SMSL M400 Balanced DAC AK4499 XMOS XU216 MQA 32bit 768kHz DSD512
The SMSL M400 is a DAC with balanced and single-ended outputs taking advantage of very high fidelity components: DAC AKM AK4499 chip, USB interface XMOS U216. It supports MQA formats.
By buying this product you get 99 loyalty points
Reference : 14554
999,00 €tax incl.
832,50 € tax excl.
Last items in stock !
Shipping date: 22-05-2025.
SMSL M400
DAC AK4499 Balanced XMOS XU216 MQA 32bit 768kHz DSD512
SMSL M400 DAC AK4499 Amplificateur Casque XMOS XU216 MQA 32bit 768kHz DSD512
DAC AK4499
The M400 uses a high performance DAC AK4499 chip. This is currently the best performance conversion chip built by AKM, it allows the M400 to reach an impressive SNR of 131dB with a THD+N of -124dB. .
Thanks to this conversion chip, the M400 supports high sampling rates and lets you enjoy the most precise reproduction possible for your very high resolution audio files. The M400 is able to play PCM files up to 32bit 768kHz and Native DSD up to DSD512.
Support MQA
MQA for Master Quality Authenticated is an award-winning British technology for restoring the sound of the original recording. The MQA Master file is authenticated by the artists, producers or rights holders. These files are small enough to be streamed or downloaded.
The M500 includes an MQA decoder to play these files in order to provide the best possible audio quality.
MQA decoding is only available via the USB input.
Review by Audio Science Review
We have another "instrument grade" DAC here from SMSL in the form of M400. Performance is beyond question, landing at the top of the class.
 test by the measurement forum Audio Science Review
Complete connectivity
On the connection side, the SMSL M400 is extremely well equipped, with an optical SPDIF input, a coaxial SPDIF input, a USB-B input working with an excellent XMOS U216 interface, an I2S input via HDMI respecting the LVDS standard.
The M400 can also receive bluetooth audio streams and supports the best audio protocols available today : UAT, LDAC, apt-X HD, SBC, AAC, for wireless transmission up to 192kHz - 24bit.
The device has a balanced stereo output on 3-pole XLR connectors as well as a single-ended stereo output on RCA connectors.
The XLR and RCA outputs are active simultaneously.
USB interfae XMOS XU216
The USB input of the M500 is associated with an XMOS XU216 32bit XMOS interface, with custom driver. This ensures rich and transparent playback while supporting high sampling rates.
SMSL M400 horloges accusilicon circuit numérique
Horloges Accusilicon
The digital stage of the M400 uses ultra high precision and ultra low noise Accusilicon clocks to provide the best audio performance.
These crystal oscillators with extremely low phase noise (<90dBc @ 10Hz) are usually intended for professional recording devices. They propose a singularly low jitter rate measured at <2ps on the 10Hz-1MHz band and <0.08ps on the 12-80MHz band.
Filtres numériques
The SMSL M500 also includes 7 digital filters for PCM signals, allowing you to adapt the playback to your listening needs.
  1. Fast linear
  2. Slow linear
  3. Apodizing
  4. Fast minimum
  5. Slow minimum
  6. Fast hybrid
  7. Brickwall
Screen & Housing
The SMSL M500 is equipped with a beautiful bright display on the front panel, allowing it to display all the information about the current playback. This includes the volume level, active input, flow and file type, as well as the sampling rate of the read file. This screen is protected by a tempered glass pane.
The components are hidden under a beautiful and robust CNC machined anodized Aluminium housing.
The unit also comes with an IR remote control for easy remote control.
Diagram
SMSL M500 DAC ES9038Pro Amplificateur Casque XMOS XU216 MQA 32bit 768kHz DSD512
1Volume / menu knob
2Display
3I/R receiver
4Bluetooth Antenna
5Optical input
6Single ended output
7Balanced output
8IIS input
9Coaxial input
10USB input
11AC input
Pinout I2S via HDMI
SMSL M400 DAC AK4499 Symétrique XMOS XU216 MQA 32bit 768kHz DSD512
TypeDAC
Inputs1x USB-B
1x Optical Toslink
1x Coaxial
1x I2S via HDMI (LVDS & inverted)
1x Bluetooth 5.0
Outputs1x RCA single-ended
1x XLR balanced
THD+N0.000058%
Dynamic range131dB
SNR131dB
USB transmissionAsynchrone
USB supportWindows 7 / 8 / 8.1 / 10
Mac OSX 10.6 ou supérieur
Linux
Bit-depthUSB : 1bit, 16~32bit
Optique / Coaxial : 1bit, 16~32bit
Sampling ratesUSB : PCM 44.1 ~ 768kHz / DSD 2.8224 ~ 22.5792MHz
Optique, Coaxial : PCM 44.1 ~ 192kHz / DSD64 (DoP)
Bluetooth : 44.1 ~ 192kHz
Bluetooth audioUAT, LDAC, apt-X HD, AAC
GENErAL
Power consumption5W
Power consumption (idle)0.5W
Dimensions215 x 220 x 43 mm
Weight1.53 kg
Power cableInclued
RemoteInclued
InputI2S via HDMI
DAC / ADC ChipAK4499
Max sampling rateDSD512
Max sampling rate768kHz
Remote ControlYes
4 reviews
Très bon produit beau désigne excellente qualité sonore
This review has been posted for SMSL M400 Balanced DAC AK4499 XMOS XU216 MQA 32bit 768kHz DSD512
For high-end systems!
Outstanding low frequency sound and detail.
Very balanced and neutral sound!
The best benefit for fans of any music genre!
dac smsl M400
Un DAC avec un rapport qualité prix remarquable, ce DAC met bien en valeur la musique, écoute agréable, jamais fatigante.
dac smsl M400
The SMSL M400 is a DAC with balanced and single-ended outputs taking advantage of very high fidelity components: DAC AKM AK4499...
