SMSL C200 DAC ES9038Q2M Bluetooth 5.0 aptX-HD LDAC 32bit 768kHz DSD512
SMSL offers with the C200 a DAC as compact as performing, benefiting from a careful design and a connectic able to answer to the majority of integration needs. We find there an ES9038Q2M digital/analog conversion chip offering a precise and clear sound restitution, associated in particular to a second generation USB XMOS interface, allowing the support of high resolution audio streams up to PCM 32bit 768kHz and DSD512.
By buying this product you get 20 loyalty points
Reference : 16812
209,00 €tax incl.
174,17 € tax excl.
Last items in stock !
Shipping date: 05-08-2025.
SMSL C200
SMSL offers with the C200 a DAC as compact as performing, benefiting from a careful design and a connectic able to answer to the majority of integration needs. We find there an ES9038Q2M digital/analog conversion chip offering a precise and clear sound restitution, associated in particular to a second generation USB XMOS interface, allowing the support of high resolution audio streams up to PCM 32bit 768kHz and DSD512. It also has a coaxial and optical input, as well as a Qualcomm QCC5125 Bluetooth 5.0 receiver, which allows you to enjoy your music wirelessly from your smartphone or tablet. Moreover, it supports the codecs of high resolution transmission aptX, aptX-HD and LDAC to achieve a very good sound quality in wireless.
On the output side, there are single-ended stereo RCA and balanced TRS jacks, as well as two headphone outputs in 6.35mm unbalanced and 4.4mm balanced jack format.
1Jack 6.35mm single-ended headphone output
2Multi-function button
3IR receiver
4Screen
5Jack 4.4mm balanced headphone output
6Bluetooth antenna connector
7Optical input
8Single-ended RCA output
9Power connector
10USB-C input
11Coaxial input
12Jack 6.35mm TRS balanced output
SMSL C200 review by Audio Science Review (Amir)
" You get a superb DAC in the C200. The headphone amplifier is also quite clean and competent. "
Test du SMSL C200 par Audio Science Review
Technical characterisitcs
Product typeDAC
DAC chipESS ES9038Q2M
InputsBluetooth 5.0
1x USB-C
1x Optical Toslink
1x Coaxial
Outputs1x Single-ended stereo RCA output
1x Balanced stereo Jack 6.35mm TRS output
1x Single-ended Jack 6.35mm headphone output
1x Balanced Jack 4.4mm headphone output
Output levelTRS : 4.0Vrms
RCA : 2.0Vrms
Headphone output power2x 2.6W @ 16Ω
2x 1.3W @ 32Ω
Headphone output gainLow gain : 0dB
High gain : 11dB
THD+NLine out : 0.0001% (-120dB)
Headphone output : 0.00013% (-117dB)
Dynamic rangeTRS : 126dB
RCA : 125dB
Headphone output : 123dB
SNRTRS : 126dB
RCA : 124dB
Output impedanceLine out : 100Ω
Headphone output : Near 0Ω
Supported sampling ratesUSB : PCM up to 32bit 768khz, DSD up to DSD512
Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Supported Bluetooth codecsAAC, SBC, aptX, aptX HD, LDAC
Consumption5W
Standby consumption< 0.5W
Dimensions139 x 147.5 x 32mm
Weight510g
Package1x SMSL C200
1x Remote control
1x Bluetooth antenna
1x USB cable
1x Power cable
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipES9038Q2M
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
5 reviews
excellent DAC
Très bonne finition, excellente sonorité, très musical, je le préfère au Topping DX3 pro que je possède également. Puissance de l'amplificateur casque un peu limite pour certains modèles.
Dommage qu'il n'y ai pas d'interrupteur marche arrêt à l'arrière. Sinon que du bonheur.
This review has been posted for SMSL C200 DAC ES9038Q2M Bluetooth 5.0 aptX-HD LDAC 32bit 768kHz DSD512
vfm amp/dac with trs output.
Paired with the edition xs and my monitor speakers everything works perfect. Very fast delivery 24hr first time experiencing that really nice. I only hope that the device has longevity. Recommended.
Très bon DAC pour le prix
Satisfait de cet achat.
Son clair et précis, construction qui paraît solide, montage qualitatif.
Branché sur un PC Windows 10, sans pilote, avec câble optique (S/PDIF), le tout relié à un ampli Marantz;
Testé aussi avec USB, fonctionne parfaitement (sans pilote);
Appairage Bluetooth sans difficulté.
Seul bémol, le câble d'alimentation électrique très rigide et surtout très court. Sa longueur ne permet pas d'atteindre une prise au sol depuis une console/meuble de hauteur standard. J'ai dû le remplacer par un câble d'alimentation PC classique et identique mais plus long.
Audiophonics : livraison rapide et emballage de qualité; La notice jointe en français n'était pas celle du C200 (mais celle du DO100). La notice originale en anglais est de toutes façons très succincte.
Excellent Dac ampli casque
Ce DAC/Ampli casque tient toute ses promesses, la dynamique est très bonne, vraiment neutre, des détails à foison, la séparation des canaux bien marqués, la scène sonore bien large, il y a mieux pour la profondeur mais elle existe…
Bien timbré, il y a plus « musicale » mais parfois au détriment de la transparence, impitoyable avec les mauvais enregistrements…
Je recommande ce Smsl C200 , qui pourra s’intégrer dans un système haute fidélité.
Excellent appareil
Un excellent DAC ! La qualité audio est vraiment au rendez vous et cela se ressent ! La séparation des canaux est impeccable, les entrées fonctionnent très bien, hormis peut-être le Bluetooth lorsque je suis connecté en LDAC où il y a quelques rares petit sauts mais rien de grave, d'autant que ma configuration (lecture de fichiers FLAC depuis un NAS à distance via un VPN) doit jouer aussi sur ça ...
La télécommande est simple, et à mon goût intuitive, il y a 100 crans pour le volume donc on peut vraiment le régler au dB près ...
Une seule petite remarque, le filtre PCM n'est pas supprimable : il semblerait que ce soit utile pour la liaison optique, probablement pour supprimer les hautes fréquences, bien que cela me semble étrange car c'est du PCM utilisé par la liaison optique et non du DSD, rien n'est expliqué dans le manuel, bizarre ...
Bref pour l'instant un super appareil avec bien sûr une puce ESS qui offrent pour moi la meilleure sonorité (notamment dans les aigus).
DAC très recommandé !
SMSL offers with the C200 a DAC as compact as performing, benefiting from a careful design and a connectic able to answer to the majority of...
