Balanced DAC ES9038Q2M Class A Headphone Amplifier Bluetooth 5.0 32bit 768kHz DSD512
The Original Audio OPA-Q3.1 is a balanced Class A DAC and headphone amplifier combo. Its digital to analog conversion stage uses an ESS ES9038Q2M DAC chip known for its ability to provide accurate and transparent playback and to support high sampling rates, up to PCM 32bit 768kHz, DSD512 and DoP256. The tube headphone amplifier stage allows to develop a comfortable power with a high current, offering the OPA-Q3.1 the possibility to accompany many headphones, whether they are high sensitivity or low impedance models, all with a beautiful dynamic and musicality.
For its connectivity, the OPA-Q3.1 offers USB-B, coaxial and an analog RCA stereo input, but also integrates a Bluetooth 5.0 receiver supporting the high definition transmission codecs aptX HD and LDAC. It is therefore possible to broadcast music remotely, from a smartphone for example, while maintaining excellent sound quality. On the output side, we can count on a stereo RCA line output as well as three headphone outputs: single-ended 6.35mm jack, balanced XLR 4-pole and balanced 4.4mm jack.
Product type | DAC Class A Headphone amplifier |
Inputs | Bluetooth 5.0 1x USB-B 1x Coaxial 1x Stereo RCA |
Outputs | 1x Stereo RCA 1x Single-ended Jack 6.35mm headphone output 1x Balanced Jack 4.4mm headphone output 1x XLR 4 pins headphone output |
Supported Bluetooth codecs | SBC, AAC, aptX, aptX LL, aptX HD, LDAC |
DAC Chip | ESS ES9038Q2M |
Supported sampling rates | USB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DoP256 Coaxial : PCM up to 24bit 192kHz, DSD DoP64 |
SNR | Line in : > -100dB (A-Weighted) Line out : > -120dB (A-Weighted) Single-ended headphone output : > -120dB @ 2Vrms Balanced headphone output : > -122dB @ 4Vrms |
THD+N | Line in : < 0.002% @ 1kHz, < 0.003% @ 20Hz-20kHz Line out : < 0.0002% @ 1kHz, < 0.00028% @ 20Hz-20kHz Single-ended headphone output : < 0.0003% @ 3Vrms Balanced headphone output : < 0.0003% @ 6Vrms |
Input amplitude (Line in) | Max. 1.5Vrms |
Output amplitude (Line out) | Max. 3Vrms @ 0dB |
Crosstalk (Line out) | > -130dB |
Frequency response | 20Hz-20kHz, -3dB @ 260kHz |
Headphone output impedance | < 100Ω |
Headphone output power | Single-ended : 1W @ 32Ω, 200mW @ 300Ω, 90mW @ 600Ω (0.5% THD) Balanced : 3W @ 32Ω, 600mW @ 300Ω, 270mW @ 600Ω (0.5% THD) |
Headphone output gain | Single-ended : +17dB Balanced : +30dB |
Housing material | Aluminum |
Color | Black |
Power supply | 220V 50Hz |
Input | USB |
Input | SPDIF |
Input | RCA |
Input | Bluetooth |
Output | Coaxial SPDIF |
Output | Jack 4.4mm |
Output | RCA |
Output | Jack 6.35mm |
DAC / ADC Chip | ES9038Q2M |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Black |
Class | Class A / AB |
Networking | No |
Remote Control | N/A |
