SABAJ D5 DAC ES9038Pro Headphone Amplifier Balanced XMOS Altera 32bit 768kHz DSD512
The Sabaj D5 is a solution that acts as both a DAC and a headphone amplifier. It ensures excellent performance, thanks to a careful architecture and components selected for their audio qualities. It also offers balanced outputs to integrate into all audio systems and enjoy a rich and detailed sound reproduction.
By buying this product you get 44 loyalty points
Reference : 15655
449,00 €tax incl.
374,17 € tax excl.
Sabaj D5
DAC Headphone Amplifier Balanced ES9038Pro XMOS Altera 32bit 768kHz DSD512
Sabaj D5 DAC Amplificateur Casque Symétrique ES9038Pro XMOS Altera 32bit 768kHz DSD512
ESS ES9038Pro DAC
The D5's digital-to-analog conversion stage uses an excellent ESS ES9038Pro chip, known for its audio performance and its ability to reproduce transparent and neutral sound. A chip that offers particularly interesting measurements, including a dynamic range of 140dB. In addition, this chip supports high resolution streams, up to PCM 32bit 768kHz and DSD512.
High-end components for incredibly accurate sound
All the circuits and stages of the D5 are equipped with high quality components. We find in particular an ESS ES9311 ultra low noise linear voltage regulator and a high efficiency sealed transformer, an XMOS XU208 32bit USB interface supporting 32bit 768kHz and DSD512 streams, four OPA1612 AOPs, an Altera MAX II CPLD associated with NDK oscillators as well as numerous discrete components in the headphone amplifier and the analog circuit.
1Single-ended Jack 6.35mm headphone output
2Balanced XLR 4 polesheadphone output
3Screen
4IR Receiver
5ON/OFF LED Indicator
6Push button
7Rotary knob
8Balanced line XLR output
9Single-ended line RCA output
10Coaxial input
11USB-B input
12Optical Toslink input
13I2S via HDMI input
14Supply voltage switch
15Power connector
16Fuse
17Power button
Sabaj D5 Test by Audio Science Review
"The Sabaj D5 is a very well-engineered DAC and headphone amplifier. It nearly outperforms every DAC I have ever tested! The ESS ES9038Pro when implemented well (which is not common) brings stunningly low levels of distortion which shows here."
Test du Loxjie A30 par Audio Science Review
Product typeDAC
Headphone amplifier
DAC ChipESS ES9038Pro
Inputs1x USB-B
1x Optical Toslink
1x Coaxial
1x I2S via HDMI
Outputs1x Balanced stereo XLR line output
1x Single-ended stereo RCA line output
1x Balanced XLR 4 poles headphone output
1x Single-ended stereo Jack 6.35mm headphone output
THD+NDAC : 0.0002%
headphone output : 0.001%
Dynamic rangeXLR : 127dB
RCA : 124dB
SNRDAC : 120dB
headphone output : 110dB
USB Transmission modeAsynchronous
USB CompatibilityWindows 7 / 8 / 8.1 / 10
Mac OSX 10.6 or later
Linux
Supported sampling ratesUSB / I2S : PCM up to 32bit 768kHz, Native DSD Natif up to DSD512
Optical / Coaxial : PCM jusqu'à 24bit 192kHz, DSD DoP jusqu'au DSD64
Headphone output powerBalanced : 1912mW @ 32Ω / 1025mW @ 64Ω / 455mW @ 150Ω / 231mW @ 300Ω
Single-ended : 480mW @ 32Ω / 265mW @ 64Ω / 115mW @ 150Ω / 58mW @ 300Ω
Supply voltage100-240VAC
Consumption8W
Standby consumption0.6W
Dimensions245 x 210 x 50mm
Weight2.5kg
Package1x Sabaj D5
1x Remote control
1x USB cable
1x Power cable
InputI2S via HDMI
OutputJack 6.35mm
ClassN/A
Remote ControlYes
2 reviews
Excellent
Très bon Dac qui pilote une paire d'ampli mono NCORE en mode symétrique.
Beaucoup de détail, très droit, voix superbes.
Je recommande.
This review has been posted for SABAJ D5 DAC ES9038Pro Headphone Amplifier Balanced XMOS Altera 32bit 768kHz DSD512
Excellent resultat d'écoute
Un DAC qui transpire la qualité de fabrication. Il n'est pas en reste pour les résultats sonores.
Merci pour le conseil.
J'ai quelques difficultés pour paramétrer FOOBAR pour la lecture des DSD en direct (sans passage en PCM). Avez vous un tutoriel.
Cordialement
The Sabaj D5 is a solution that acts as both a DAC and a headphone amplifier. It ensures excellent performance, thanks to a careful architecture...
