SMSL RAW-DAC1 DAC
The SMSL RAW-DAC1 is a high-performance, elegant DAC based on a combo of AKM AK4499EX+AK4191 chips and a USB XMOS XU-316 interface. These audiophile components enable it to support high-resolution sampling rates up to PCM 32bit 768kHz, DSD512 and MQA/MQA-CD.
4.5 / 5
Reference : 19917
499,00 €tax incl.
415,83 € tax excl.
Shipping date: 07-04-2026.
SMSL RAW-DAC1 DAC AK4191+AK4499EX Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512 MQA-CD
SMSL RAW-DAC1 picture
The SMSL RAW-DAC1 is a high-performance, elegant DAC based on a combo of AKM AK4499EX+AK4191 chips and a USB XMOS XU-316 interface. These audiophile components enable it to support high-resolution sampling rates up to PCM 32bit 768kHz, DSD512 and MQA/MQA-CD. In addition, Bluetooth 5.1 supports aptX, aptX HD, aptX Adaptive and LDAC codecs for reliable, stable wireless transmission. SMSL has also equipped the RAW-DAC1 with an optimized CK-03 clock circuit and a low-noise power supply. In terms of appearance, the RAW-DAC1 features an attractive tempered-glass LCD color display and elegant curves. As for the RAW-DAC1's input/output interface, it features numerous digital inputs such as a USB-C input, an HDMI I2S input, two Toslink optical inputs and two coaxial inputs, while outputs include RCA and balanced XLR.
SMSL RAW-DAC1: AKM AK4499EX+AK4191 combo and XMOS XU-316 USB interface
The RAW-DAC1's high-performance chipset, comprising the AK4499EX DAC chip, AK4191 digital filter interface and XMOS XU-316 USB interface, gives it an ultra-low distortion level of 0.00006% (-124dB) and a dynamic range of up to 132dB on its XLR output. All this while supporting high-resolution sampling rates up to PCM 32bit 768kHz, DSD512 and MQA/MQA-CD via its USB-C input. The RAW-DAC1 is therefore the ideal choice for enjoying music files at the highest possible resolution, and enjoying high quality listening sessions.
AKM AK4499EX+AK4191 combo and SMSL RAW-DAC1 XMOS XU-316 USB interface
Bluetooth functionality of the SMSL RAW-DAC1
SMSL RAW-DAC1: Bluetooth 5.1
A Bluetooth receiver chip also enables it to support the wireless transmission codecs SBC, AAC, aptX, aptX HD, aptX Adaptive and even LDAC. This makes the RAW-DAC1 quick and easy to use with smartphones and streaming applications, for example.
SMSL RAW-DAC1: optimized components
Photo of CK-03 clock circuit
CK-03 clock circuit
The clock circuit developed by SMSL considerably reduces jitter and, consequently, improves the DAC's performance.
Photo of low-noise power supply for SMSL RAW-DAC1
Low-noise power supply
RAW-DAC1's isolated low-noise power supply provides clean power.
SMSL RAW-DAC1: a refined look and interface
The front panel of the SMSL RAW-DAC1 features an attractive 2.33” color LCD screen, giving access to an ergonomic, aesthetically pleasing interface displaying all the information you need to use it.
Photo of SMSL RAW-DAC1 screen and interface
SMSL RAW-DAC1 overview
1Balanced XLR analog output
2RCA analog output
32x Coaxial SPDIF inputs
42x Toslink optical inputs
5I2S input via HDMI
6USB-C input
7Bluetooth antenna
8IEC power supply/Power switch
Product typeDAC
DAC chipAK4191+AK4499EX
USB interfaceXMOS XU-316
Inputs1x USB-C
1x I2S via HDMI
2x Optical Toslink
2x Coaxial
Bluetooth
Outputs1x RCA
1x Balanced XLR
Output levelRCA : 2.5Vrms (variable)
XLR : 5Vrms (variable)
THD+N0.00006% (-124dB)
Dynamic rangeXLR: 132dB
RCA: 127dB
SNRXLR: 132dB
RCA: 127dB
Supported sample ratesUSB: 32bit 768kHz, DSD512, MQA/MQA-CD
Optical Toslink / Coaxial: 24bit 192kHz, DSD DoP64, MQA/MQA-CD
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, aptX Adaptative, LDAC
USB transmissionUSB 2.0 Asynchronous
USB compatibilityWindows 7/8/8.1/10/11 (with driver)
MAC OSX 10.6 ou +
Linux
Power supplyAC 100-240V
Energy consumption< 10W
Standby: < 0.5W
Dimensions219 x 180 x 45mm
Weight1.33kg
Package1x SMSL RAW-DAC1
1x Remote control
1x Bluetooth antenna
1x Power cable
SMSL RAW-DAC1 measurements
InputI2S via HDMI
DAC / ADC ChipAK4191
DAC / ADC ChipAK4499EX
Max sampling rateMQA
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
2 reviews
Great connectivity, good functionality
Pleasant unit, good clear sound. If you are looking for a modern DAC with a little extra in the base and detailed sound that is a bit smoother than most Sabre DACs, this might be for you. in my case, I didn't like the sound signature and did not feel like an upgrade for me. In the end I went with Denafrips Enyo instead.
This review has been posted for SMSL RAW-DAC1 DAC AK4191+AK4499EX Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512 MQA-CD
Excellent DAC - perhaps where diminishing returns really kick in.
Bass extends down, and highs are pristine. The sound stage is very wide, with good depth depending on the recording. Perhaps best of all is an 'infectious' quality. This is definitely a step from my previous ES9038Q2M equipped units, and ZEN DAC 2. I also tried a Topping Centaurus, and while I can appreciate many liking the presentation, and slight lushness even on broadcast voices in particular, my point is that the SMSL Raw-DAC 1 renders music equally validly ... but different. Extra and varied inputs a bonus.
The SMSL RAW-DAC1 is a high-performance, elegant DAC based on a combo of AKM AK4499EX+AK4191 chips and a USB XMOS XU-316 interface. These...
