Audiophonics a été très réactif quant à la livraison mais DPD n'a pas respecté les délais nis mon colis il est arrivé dans un état abominable heureusement qu'il est bien protégé.
sinon le DAC et fantastique !
The SMSL RAW-MDA1 is a balanced DAC featuring two ESS ES9039Q2M chips and a USB XMOS XU316 interface. These high-quality components enable it to support high-resolution streams up to PCM 32bit 768kHz, native DSD up to DSD512 and MQA. Added to this is Bluetooth 5.1 functionality thanks to a Qualcomm receiver chip supporting SBC, AAC, aptX, aptX HD and LDAC codecs. The RAW-MDA1 also benefits from an independent headphone amplification circuit for consistent output power in balanced 4.4mm jack or 6.35mm jack. Several digital and optical inputs are available: USB-C, 2x SPDIF Coaxial, 2x Optical Toslink, complemented by a stereo RCA line output and a balanced XLR output.
The SMSL RAW-MDA1 DAC supports high-resolution PCM 32bit 768kHz and native DSD streams up to DSD512 thanks to its XMOS XU316 USB interface and two ES9039Q2M DAC chips. The RAW-MDA1's balanced operation offers excellent performance, with a dynamic range of 132dB and a THD+N of 0.00005%.
The RAW-MDA1 DAC benefits from the most advanced MQA decoding technology, enabling it to perform complete expansion of MQA and MQA-CD files.
The RAW-MDA1 DAC is equipped with a Qualcomm Bluetooth receiver chip supporting the following high-definition codecs: SBC, AAC, aptX, aptX HD, and LDAC. The Bluetooth LDAC codec enables stream transfer at up to 24bit 96kHz.
An independent headphone amplifier circuit enables the SMSL RAW-MDA1 to achieve an output power of up to 2x 2.5W into 16 Ohm and up to 1.7W into 32 Ohm. The RAW-MDA1 is therefore able to drive many of the headphones available on the market.
The RAW-MDA1's USB-C input operates in both USB1.1 and USB2.0. This is convenient for those wishing to use this DAC with video game consoles such as PlayStation or Nintendo Switch. USB 2.0 supports 32bit 768kHz PCM streams via a driver, while USB1.1 supports 24bit 96kHz PCM streams without a driver.
The SMSL RAW-MDA1 features no less than 6 AOP1612A.
The SMSL RAW-MDA1's clock circuit reduces jitter considerably.
The SMSL RAW-MDA1 features a low-noise power supply delivering clean, reliable current.
1 | Jack 6.35mm headphone output |
2 | Balanced Jack 4.4mm headphone output |
3 | Display |
4 | Standby LED indicator |
5 | IR remote control receiver |
6 | Multifunction buttons / volume control |
7 | XLR balanced stereo output |
8 | RCA stereo output |
9 | 2x SPDIF coaxial input |
10 | 2x Toslink optical input |
11 | Bluetooth antenna |
12 | USB-C input |
13 | IEC power supply |
" The RAW-MDA 1 aims high and achieves it across the board despite its very reasonable price. It is good looking, compact and easy to operate. Some of this we expect from SMSL but the total package is a step forward, as difficult as that may have seemed. I am happy to recommend the SMSL RAW-MDA 1. "
Product type | DAC / Headphone amplifier |
DAC chips | 2x ES9039Q2M |
OPA | 6x OPA1612A |
Inputs | 1x USB-C 2x SPDIF coaxial 2x Optical Toslink Bluetooth 5.1 |
Outputs | 1x Balanced XLR stereo 1x Single-ended RCA stereo |
Supported sample rates | USB: PCM 32bit 768kHz,DSD DoP256, DSD natif DSD512 and MQA Coaxial SPDIF and Optical Toslink: PCM 24bit 192kHz, DSD DoP64, MQA |
THD+N | 0.00005% (-124dB non-weighted) |
Output level | XLR: 5.2Vrms RCA: 2.5Vrms Headphone outputs: 8.2Vrms |
Headphone output power | 2x 2.5W @ 16 Ohms 2x 1.7W @ 32 Ohms |
Output impedance | Line outputs: 100 Ohms Headphone outputs: close to 0 Ohms |
Dynamic range | XLR: 132dB RCA: 127dB Headphone outputs: 122dB |
SNR | XLR: 132dB RCA: 127dB Headphone outputs: 122dB |
USB transmission | Asynchronous |
USB compatibility | Windows 7 / 8 / 8.1 / 10 / 11 (avec driver) MAC SOX10.6 et plus (sans driver) Linux (sans driver) |
Bluetooth version | Bluetooth 5.1 |
Supported bluetooth codecs | SBC, AAC, aptX, aptX HD, LDAC |
Energy consumption | < 30W Standby: < 0.5W |
Dimensions | 189 x 45 x 179mm |
Weight | 1.02kg |
Package | 1x SMSL RAW-MDA1 DAC 1x USB cable 1x Bluetooth antenna 1x RC-8C remote control 1x Power cable |
Input | SPDIF |
Input | Bluetooth |
Input | USB |
Input | Optical |
Output | XLR |
Output | RCA |
DAC / ADC Chip | ES9039Q2M |
Max sampling rate | DSD512 |
Max sampling rate | MQA |
Max sampling rate | 768kHz |
Color | Black |
Networking | No |
Remote Control | Yes |
Average votes 4.8 / 5 5 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Kirsch p.
Rik H.
Panos M.
vincent m.
Mehdi O.
