stability for the most pleasing rendering. Numerous additional features are also available, such as Bluetooth 5.0 thanks to a Qualcomm QCC5125 chip and the ability to adjust rendering thanks to an AK7739 DSP chip. As for its connectivity, the Luxsin X9 is not to be underestimated, with various digital and analog inputs, three headphone outputs and two line/preamplifier outputs.
Luxsin X9 highlights
Luxsin X9: AKM DAC combo
The Luxsin X9 benefits from an AKM AK4191 + AK4499EX chip combo and an Accusilicon femtosecond clock, offering clear, precise sound reproduction with a THD+N of -120dB. Moreover, thanks to its XMOS XU316 USB interface, it supports high-resolution sampling rates up to PCM 32bit 768kHz and DSD512. Meanwhile, the analog and digital stages are each powered separately to guarantee uncompromised audio performance.
AKM chips in the Luxsin X9
Luxsin X9 R2R volume control
Luxsin X9: R2R volume control
The Luxsin X9's volume control circuit is an R2R circuit made from high-precision components. It adjusts the left-right channel balance to an exceptional accuracy of 0.1dB, guaranteeing precise, distortion-free audio performance.
Luxsin X9: an smart headphone amplifier
The Luxsin X9's AK7739 DSP provides advanced, customizable audio signal management. In particular, it supports the automatic equalization function for headphones (HP-EQ). In fact, the Luxsin has a database of over 2,500 headphones references, automatically adjusting the equalization curve to match the Harman reference curve. It goes without saying that it is also possible to fully customize the sound rendering. But that's not all, as this chip also automatically measures the impedance of headphones connected to the X9 to adjust the output stage for optimum audio performance.
Luxsin X9's strengths as a headphone amplifier
Luxsin X9: preamplifier with subwoofer output
As well as its DAC and headphone amplifier functions, the X9 offers a preamplifier mode on its RCA and XLR outputs, thanks to a circuit providing up to 10dB of gain rather than just volume attenuation. Furthermore, the rear panel features an RCA output for a subwoofer, offering the possibility of a 2.1-channel system for an immersive experience. The totality of the X9's functions positions it as a central and indispensable device within any sound system.
Photo of Luxsin X9 and its subwoofer output
Luxsin X9: 1080P display
To top it all off, the X9 features a beautiful 4” color display. This high-definition 1080p screen displays a wealth of information on the current playback, and provides access to the device's settings. In addition, the user can choose between different meter displays.
Photo of Luxsin X9 screen
Luxsin X9 overview
Luxsin X9 overview
1Balanced XLR 4 pin headphones output
2Single-ended 6.35mm jack headphone output
3Balanced 4.4mm jack headphones output
4Display
5Multifunction potentiometer
6Power on/off
7Power on / IEC power supply
8Trigger IN/OUT
9USB-C input / USB-A update port
10USB-B input
11HDMI ARC input
12Bluetooth antenna
13WiFi antenna
14Coaxial input
15Toslink optical input
16RCA input
17Subwoofer output
18XLR output (Line/Preamp)
19RCA output (Line/Preamp)
Luxsin X9 test by Audio Science Review
"Compared to typical high-end DACs though, the X9 is much cheaper and far more functional. I am going to recommend the Luxsin X9."
Product typeDAC / Headphone amplifier
Preamplifier
DAC chipAKM AK4191+AK4499EX
USB interfaceXMOS XU316
DSP chipAK7739
OPAOPA1612
Amplification chipTPA6120A2
Bluetooth chipQCC5125
Inputs1x USB-C
1x USB-B
1x HDMI ARC
1x Toslink optical
1x Coaxial
1x Stereo RCA
Outputs1x Single-ended 6.35mm jack headphone output
1x Balanced 4.4mm jack headphone output
1x Balanced XLR 4-pin headphone output
1x RCA output (line/preamp)
1x XLR output (line/preamp)
1x Subwoofer output (RCA)
Supported sample ratesUSB: PCM up to 32bit 768kHz, DSD up to DSD512
Toslink optical / Coaxial: PCM up to 24bit 192kHz, DSD up to DoP64
HDMI ARC: PCM 24bit 192kHz
Supported Bluetooth codecsSBC, AAC
RCA input gainMax. +10dB
Analog output interfaceXLR + RCA or RCA + Subwoofer output
Touch screen4" 1080P color
OS compatibitliyUSB : Windows (10, 11), Android, iOS
WiFi
Luxsin App control application
XLR output specifications
Output level4.2Vrms @ 0dBFS
Frequency response20Hz~20KHz (±0.25dB)
Dynamic range> 128dB
SNR> 128dB
THD+N< 0.000096% (-120.3dB) @ Unweighted
Crosstalk> -117dB
RCA output specifications
Output level2.1Vrms @ 0dBFS
Dynamic range>125dB
SNR>125dB
THD+N<0.00010% (-119dB) @ Unweighted
Crosstalk>-114dB
Headphone outputs specification
Output level4-15Vrms @ 0dBFS
SNR> 128dB
THD+N< 0.00016% (-116dB) @ Unweighted
Power supplyAC 100-240W 50/60Hz
Dimensions300 x 206 x 65mm
Weight3.72kg
ColorSilver
Package1x Luxsin X9
1x Remote control
1x Power supply cable
InputHDMI ARC
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipAK4499EX
Max sampling rate768kHz
Max sampling rateDSD512
ColorSilver
ClassClass A / AB
Remote ControlYes
LUXSIN X9 DAC Headphone Amplifier AK4191 + AK4499EX Bluetooth 5.0 32bit 768kHz DSD512
The Luxsin X9 DAC headphone amplifier was developed by Eversolo and benefits from the brand's expertise. It incorporates top-quality...
