SMSL SU-9 DAC ES9038Pro USB XMOS Bluetooth 5.0 MQA 32bit 768kHz DSD512
Successor of the SU-8, the SMSL SU-9 takes up the excellent base of the SU-8 while bringing significant improvements to improve its sound performance. This new version of the DAC also offers support for MQA (Master Quality Authenticated) files, guaranteeing faithful reproduction, as close as possible to studio recording. On the conversion chip side is the excellent and proven DAC ESS ES9038Pro, supporting high-resolution files up to 32bit 768kHz PCM and up to DSD512.
By buying this product you get 47 loyalty points
Reference : 14801
479,00 €tax incl.
399,17 € tax excl.
Shipping date: 20-05-2025.
SMSL SU-9
SMSL SU-9 DAC ES9038Pro USB XMOS Bluetooth 5.0 32bit 768kHz DSD512
Successor of the SU-8, the SMSL SU-9 takes up the excellent base of the SU-8 while bringing significant improvements to improve its sound performance. This new version of the DAC also offers support for MQA (Master Quality Authenticated) files, guaranteeing faithful reproduction, as close as possible to studio recording. On the conversion chip side is the excellent and proven DAC ESS ES9038Pro, which supports high-resolution files up to 32bit 768kHz PCM and up to DSD512.
The ergonomics of the device has also been reviewed. The front panel now features a rotary knob that allows you to navigate through the menus, adjust the volume level, select a source or turn the device on and off. The color screen has been greatly enlarged for improved navigation and readability.
The connections remain unchanged and therefore as complete as ever. We find Toslink Optics, Coaxial and USB (XMOS) in input and unbalanced RCA as well as balanced XLR in output. However, a novelty appears here as well, with the support of Bluetooth 5.0 transmission. Particularly convenient, it is possible to broadcast your music remotely, directly from a smartphone.
The SU-9's careful and well thought-out internal design allows it to unveil a precise, rich and dynamic sound reproduction.
MQA Support
Master Quality Authenticated (MQA) files offer the same quality as when the song is recorded in the studio, resulting in much lower distortion, a wider sound stage, and richer, more accurate playback.
The MQA uses a treatment called "musical origami". This makes this high-resolution file easy to manage in order to make it compatible with all audio playback services and devices. This process consists of 3 steps.
Bluetooth UAT Reception
The SMSL SU-9 allows a Bluetooth reception, particularly practical to broadcast music from your phone. It also supports all available transmission codecs, including high-resolution protocols such as LDAC, aptX, aptX-HD, XBC and AAC. It is also compatible with the UAT (Ultra Audio Transmission) format, allowing high quality reception at 24bit 192kHz.
1Volume / Navigation / Power ON-OFF Button
2Screen
3IR Receiver
4Bluetooth Antenna
5Optical input
6Single-ended RCA output
7Balanced XLR output
8Coaxial Input
9USB-B Input
10Power supply
SMSL SU-9 Review by Audio Science Review
Looks like we started a trend to achieve perfection in desktop DACs and the SMSL SU-9 is yet another example of that. We have another great "instrument grade" DAC on our hands providing absolute transparency to the source beyond any threshold of human hearing. "
Test du SMSL SU-9 par Audio Science Review
Included in this product
Product typeDAC
DAC ChipESS ES9038Pro
USB InterfaceXMOS
Digital reception cgipESS ES9311
Inputs1x USB-B
1x Optical Toslink
1x Coaxial SPDIF
Bluetooth
Outputs1x Balanced XLR
1x Single-ended RCA
Dynamic rangeXLR : 130dB
RCA : 123dB
SNR130dB
Output impedanceXLR : 207Ω
RCA : 142Ω
USB TransmissionAsynchronous
USB CompatibilityWindows 7 / 8 / 8.1 / 10
Mac OSX
Linux
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD jusqu'à DSD512
Optical / Coaxial : PCM up to 24bit 192kHz, DSD64 (DoP)
Bluetooth SpécificationsUAT : 24bit 192kHz (1200kbps / 900kbps / 600kbps)
LDAC : 24bit 96kHz (990kbps / 660kbps / 330kbps)
aptX-Hd : 24bit 48kHz (576kbps)
aptX : 16bit 44.1kHz (352kbps)
SBC : 16bit 44.1kHz (328kbps)
AAC : 16bit 44.1kHz (320kbps)
Supply voltage100 - 240VAC (cable included)
Consumption5W
Standby consumption< 0.5W
Dimensions154 x 187.5 x 40mm
Weight790g
Housing materialAluminum
Package1x SMSL SU-9
1x Remote control
1x USB cable
1x Power cable
THD+N
Jitter (Coaxial)
Intermodulation distortion
Frequency response
DAC / ADC ChipES9038PRO
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
22 reviews
Very satisfied
Fast delivery, quality service.
This review has been posted for SMSL SU-9 DAC ES9038Pro USB XMOS Bluetooth 5.0 MQA 32bit 768kHz DSD512
Mini mais costaud
Livré avec câble USB bas de gamme très court ... dans mon cas trop court ! commande d'un câble plus long chez Audiophonics et livré dans les temps.
La qualité est très étonnante pour un si petit DAC au prix raisonnable. Il prendra sa place dans une chaîne à plusieurs millier d'euros sans problème et si vous n'êtes pas satisfait du résultat vous devrez peut-être aller voir au niveau de votre ampli ou de vos enceintes ... mais là c'est une autre histoire ...
En conclusion: pas assez cher mon fils, pas assez cher...
Bon
Très très bon il n'a plus rien à prouver.
Ont espère qu'il n'a pas d'obsolescence programmé c:
Je croise les doigts :) Mais pour l'instant il semble robuste.
Tres bon DAC
Je l'utilise essantellement entre un lecteur preampli ,un CD servant de transport et un ampli MPA-S250NC Audiophonic.
Le son est légèrement analogique et tout en finesse.
Je pense que le son va encore s'améliorer dans quelques jours.
Merci à David pour ses conseils.
Envoi rapide, mais ceci devient normal chez Audiophonics et très apprécié.
Son excellent... en USB
Je l'utilise principalement avec Tidal sur mon iphone, l'Amplificateur Casque Symétrique SH-9 de la même marque et un casque Sennheiser HD660S. Mais aussi sur ma chaine hifi (ampli classe D & enceintes Dynaudio).
Le son est remarquable. Comparaison avec un convertisseur haut de gamme à tube mais plus vieux : Son plus précis, sur tout le spectre mais parfois un peu froid pour le SU-9.
Cependant après quelque semaines d'utilisation le bluetooth ne fonctionne plus. Un mal pour un bien car j'ai commandé un "meloaudio Adaptateur de caméra USB avec Port de Charge" sur Amaz** et depuis je l'utilise en connectant directement l'iphone à l'USB. Conséquence quand j'utilise des fichiers "master" sur Tidal le logo "master" s'affiche sur le SU-9 et le son est bien superieur me semble t'il (je ne peux pas comparer puisque le bluetooth ne fonctionne plus).
Je viens d'envoyer un email au SAV. Donc 4 étoiles pour ce problème de bluetooth bien que sur le plan sonore les 5 étoiles me semblent être méritées.
Successor of the SU-8, the SMSL SU-9 takes up the excellent base of the SU-8 while bringing significant improvements to improve its sound...
