SMSL DO200 PRO DAC
With its DO200 PRO, SMSL breaks new ground and unveils an ultra-high-performance DAC incorporating no less than twelve Cirrus Logic CS43131 DAC chips and an XMOS XU316 USB interface for ultra-high performance. It supports high-resolution streams up to PCM 32bit 768kHz, native DSD up to DSD256, as well as MQA/MQA-CD streams.
By buying this product you get 39 loyalty points
Reference : 19199
399,00 €tax incl.
332,50 € tax excl.
Shipping date: 15-04-2026.
SMSL DO200 PRO Blanced DAC 12x CS43131 XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD256 MQA/MQA-CD
SMSL DO200 PRO : Front view
With its DO200 PRO, SMSL breaks new ground and unveils an ultra-high-performance balanced DAC incorporating no less than twelve Cirrus Logic CS43131 DAC chips and an XMOS XU316 USB interface for ultra-high performance. It supports high-resolution streams up to PCM 32bit 768kHz, native DSD up to DSD256, as well as MQA/MQA-CD streams. The DO200 PRO features wireless connectivity thanks to a Qualcomm QCC5125 Bluetooth chip supporting aptX, aptX-HD and LDAC 24bit/96kHz codecs. One of its major assets is its connectivity and compatibility, made possible by an HDMI ARC port, a USB-C input and optical inputs. Regarding the chassis, we're back to SMSL's slim, sober design, with a color screen that displays information on the track being played and makes it easy to navigate through the DAC DO200 PRO's various parameters.
SMSL DO200 PRO highlights
SMSL DO200 PRO: 12 CS43131 DAC chips and 6 OPA1612 AOPs
Innovative brand SMSL goes so far as to implement 12 Cirrus Logic CS43131 DAC chips in its DO200 PRO DAC, creating a 12-core driver configuration for high processing power and audio resolution. Digital-to-analog conversion is therefore effortless, even for rich signals. Texas Instrument's OPA1612 AOPs are used to amplify and texture the signal at the DO200 PRO's output.
SMSL DO200 PRO's 12 DAC chips
Photo of SMSL DO200 PRO XMOS XU316 USB interface
SMSL DO200 PRO: XMOS XU316 USB interface
The DO200 PRO's USB-C input is coupled to a third-generation XMOS XU316 interface, enabling it to support high-resolution PCM 32 bit 768kHz streams, and native DSD up to DSD256 for the most vivid sound reproduction.
SMSL DO200 PRO: HDMI ARC port
The HDMI ARC port on the DO200 PRO lets you retrieve the audio signal from a TV for a slightly more immersive experience, thanks to a combo amplifier and passive speakers, or simply active speakers.
SMSL DO200 PRO HDMI ARC connector
SMSL DO200 PRO: Bluetooth 5.1
A QCC5125 Bluetooth receiver chip enables this DAC to support high-definition wireless transmission codecs: SBC, AAC, aptX, aptX HD and LDAC 24bit/96kHz. The DO200 PRO can therefore be paired with a smartphone or tablet to enjoy your streaming applications quickly and easily.
SMSL DO200 PRO : Bluetooth 5.1
SMSL DO200 PRO: compatibility with video game consoles
The DO200 PRO's USB-C port is compatible with both USB1.1 and USB2.0. To enjoy your console, whether PS5 or Nintendo Switch, simply switch to USB1.1 mode. USB 1.1 supports 24bit/96kHz PCM streams. Once your DAC has been switched to USB1.1 mode, simply restart it for the change to take effect.
SMSL DO200 PRO extended compatibility
SMSL DO200 PRO MQA support
SMSL DO200 PRO: decoding MQA/MQA-CD streams
MQA x8 and MQA CD files are supported by Toslink optical, SPDIF Coaxial and USB-C inputs for users wishing to enjoy audio files as close as possible to studio recording files.
SMSL DO200 PRO: 2 operating modes and 5 PCM filters
The DO200 features a "VARIABLE" mode for volume adjustment, as well as a "FIXED" mode for a fixed output level. In addition, an adjustable gain via a switch on the underside of the case allows the output level to be adjusted to 4V or 5V. To complete the package, SMSL has integrated 5 PCM filters to adjust the sound according to your preferences or the type of track being played.
SMSL DO200 PRO operating modes
Photo of SMSL RC-8C IR control unit
SMSL DO200 PRO: IR remote control
The new SMSL RC-8C remote control allows you to remotely control the DO200 PRO for a smooth user experience and easy navigation through settings and parameters.
SMSL AO200 PRO overview
SMSL DO200 PRO overview
1Display
2IR receiver
3LED indicator
4Volume control
5Analog RCA stereo output
6XLR balanced stereo analog output
7SPDIF coaxial input
8Toslink optical input
9HDMI ARC
10Bluetooth antenna
11USB-C input
12Power input
13Power switch
Test of the DO200 Pro DAC by Audio Science Review
"The DO200 Pro DAC turns in state of the art performance for what is a very good price these days for a balanced DAC. Inclusion of HDMI ARC I am sure is appreciated by many. There are a few minor nits but nothing remotely interfering with fully transparent (to source) operation of the unit. I am happy to recommend the SMSL DO200 Pro."
Product typeDAC
DAC chip12x CS43131
USB interfaceXMOS XU316
Bluetooth chipQualcomm QCC5125
OPAOPA1612
Inputs1x USB-C input
1x HDMI ARC port
1x Toslink optical input
1x Coaxial input
Bluetooth
Outputs1x RCA output
1x XLR balanced output
Supported sample ratesUSB-C: PCM 32bit 768kHz, DSD256, MQA/MQA-CD
Toslink optical and SPDIF coaxial: 24bit 192kHz, DSD DoP64
Bluetooth5.1
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
Max. output levelRCA: 2.5Vrms
XLR: 5.2Vrms
THD+N0.00006% (-123dB)
Dynamic rangeRCA: 128dB
XLR: 134dB
SNRRCA: 128dB
XLR: 134dB
USB transmissionAsynchronous
USB compatibilityWindows 7/8/8.1/10/11 (with driver)
MAC OSX10.6 & Linux (without driver)
Operating modesVARIABLE: volume control
FIXED : fixed output level
Screen adjustementBrightness (1 to 8)
Screen saver5-60 seconds
Power consumptionOperating: < 10W
Standby: < 0.5W
Dimensions189 x 45 x 186mm
Weight1.15Kg
Package1x SMSL DO200 PRO DAC
1x USB-A to USB-C cable
1x Bluetooth antenna
1x IR remote control
1x Mains power cable
SMSL DO200 PRO measurements
InputHDMI ARC
DAC / ADC ChipCS43131
Max sampling rateDSD256
Max sampling rateMQA
Max sampling rate768kHz
Remote ControlYes
Had a Topping E50 before. This is way more natural sounding, especially in the highs and the mids. Instruments have a realistic timbre. Also has better details and a bigger, more precise soundstage. This is the sound that I wanted. Fantastic DAC!
 (3)
This review has been posted for SMSL DO200 PRO Balanced DAC 12x CS43131 XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD256 MQA/MQA-CD
With its DO200 PRO, SMSL breaks new ground and unveils an ultra-high-performance DAC incorporating no less than twelve Cirrus Logic CS43131 DAC...
