LSMSL's DS100 is a compact, high-performance DAC that can also act as a headphone amplifier. With its well-designed construction, it offers great versatility and high-quality sound reproduction.
SMSL's DS100 is based on Cirrus Logic's CS43131 chip. In addition to high-quality digital/analogue conversion, this chip offers an output of 2 Vrms for 600 Ω high-impedance headphones with >110 dB inter-channel isolation, and 30 mW for 32 Ω low-impedance headphones. Thanks to this Cirrus Logic chip, the DS100 is capable of driving a wide range of headphones.
The DS100's USB-C input is paired with a high-performance XMOS XU316 interface, which efficiently processes the audio signal received. In conjunction with the CS43131 DAC, it enables the SMSL DS100 to support high-resolution audio signals up to PCM 32bit 768kHz and DSD512.
The DS100 also incorporates an MQA (Master Quality Authenticated) decoder. This format offers very high sound quality, as close as possible to studio recording, with each file authenticated by the artist, producer or copyright holder. SMSL's DAC also supports MQA-CD.
1 | 6.35 mm Jack headphone output |
2 | 4.4 mm Jack headphone output |
3 | MQA indicator |
4 | Headphone amplification indicator |
5 | Coaxial indicator |
6 | Optical indicator |
7 | USB indicator |
8 | Volume knob |
9 | USB-C input |
10 | Toslink optical input |
11 | Coaxial input |
12 | Stereo RCA output |
Product type | DAC / Headphone amplifier |
DAC / amplification chip | Cirrus Logic CS43131 |
Inputs | 1x USB-C 1x Optical Toslink 1x Coaxial |
Outputs | 1x Headphone output 6.35 mm Jack 1x Headphone output 4.4 mm Jack 1x Stereo RCA |
Output level | 2Vrms |
Total harmonic distortion (THD) | 0.00017% |
Signal-to-noise ratio | 127dB |
Dynamic range | 127dB |
USB Compatibility | Windows 7/8/8.1/10/11 (driver needed) Mac OSX 10.6+ Linux Android |
Supported sampling rates | USB : PCM up to 32bit 768kHz, Native DSD up to DSD512, MQA, DoP 256 Optique / Coaxial : PCM up to 24bit 192kHz, MQA, DoP 64 |
Consumption | <1W |
Standby consumption | <0.1W |
Dimensions | 101 x 89 x 30mm |
Weight | 180g |
Color | Black |
Package | 1x SMSL DS100 1x USB-C to USB-A Cable |
Input | USB |
Input | Optical |
Input | SPDIF |
Output | Jack 6.35mm |
Output | RCA |
Output | Jack 4.4mm |
DAC / ADC Chip | CS43131 |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Max sampling rate | MQA |
Color | Black |
Networking | No |
Remote Control | No |
