By buying this product you get 36 loyalty points
With the EH2, Shanling presents a desktop DAC and headphone amplifier that's intended to be the successor to the Shanling HE1. This evolution incorporates digital/analog conversion via an R2R ladder resistor network developed directly in-house by the brand, in order to approach the sound rendering of the PCM1704 chip. As a result, this DAC can process signals up to PCM 32bit 768kHz and DSD512. The amplification stage is based on transistors and offers an output power of 4.32W at 32Ω.
For its EH2, Shanling decided to develop its own custom DAC. The R2R 24bit DAC takes its inspiration from the legendary PCM1704 DAC chip, enabling digital-to-analog conversion of signals up to PCM 32bit 768kHz and DSD512, while offering sound reproduction with a characteristic analog tone. Furthermore, a NOS mode is also available, allowing you to enjoy your tracks as close to the original as possible.
The HE02's amplifier stage relies on BD139 and BD140 transistors for an output power of 4.32W into 32Ω for the balanced headphone output and 1.28W into 32Ω for the Single-ended headphone output. Furthermore, the line output is also equipped with an OPA 1612 to provide an output level of 4.5V balanced and 2.2V single-ended.
The EH2 also offers more extensive connectivity than its predecessor. It features a Toslink optical input, a coaxial input and a USB-C input. The latter is equipped with an XMOS XU316 interface that supports signals up to PCM 32bit 768kHz and DSD512. Furthermore, the EH2 features Bluetooth 5.2 connectivity thanks to Qualcomm's QCC5125 chip, allowing you to connect wirelessly while maintaining excellent quality thanks to support for LDAC, aptX, aptX HD and aptX Adaptive high-definition codecs.
Product type | DAC Headphone amplifier |
DAC | R2R 24bit |
Supported sampling rates | PCM up to 32bit 768kHz DSD up to DSD512 |
Amplification | BD139 BD140 AOP 1612 |
Inputs | 1x USB-C 1x Optical Toslink 1x Coaxial Bluetooth 5.2 |
Outputs | 1x Balanced headphone output 4.4mm jack 1x Single-ended headphone output 6.35mm jack 1x Balanced line output 4.4mm jack 1x Single-ended line output RCA |
USB interface | XMOS XU316 |
Bluetooth chip | Qualcomm QCC5125 |
Supported Bluetooth codecs | SBC AAC aptX aptX Low Latency aptX HD aptX Adaptative LDAC |
Headphone outputs | |
Output power 4.4mm Jack | Low gain: 2365mW @ 32Ω High gain: 4351mW @ 32Ω |
Output power 6.35mm Jack | Low gain: 632mW @ 32Ω Hight gain: 1280mW @ 32Ω |
Frequency response | 20Hz-40kHz (-0.5dB) |
Total harmonic distotion more noise (THD+N) | 0.02% |
Channel separation | 111dB @ 32Ω |
Dynamic range | 118dB @ 32Ω |
Signal-to-noise ratio (SNR) | 118dB @ 32Ω |
Output impedance | <2Ω |
Line outputs | |
Output level | RCA: 2.2V Jack 4.4mm: 4.5V |
Signal-to-noise ratio (SNR) | 119dB |
Supply voltage | 12V |
Color | Silver |
Dimensions | 156 x 150 x 36.5mm |
Weight | 715g |
Package | 1x Shanling EH2 1x Power adapter 1x USB-A to USB-C cable 1x Bluetooth antenna 1x Jack 3.5mm to Jack 6.35mm adapter |
Input | Bluetooth |
Input | USB |
Input | Optical |
Input | SPDIF |
Output | Jack 4.4mm |
Output | RCA |
Max sampling rate | DSD512 |
Max sampling rate | 768kHz |
Color | Silver |
Class | N/A |
Networking | No |
Remote Control | No |
