SHANLING ONIX ZENITH XDA20 DAC Headphone Amplifier
With the ONIX Zenith XDA20, Shanling unveils a high-end DAC and headphone amplifier, combining luxurious design with cutting-edge components. It uses two ES9039Pro DAC chips combined with an in-house developed I/V architecture for digital-to-analogue conversion of rare quality, capable of handling data up to 32-bit 768kHz PCM and DSD512. The amplifier stage is based on a TPA6120 chip, for smooth sound reproduction and power of up to 1620mW at 32Ω. The whole unit is housed in a stunning CNC-machined aluminium case, featuring the black and gold aesthetic characteristic of the ONIX range.
By buying this product you get 225 loyalty points
Reference : 20972
2 259,00 €tax incl.
1 882,50 € tax excl.
Shanling ONIX Zenith XDA20 DAC Headphone Amplifier 2x ES9039Pro 32bit 768kHz DSD512
Shanling ONIX Zenith XDA20 : Front view
With the ONIX Zenith XDA20Shanling unveils a high-end DAC and headphone amplifier, combining luxurious design with cutting-edge components. It uses two ES9039Pro DAC chips combined with an in-house developed I/V architecture for digital-to-analogue conversion of rare quality, capable of handling data up to 32-bit 768kHz PCM and DSD512. The amplifier stage is based on a TPA6120 chip, for smooth sound reproduction and power of up to 1620mW at 32Ω. The whole unit is housed in a stunning CNC-machined aluminium case, featuring the black and gold aesthetic characteristic of the ONIX range.
Shanling ONIX Zenith XDA20: Cutting-edge technology
The heart of the XDA20 is based on a dual ESS ES9039Pro chip, capable of processing PCM streams up to 32-bit/768kHz and DSD512 files with exemplary precision. This dual DAC chip is supported by a proprietary ‘Brighton’ I/V architecture developed in-house by Shanling, using 8 OPA1611s to ensure rich, detailed sound reproduction with an expansive soundstage and impressive dynamics.
Amplification is handled by a TPA6120 chip, renowned for its ability to deliver smooth, controlled sound, even on demanding headphones. The XDA20 can deliver up to 1620mW at 32Ω, with a comfortable power reserve.
The unit is powered by a silent, high-quality power supply section based on two Talema transformers (25W and 15W), supported by four 3300uF / 63V capacitors, for stable, noise-free regulation.
Shanling ONIX Zenith XDA20 : ESS ES9039Pro DAC
Shanling ONIX Zenith XDA20 : Front and rear panels
Shanling ONIX Zenith XDA20: Complete and flexible connectivity
Designed to fit into any type of setup, the Zenith XDA20 offers three distinct output modes: Pre-out, Line-out and headphone amplification, which can be easily selected depending on use. It features a particularly rich set of digital connections, including a USB-B input, an I2S input via HDMI, a coaxial RCA, an optical Toslink, as well as BNC and AES/EBU connectors. On the output side, it offers single-ended RCA and balanced XLR connections on the rear panel, while the front panel receives a 6.35 mm jack headphone output, ensuring great versatility for both headphone listening and integration into a larger hi-fi system.
Shanling ONIX Zenith XDA20: As stylish as it is ergonomic
The Zenith XDA20 features a robust and elegant CNC aluminium chassis, echoing the distinctive black and gold design of the ONIX series. The sleek front panel houses a 3.4-inch colour touchscreen, complemented by a navigation wheel for smooth and intuitive operation. A remote control is also provided for wireless control.
Shanling ONIX Zenith XDA20 : Black chassis surrounded by silver casings
Shanling ONIX Zenith XDA20: I2S pinout
Shanling ONIX Zenith XDA20 : I2S Pinout
Product typeDAC
Headphone amplifier
Inputs1x I2S via HDMI
1x USB-B
1x Coaxial
1x Optical Toslink
1x BNC
1x AES/EBU
Outputs1x Balanced stereo XLR
1x Single-ended stereo RCA
1x Headphone output Jack 6.35mm
DAC chips2x ES9039Pro
USB interfaceXMOS XU316
Supported sampling ratesSPDIF input: PCM up to 24bit 194kHz, DSD64 DOP
I2S input: PCM up to 32bit 768kHz, Native DSD up to DSD512
USB input: PCM up to 32bit 768kHz, Native DSD up to DSD512
Amplification chipTPA6120
Screen3.4" touchscreen
RCA output specifications
Output level2.1V
Frequency response20Hz-40kHz (-0.5dB)
Total harmonic distotion more noise (THD+N)0.0003%
Dynamic range123dB
Channel separation122dB
Signal-to-noise ratio (SNR)123dB
Noise117dB
XLR output specifications
Output level4.2V
Dynamic range127dB
Channel separation126dB
Signal-to-noise ratio (SNR)127dB
Noise114dB
6.35mm headphone jack output specifications
Output powerLow gain: 101mW @ 32Ω
High gain: 1620mW @ 32Ω
High gain: 252mW @ 300Ω
Total harmonic distotion more noise (THD+N)0.003%
Dynamic range121dB
Channel separation69dB
Signal-to-noise ratio (SNR)120dB
Noise112dB
Output impedance3.3Ω
Dimensions320 x 240 x 62mm
Weight5.7kg
Package1x Shanling ONIX Zenith XDA20
1x Remote control
1x Power cable
1x USB cable
InputAES/EBU
InputBNC
InputI2S via HDMI
OutputJack 6.35mm
DAC / ADC ChipES9039PRO
Max sampling rate768kHz
Max sampling rateDSD512
ClassN/A
Remote ControlYes
SHANLING ONIX ZENITH XDA20 DAC Headphone Amplifier 2x ES9039Pro 32bit 768kHz DSD512
With the ONIX Zenith XDA20, Shanling unveils a high-end DAC and headphone amplifier, combining luxurious design with cutting-edge components. It...
