ORIGINAL AUDIO OPA-Q3.1 Balanced DAC ES9038Q2M Class A Headphone Amplifier Bluetooth 5.0 32bit 768kHz DSD512
The Original Audio OPA-Q3.1 is a balanced Class A DAC and headphone amplifier combo. Its digital to analog conversion stage uses an ESS ES9038Q2M DAC chip known for its ability to provide accurate and transparent playback and to support high sampling rates, up to PCM 32bit 768kHz, DSD512 and DoP256. The tube headphone amplifier stage allows to develop a comfortable power with a high current, offering the OPA-Q3.1 the possibility to accompany many headphones, whether they are high sensitivity or low impedance models, all with a beautiful dynamic and musicality.
Reference : 16340
699,00 €tax incl.
582,50 € tax excl.
Last items in stock !
Shipping date: 06-05-2025.
Original Audio OPAQ3.1 DAC ES9038Q2M Amplificateur Casque Symétrique Class A Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512
For its connectivity, the OPA-Q3.1 offers USB-B, coaxial and an analog RCA stereo input, but also integrates a Bluetooth 5.0 receiver supporting the high definition transmission codecs aptX HD and LDAC. It is therefore possible to broadcast music remotely, from a smartphone for example, while maintaining excellent sound quality. On the output side, we can count on a stereo RCA line output as well as three headphone outputs: single-ended 6.35mm jack, balanced XLR 4-pole and balanced 4.4mm jack.
Product typeDAC
Class A Headphone amplifier
InputsBluetooth 5.0
1x USB-B
1x Coaxial
1x Stereo RCA
Outputs1x Stereo RCA
1x Single-ended Jack 6.35mm headphone output
1x Balanced Jack 4.4mm headphone output
1x XLR 4 pins headphone output
Supported Bluetooth codecsSBC, AAC, aptX, aptX LL, aptX HD, LDAC
DAC ChipESS ES9038Q2M
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DoP256
Coaxial : PCM up to 24bit 192kHz, DSD DoP64
SNRLine in : > -100dB (A-Weighted)
Line out : > -120dB (A-Weighted)
Single-ended headphone output : > -120dB @ 2Vrms
Balanced headphone output : > -122dB @ 4Vrms
THD+NLine in : < 0.002% @ 1kHz, < 0.003% @ 20Hz-20kHz
Line out : < 0.0002% @ 1kHz, < 0.00028% @ 20Hz-20kHz
Single-ended headphone output : < 0.0003% @ 3Vrms
Balanced headphone output : < 0.0003% @ 6Vrms
Input amplitude (Line in)Max. 1.5Vrms
Output amplitude (Line out)Max. 3Vrms @ 0dB
Crosstalk (Line out)> -130dB
Frequency response20Hz-20kHz, -3dB @ 260kHz
Headphone output impedance< 100Ω
Headphone output powerSingle-ended : 1W @ 32Ω, 200mW @ 300Ω, 90mW @ 600Ω (0.5% THD)
Balanced : 3W @ 32Ω, 600mW @ 300Ω, 270mW @ 600Ω (0.5% THD)
Headphone output gainSingle-ended : +17dB
Balanced : +30dB
Housing materialAluminum
Power supply220V 50Hz
OutputCoaxial SPDIF
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipES9038Q2M
Max sampling rate768kHz
Max sampling rateDSD512
ClassClass A / AB
Remote ControlN/A
The Original Audio OPA-Q3.1 is a balanced Class A DAC and headphone amplifier combo. Its digital to analog conversion stage uses an ESS ES9038Q2M...
