QUESTYLE CMA 18 MASTER DAC Headphone Amplifier
Questyle's CMA 18 MASTER DAC/headphone amplifier is a high-performance device featuring top-of-the-range components. It incorporates an ES9039PRO DAC chip and an XMOS XU-316 USB interface, enabling it to support sampling rates up to PCM 32bit 768kHz and native DSD up to DSD512.
By buying this product you get 299 loyalty points
Reference : 19580
2 999,00 €tax incl.
2 499,17 € tax excl.
Questyle CMA 18 Master DAC ES9039PRO Headphone Amplifier Bluetooth aptX LDAC 32bit 768kHz DSD512
QUESTYLE CMA 18 MASTER picture
Questyle's CMA 18 Master DAC/headphone amplifier is a high-performance device featuring top-of-the-range components. It incorporates an ES9039PRO DAC chip and an XMOS XU-316 USB interface, enabling it to support sampling rates up to PCM 32bit 768kHz and native DSD up to DSD512. Added to this is Bluetooth functionality for reception of high-definition codecs such as aptX HD and LDAC, as well as Questyle's patented current mode amplification technology. This amplification technology enables it to reach up to 2W into 32 ohms on its balanced headphone output, and a preamplified line output level that can be boosted with the use of studio mode. The CMA 18 Master offers a complete connectivity with digital/optical inputs, an RCA input, headphone outputs and RCA and XLR line outputs.
Questyle CMA 18 Master: ES9039 PRO DAC and XMOS XU316 USB interface
The Questyle CMA 18 Master, with its ES9039PRO DAC chip and XMOS XU-316 USB interface, supports sampling rates up to PCM 32bit 768kHz and native DSD up to DSD512. The ES9039Pro DAC is a 32-bit, 8-channel chip featuring a Hyperstream IV DAC architecture specially designed for professional audio applications.
Questyle CMA 18 Master: current-mode amplification
The Questyle CMA 18 Master benefits from the brand's patented current-mode amplification technology using discrete components. The headphone amplification and preamplification circuits are independent to ensure high performance and low distortion. The headphone amplifier circuit benefits from a fully balanced architecture, coupled with ALS analog potentiometers for optimum sound reproduction that will get the best out of your headphones. All components are incorporated on a military-grade PCB for optimum heat dissipation.
Circuit picture of the QUESTYLE CMA 18 MASTER
Questyle CMA 18 Master: high-definition Bluetooth
The Questyle CMA 18 Master supports high-definition Bluetooth codecs like aptX, aptX HD and LDAC for an excellent audio quality, even wireless.
Questyle CMA 18 Master: a carefully designed power supply stage
The power supply for the digital circuit and the amplifier/converter circuit is independent, for optimized signal processing. An independent NORATEL toroidal transformer and Schottky rectifier provide the cleanest power supply for the analog side of the DAC.
QUESTYLE CMA 18 MASTER power supply stage
Questyle CMA 18 Master overview
QUESTYLE CMA 18 MASTER overview
1ON/OFF Button
2Indicator LEDs
3Source selector
4DAC / HP AMP operating mode
5Gain control Standard / High
6Balanced 4.4mm headphone output
76.35mm jack headphone output
8Balanced XLR 4-pin headphone output
9Volume control
10USB-B input
11Toslink optical input
12USB-C input
13SPDIF coaxial input
14Stereo RCA input
15Line output gain Standard / Studio mode
16Line output selector Fixed / ADJ (volume control)
17Stereo RCA line output
18Balanced XLR stereo line output
19Bluetooth pairing button
20AC 110/220V power selector switch
21IEC power supply
Product typeDAC Headphone amplifier
Dadc chipES9039PRO
Amplification technologyCurrent-mode amplification (CMA)
Inputs1x USB-C
1x USB-A
1x Optical Toslink
1x Optical coaxial
1x RCA stereo
Bluetooth
Outputs1x Balanced 4.4mm jack headphone output
1x 6.35mm jack headphone output
1x Balanced XLR 4-pin headphone output
1x RCA line output
1x Balanced XLR line output
Supported sample ratesUSB : PCM up to 32bit 768kHz, DSD DoP up to DoP256, Native DSD up to DSD512
Optical Toslink / SPDIF Coaxial : PCM up to 24bit 192kHz
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC (24bit 96kHz / 990kbps)
Headphone output gain adjustment
Preamp output volume control
CompatibilityWin XP/Vista/7/8/10/11, Linux, Android, HarmonyOS, macOS, iOS
HEADPHONE AMPLIFIER SPECIFICATIONS
Max. output power6.35mm jack: 188mW @ 300 ohm / 1.5W @ 32 ohm
Balanced headphone outputs: 765mW @ 300 ohm / 2W @ 32 ohm
THD+N< 0.0003%
Frequency response+/-0.2dB (DC-22kHz) @ 24bit 48kHz
SNR6.35mm jack: 117dB
Balanced headphone outputs: >120dB
PREAMPLIFIER SPECIFICATIONS
Max. output levelRCA : 2V (Standard) / +14dBu (Studio mode)
XLR : 4V (Standard) / +20dBu (Studio mode)
THD+N< 0.0003%
SNRRCA : >116dB XLR : >119dB
Power supplyAC 110-240V (selector switch available on rear of unit)
Weight3.5kg
Dimensions330 x 220.2 x 56mm
Package1x Questyle CMA 18 Master
1x USB-C to USB-C cable
1x Remote control
1x Power supply cable
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipES9039MPro / ES9039MSPro
Max sampling rate768kHz
Max sampling rateDSD512
ClassN/A
Remote ControlYes
QUESTYLE CMA 18 MASTER DAC ES9039PRO Headphone Amplifier Bluetooth aptX LDAC 32bit 768kHz DSD512
Questyle's CMA 18 MASTER DAC/headphone amplifier is a high-performance device featuring top-of-the-range components. It incorporates an...
